Ignace:
Another question that if answered could be added to the FAQ:FAQ which covers several of these questions.
Can I have the Beosound 5/Beomaster 5 and another Audiomaster in the same room and the same Masterlink setup.
Does the AudioMaster need to be N.MUSIC compatible?
What setting needs to be applied in order to get this working?
I will be updating the FAQ over the next couple of days with answers to questions such as the ones highlighted above, but in the meantime the answers to these particular question are:-
- Your AudioMaster must be compatible to use N.Music or N.Radio
- You CAN have a Beosound 5/Beomaster 5 in the same room and on the same Masterlink setup, see below for further details
In the Service Menu you are provided with the ability to define whether the BeoMaster 5/BeoSound 5 is a AUDIO MASTER or not. If AUDIO MASTER is set to YES, it is possible to define which option the BeoMaster 5/BeoSound 5 is going to be in. If the AUDIO MASTER is set to NO the ‘Option’ item is greyed out. The options are:
- AUDIO MASTER YES / NO
- Audio Master OPTIONS 0 / 1 / 2 (greyed out if AUDIO MASTER is NO)
These and other FAQ items will be added in the next few days. I will also update the typing error I made related to web access.
