BEO6 XML for Samsung Smart TV
Hi all,
I recently bought a Beo6, and now I'm working on a configuration for my Samsung Smart TV UE46D8000.
I've come a long way, starting with the Samsung Plasma TV XML from this site, thank you very much for this. I am however missing a few functions, that have been added to the more recent Samsung LCD TV's.
The functions/buttons I'm missing in the existing Plasma TV XML are:
723 007 007 159 096 000 000 3d
723 007 007 037 218 000 000 ad_subt.
723 007 007 063 192 000 000 e_manual
723 007 007 045 210 000 000 exit
723 007 007 079 176 000 000 guide
723 007 007 062 193 000 000 p.size
723 007 007 088 167 000 000 return
723 007 007 115 140 000 000 search
723 007 007 121 134 000 000 smart hub
723 007 007 100 155 000 000 social tv
723 007 007 075 180 000 000 tools
Can someone please explain/help me how to convert the above (or pronto which are also available) codes to Beo6 XML?
Thank you very much in advance,
kind regards,
Joost
Joost,
The commands you have listed are for Lintronics, it would be better to convert from Pronto HEX codes as you say you have them.
Thanks for your reply. Will post them as soon as I'm back from holidays.....
Kind regards Joost
Dear Keith,
I have added the pronto hex codes for the Samsung Smart TV functions that are currently missing from your Samsung Plasma TV XML.
Can you please explain to me how it's best to have these codes converted to XML that can be imported into Beo6?
kind regards,
Joost
3d
lintronic code
pronto hex code
Device Code: 7.7 Function: 159
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0689
ad_subt.
lintronic code
pronto hex code
Device Code: 7.7 Function: 37
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689
e_manual
lintronic code
pronto hex code
Device Code: 7.7 Function: 63
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689
exit
lintronic code
pronto hex code
Device Code: 7.7 Function: 45
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689
guide
lintronic code
pronto hex code
Device Code: 7.7 Function: 79
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0689
p.size
lintronic code
pronto hex code
Device Code: 7.7 Function: 62
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689
return
lintronic code
pronto hex code
Device Code: 7.7 Function: 88
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0689
search
lintronic code
pronto hex code
Device Code: 7.7 Function: 115
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0689
smart hub
lintronic code
pronto hex code
Device Code: 7.7 Function: 121
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0689
social tv
lintronic code
pronto hex code
Device Code: 7.7 Function: 100
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0689
tools
lintronic code
pronto hex code
Device Code: 7.7 Function: 75
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0689
Please find attached an XML file I have produced from your Pronto HEX codes supplied.
Extract the zip file to C:\ will automatically put the XML file into the correct directory of the B&O Configuration Tool
Please test and provide feedback..
I'm affraid it doesn't work.
Importing the XML works fine and adds a new device to the Beo6, but the TV doesn't respond to the commands.
Comparing the stIR strings, it appears the new non-working strings have around half the length of the other working strings?
Well, I guess the Pronto HEX codes you found are not for your TV which almost certainly means the address code is different.
Over the years I have posted several Samsung TV XML files and most use a different address code. Which one did you use that works, if I know that then I can decode one of the commands and determine the correct address ?
Hi Keith,
Thanks for the effort you put into this.
The working XML i got from this site, I think you have made it. It's called Samsung Plasma TV and contains all working codes, except that it's missing the mentioned 11 functions for the Smart TV Range...
I got the Lintronics codes from the Lintronic website, The Pronto Hex codes from remotecentral.com. Protocol is claimed to be NecX2.
I'm affraid I don't understand the matter enough to give more information.
Regards,
Joost
Joost,
I have compared the two and I can see that their address is exactly the same. However, the reason it does not work is that the last binary digit is missing from each command of the Pronto HEX commands as you will see below.
The address is the first 16 binary bits after the start bit
Long time ago I produced this *.xml -File for my Samsung UE558790.
maybe that works for you.
