Hi All,
I am trying for the first time to program a second hand BEO6. (my previous BEO6 was stolen & I am trying to replace it without having the expense of calling in the B&O dealer)
I have sourced the Configuration Tool v 6.62, and made up a sample set up to try and load into the BEO6.
When I connect the BEO6, my PC loads drivers successfully, however when I try to upload the file from the Configurator program I get USB errors and the upload fails.
The configurator program is running on a 64 bit version of Windows 7 Enterprise.
The BEO6 is software version 3.00a.
So far I have tried restoring settings, and a hard reset on the BEO6. On the PC, I have tried updating the drivers however I get the response that these are the most up to date drivers. I do not have easy access to a 32 bit PC.
Does anyone have any thoughts as to how to progress? Many thanks
