BEO6 Configuration Tool error on upload
Hi All,
I am trying for the first time to program a second hand BEO6. (my previous BEO6 was stolen & I am trying to replace it without having the expense of calling in the B&O dealer)
I have sourced the Configuration Tool v 6.62, and made up a sample set up to try and load into the BEO6.
When I connect the BEO6, my PC loads drivers successfully, however when I try to upload the file from the Configurator program I get USB errors and the upload fails.
The configurator program is running on a 64 bit version of Windows 7 Enterprise.
The BEO6 is software version 3.00a.
So far I have tried restoring settings, and a hard reset on the BEO6. On the PC, I have tried updating the drivers however I get the response that these are the most up to date drivers. I do not have easy access to a 32 bit PC.
Does anyone have any thoughts as to how to progress? Many thanks
hello, I just wanted to ask you where I can download the latest config. tool for beo6
B&O fan since adolescence. I have a multi room audio-video system with Master Link connection. In 2016 integrated the system with Beosound 5. I'm satisfied 'cause I use it for hours everyday, but sometimes any device need reparation.
Am also looking for a copy of the Beo6 config tool.
Tool:
www.mediafire.com/download/6s2l3qs88zqz9x1/CTSetup_6.84.exe
Hello Frank.
Do you know if the link still exists? Have you used the link yourself virusfree..? Can I contact you i an other forum?
Carsten
beoloverdk wrote:
Hello Frank.
Carsten
Hi Carsten. If you are the one who has sent me a private mail, then I have responded :) If not, then send me one :)
/Jacob
CallmeAll wrote:
Hi All,
Hello,
I believe that you should install the last version of the configurator which is 6.84 and try again. I had a similar problem and it was the size of the pictures of the buttons. They were to big and I used to get an error. I tried with no pictures and everything worked perfectly. I then downloaded the pictures I wanted in smaller sizes and used many of the pictures available in the configurators folder. Hope I helped you
