Beo6 and Sky Q
Hope someone can advise / help
Have a Beo6 and the config tool and have used for a long time to program things up
Always worked great
Just upgraded from the old Sky HD box to Sky Q
Anyone programmed the Beo6 to send commands to Sky Q ?
Do you still need to use the little IR bud to control ?
What stating config did you use and edit to replicate the commands ?
The Sky Q doesn't appear in my config tool settings anywhere
Hope someone can give me some pointers
Regards
Is Sky Q controlled by IR or Bluetooth? Unless it is IR the Beo6 cannot control it.
Stoobie
Exeter,
Devon,
UK
