beo5 confyg.tool fails to load
dear members,
i have installed 3.87 in windows 7 professional.
however, following the log in en marking offline field, the following message is dysplayed:
Loading..........
The programm fails to progress.
Do you have a solution.
Greetings,
Mirralph
Mirralph,
The programme not start in the manner you have described can have many causes.
Is this a new Windows 7 Professional installation or is it being used without problems with many other programmes ?
If it is not a new Windows 7 installation, then it is likely that there is conflict with something else running. The first thing I suggest you do is reboot the windows system and re-install the Configuration Tool without any other programme running and then try again.
These are the symptoms when trying to start the Config tool in a 64bit version of Windows 7 which is (still) not supported by B&O. The easiest workaround is to use the XP Virtual PC options within Windows 7 and install the Config tool within this shell. This works well although it is a little hassle to remember to connect to the BEO5 USB post within the XP emulator.
It does save on having to operate a seperate XP laptop/PC solely for B&O !
//Rolf
Thank you for your help.
My problem is solved
Greetings
