Beo5 Configuration tool 3.0
B&O just released Beo5 Configuration Tool version 3.0 today.
Does anybody know if this version will upgrade the firmware as it happened with the 2.2? I mean, will the third party products stop run with the new software version?
Version 3.0.0.2 updates the firmware to 1.41a
Third party XML files work correctly regardless of Carrier Frequency using 2 or 5 bits
You can review the FAQ
You can review the FAQ link
Thanks! 🙂
What are the new features of this version?
Here are some pictures
