BEO5 configuration software
Hi all,
I will get my Beo5 next week.
It's OK for my dealer to give me a copy of the configuration software, but he don't know how. He have not got a CD or sometime. I guess it's installed from the net. Anyone knows what I shoudl copy from he PC in order to get the configuation software to my PC?
Ken
I do not know how the software is installed, but the easiest for you would be to go there with a USB memory stick.
Will the dealer share his password???
p.
From what I have seen,  the software can be used in an offline mode, thus no need for username and password from your dealer.  Just enter your own made up username and password.
Greg
Yes, I will bring a USB stick with me. But I need to know what to copy. Is it a single program file, is it a specific directory, is it a number of files / dirs?
On this forum it seams that others have got a copy from thier dealer. Maybe they could to what to copy.
Ken
I'll be going to my dealer no later than this afternoon for the same reason.
I still haven't ordered the Beo5 as I am waiting to get the software...
 p.
I suggest you review the beo5 FAQ HERE
It is a stand alone program in what is called msi form which extracts and installs automatically. You don't need a password or log in - but you do have to work off line - allegedly.
Hallo,
how can I receive the BEO5 programming software ? My local dealer points out that it is not possible to distribute the software, because of its connection to a dealer-computer !?!
Can it be downloaded from some other places on the B&O homepage ?
Thanks for the reply !
It is really up to B&O whether they distribute the software. It does not need a connection to the central server to work but I can understand why B&O and the dealers are keen to keep it in store. Unfortunately the best way to program this device is in the home and after trying various formats. I think this will come once the software is more stable. Beoworld cannot be seen to be illegally distributing copyright software I am afraid.
Thank you for the answer. I didn't not expect that Beoworld is distributing software. It was more the question whether the software is available on the official webside or not. As I understand not ! Hopefullly the software is available soon for the users purpose at home ! I will wait patient !
Thanks !
