Beo5 battery
Hi guys,
Is the battery in the Beo5 self replaceable? Mine is almost dead, it only keeps it's charge a few hours. A pity since I really like the Beo5.
Provided you have the correct size splined screw driver and a new replacement battery, you can replace the battery yourself.
Have a look
Is the battery available from elsewhere than B&O?
Possible, but I have never seen them.
The batteries are made by Sanyo NI-MH model # 2HR-4/5AAU and are 2.4 volt
Thanks Keith!
I ordered it from the dealer.
Dealer price was pretty steep at 60 euro, just as a heads up to the rest of you.
Got it today, and is now changed thanks to Keith's instructions. 🤒
Wau, in denmark its cost 30 euro
If you have soldering skills, can try eBay item: 290764725982.
Looks like correct size 4/5AA (original Sanyo spec is here: link)
item 290764725982 Technical specifications
  • Size: 42mm (length) x 14mm (hight) x 28mm (width)
  • Chemistry: NiMh (Nickel Metal Hydride)
  • Output Voltage: 2,4V
  • Amperage: 2x 1200mAh
  • Battery Terminals: Flat terminals, tagged on both ends for soldering
