Beo5 and Thomson SkyHD
What would I need to control my Thomson SkyHD box via the Beo5.
(note: I do not own a B&O TV set)
You can control your Thomson SkyHD box DIRECTLY from the Beo5 provided you have the Beo5 programmed with the associated XML file.
I have successfully programmed the beo5 for the PS3 and the B&O units but do not have the XML for the skybox. Any chance I can download this from somewhere ?
Hi
i need direct control for a sky box as well.
has anyone got this? if not i might have to give it a go with the lintronic...
Louis
Right so i got these codes...
link255255000012000000 0
link255255000012001000 1
link255255000012002000 2
link255255000012003000 3
link255255000012004000 4
link255255000012005000 5
link255255000012006000 6
link255255000012007000 7
link255255000012008000 8
link255255000012009000 9
link255255000012131000 BACKUP
link255255000012112000 BLUE
link255255000012125000 BOXOFFICE
link255255000012033000 CHANDOWN
link255255000012032000 CHANUP
link255255000012089000 DOWN
link255255000012040000 FORWARD
link255255000012110000 GREEN
link255255000012129000 HELP
link255255000012203000 INFO
link255255000012245000 INTERACTIVE
link255255000012090000 LEFT
link255255000012036000 PAUSE
link255255000012062000 PLAY
link255255000012012000 POWER
link255255000012064000 RECORD
link255255000012109000 RED
link255255000012061000 REWIND
link255255000012091000 RIGHT
link255255000012092000 SELECT
link255255000012126000 SERVICES link255255000012128000 SKY
link255255000012063000 STOP
link255255000012060000 TEXT
link255255000012132000 TV
link255255000012204000 TVGUIDE
link255255000012088000 UP
link255255000012111000 YELLOW
What on earth do i do with them now?
