SirCona wrote:
in my oppinion, the audio sources are divided into generell types. For example the BS2300 and the BS2500 aren't listed either but a Bs3000 is listed. So if you choose the BS3000 the BS2300 and BS2500 will work also with this configuration.
So give it a try for the BS 5 instead of the BS 5 encore!
Hi SirCona,
Actually this did not work, as BeoSound 5 is automatically connected to a video source (my BeoVision 10) in the Configuration Tool, and many remote control functions seem to go through TV. As Encore cannot actually be connected to Beovision 10, it needs to be set up as a stand-alone product. This is not possible using Beosound 5 found in the Configuration Tool. I even tried creating a new zone, without a video product, but Beosound 5 insisted on selecting a video product first.
So, I'll need to get my hands on the Encore configuration files for Beo5. If only my computer was portable, I could take it to the dealer and ask for an update, but I have a HTPC.
Thanks for the advice, in any case!
Perhaps someone here at BeoWorld can provide my Configuration Tool with the Encore-related files? Or simply enough zip the entire Configuration Tool folder, send it to me, and I can take the necessary files from there?
Anyone?
