Hi everybody.
Does any one know, if I could use Beo5 with an old Beosystem 7000, or 4500?
And if so, does it support two way communication with it?
I couldn't find any information from the Net.
Beo5 & Beosystem 7000
the Beo5 can replicate any other IR device so you will be able to use it. However, it is not a two-way remote so for that you would need a Beolink 5000 or 7000.
BR
Riven
Ok. Thanks for your advice.
So I better start looking at Beolink 7000. It seems to be very rare and expensive, though.
But that's life...
