Beo5/ Beo 6 Remote Controller software
Hello! Could you please tell me is it possible to find a configuration tool which will help me to program Beo5/ Beo 6 Remote using Windows PC?
this is not the latest software but good for Beo 5
https://www.mediafire.com/download/tjv9oy9agrk0sr2/CTSetup_5.12.exe
good luck
good luck
and here is the latest SW for Beo 6
https://www.mediafire.com/download/6s2l3qs88zqz9x1/CTSetup_6.84.exe
good luck
good luck
Hello BeoZip
I downloaded the program from your link, when I log in the program requires a login and password. Did I do something wrong?
Thank you very much for your quick reply! I hope that I will be able to run the program!
Lot of documentation in BWII including a comprehensive guide from a fellow beoworlder.
Also lot of threads, templates, tips and tricks and also free codes.
Learning to program the remote is not an easy ride but it is very rewarding: Play with it and come back here with specific questions once you're really stuck.
Have fun!
Have fun!
