Hello there;
is there an XML for Yamaha RAV503 for an Yamaha AV Reciever available?
Thanks a lot =)
Great forum here!
Hello there;
Thanks a lot =)
Great forum here!
Here are the lintronic codes....
716122133101026000000
| AUDIO1 | |
| 716122133000127000000 | BD SCENE 1 |
| 716122133000127000000 | BD_DVD |
| 716127001096159000000 | DISPLAY |
| 713122148000000000000 | ENCHANER |
| 713122222000000000000 | ENTER |
| 716122133071056000000 | HDMI 1 |
| 716122133074053000000 | HDMI 2 |
| 716122133077050000000 | HDMI 3 |
| 716122133080047000000 | HDMI 4 |
| 716122133039088000000 | INFO |
| 713122136000000000000 | MOVIE |
| 713122137000000000000 | MUSIC |
| 716127001063192000000 | NET |
| 716122133006121000000 | NET 2 |
| 716122133006121000000 | NET SCENE 3 |
| 713122132000000000000 | ON SCREEN |
| 716122133107020000000 | OPTION |
| 713122158000000000000 | PIL H |
| 713122156000000000000 | PIL NED |
| 713122157000000000000 | PIL OP |
| 713122159000000000000 | PIL V |
| 716122133164219000000 | POP UP MENU |
| 713122030000000000000 | POWER OFF |
| 713122029000000000000 | POWER ON |
| 713126126000000000000 | POWER ON 1 |
| 713122089000000000000 | PROGRAM DOWN |
| 713122088000000000000 | PROGRAM UP |
| 713122221000000000000 | PURE DIRECT |
| 716122133009118000000 | RADIO SCENE4 |
| 713122170000000000000 | RETURN |
| 713122048000000000000 | SLEEP |
| 713122086000000000000 | STRAIGHT |
| 713122141000000000000 | SUR DECODER |
| 716122133160223000000 | TOP MENU |
| 713122022000000000000 | TUNER |
| 716122133003124000000 | TV |
| 716122133003124000000 | TV SCENE 2 |
| 716127001114013000000 | USB |
| 713122027000000000000 | VOL DOWN |
| 713122026000000000000 | VOL UP |
Perhaps it helps?!?
These are all 32 bit NEC protocol codes which are easy to make into a XML file because NEC is one of two protocols support in the firmware of the Beo5/6.
You also sent me an email on the same subject which I will reply too later.
