Beo 5/6 XML for Yamaha AV Reciver
Hello there;
is there an XML for Yamaha RAV503 for an Yamaha AV Reciever available?
Thanks a lot =)
Great forum here!
Here are the lintronic codes....
716122133101026000000
AUDIO1
716122133000127000000 BD SCENE 1
716122133000127000000 BD_DVD
716127001096159000000 DISPLAY
713122148000000000000 ENCHANER
713122222000000000000 ENTER
716122133071056000000 HDMI 1
716122133074053000000 HDMI 2
716122133077050000000 HDMI 3
716122133080047000000 HDMI 4
716122133039088000000 INFO
713122136000000000000 MOVIE
713122137000000000000 MUSIC
716127001063192000000 NET
716122133006121000000 NET 2
716122133006121000000 NET SCENE 3
713122132000000000000 ON SCREEN
716122133107020000000 OPTION
713122158000000000000 PIL H
713122156000000000000 PIL NED
713122157000000000000 PIL OP
713122159000000000000 PIL V
716122133164219000000 POP UP MENU
713122030000000000000 POWER OFF
713122029000000000000 POWER ON
713126126000000000000 POWER ON 1
713122089000000000000 PROGRAM DOWN
713122088000000000000 PROGRAM UP
713122221000000000000 PURE DIRECT
716122133009118000000 RADIO SCENE4
713122170000000000000 RETURN
713122048000000000000 SLEEP
713122086000000000000 STRAIGHT
713122141000000000000 SUR DECODER
716122133160223000000 TOP MENU
713122022000000000000 TUNER
716122133003124000000 TV
716122133003124000000 TV SCENE 2
716127001114013000000 USB
713122027000000000000 VOL DOWN
713122026000000000000 VOL UP
 Perhaps it helps?!?
These are all 32 bit NEC protocol codes which are easy to make into a XML file because NEC is one of two protocols support in the firmware of the Beo5/6.
You also sent me an email on the same subject which I will reply too later.
