Beo 5 and Playstation 3 ??
Hello,
i found the PS3 in the config tool of the Beo 5. Is it possible to control the PS3 with Beo5??? The PS3 is normally controlled via bluetooth and cannot be controlled by IR!! Has anybody the solution for this? If it works this could be a nice blue ray-player for my BV7..
TS
Sould be possible.
http://www.schmartz.com/product.sc?categoryId=1&productId=4
linkStefan
A Playstation 3 can be controlled by a Beo5 provided you have a converter of one type or another.
There is quite a long thread on the subject HERE
