AUX button beosound 3000 on BEO5
Dear forum members,
I own a beosound 3000. With it aux function I can channel a beogram and apple tv.
With the beo4 this function is approached with the ATAPE button.
However I cannot figure out how top programm this with the confyg. tool on the BEO5.
Do you have any suggestions?
The easiest way to enable A.AUX is to click on the the BS3000 on the choose products tab. Then under selected product data you expand modules and then select A.AUX. Now A.AUX should be visible on the source selection page....
