Snow Leopard - Update: BM-Link not 100% compatible. Don't upgrade yet!
I have followed the instructions but I can not distribute music from my mac to the B&O sound system. Beoport ist connect to Beosystem 3. What am I doing wrong?
Hi Marc,  I cna try to help you, or you could email Phillipe directly which is his preference as the LinkPlayer software is still beta.
However it would be helpful if you could you please describe your layout a bit more?
Do you have an Audio Master ? You say "the B&O sound system" but then you mention "Beosystem 3" which I am guessing would be classified as a Video Master.
Is the BeoPort connected via MasterLink to the BeoSystem 3?
Do you have any speakers attached to your Beoport? And does the BeoPort have an IR eye attached?
Did you change the Options settings on any of the components?
Hi Jan,
many thanks for you help but the issue has already been resolved with Philip by email.
Marc
Hi Philondon,
Finally got hold of a PC2 unit, last week ... and downloaded your software.
Took me all evening last night to connect it all up and install and config the software.
After a few hassles (bad cable) and a few changes of the config options it now works with my beosound.
Have not tried the full screen option or extras like plex yet (that will be later this week) but works (so far) flawless with itunes. Impressive.
Thanks so much for this ....
Does this new software replace the old BMLink? After having upgraded to SnowLeopard the BMLink does not work properly anymore. Can I, using this new software, remote control iTunes with my beo4 like I could with BMLink? Where can I find this new piece of interesting software?
kraendavid wrote:
The linkplayer software is written by one of these forums members, PhilLondon and you'll find a link for a trial version on following website http://web.me.com/philrobin/LinkPlayer/Linkplayer.html
Great application I must say. My first impression is that it is even better then the old BMLink written by odlund. However it has major problem: it is only a demo working for 1 hour :(. Is it possible to buy a non-demo version - or is it still to unstable to run for longer periods than that (I haven't had any problems with it).
The software is still in a testing fase, but you can contact the writer (member PhilLondon) directly for more information.
Finally a new version of BM-link has been released to support mac os 10.6 and iTunes 9 and B&O has confirmed.
ibg001 wrote:
B&O has confirmed
Hi, what do you mean by "confirmed"?
Yes, the B&O page links to Anders' updated change log, but then I think it always did.
I could find no update on the B&O Digital Media link I followed to indicate a confirmation by B&O that this was now the latest release that they endorse and support - I assume that is what your "confirmed" means?
