Dear All,
On Friday Apple delivered promptly my Snow Leopard disc 🙂 I first upgraded my MacBook Air with no problems and checked everything out with great satisfaction - definitely faster, very stable and some of the minor tweaks to iPhoto and Expose very good.
So far so good...
Then upgraded my MacMini which runs iTunes and connects via a DACMagic to MasterLink and my B&O home set-up.
All looked good (despite not having control over playlists any longer from Beo4 after upgrading to latest iTunes for my iPhone) the music was coming out beautifully. For a while it worked well then just stopped. Further inspection showed iTunes still playing but BM-Link running but will not accept commands either from OSX Preference Panel or IR eye & Beo4. The only way I found to restart BM-Link was to stop the Server and Script applications via Activity Monitor and then restart BM-Link via Preference Panel.
2 hours later same thing, music just stopped, but iTunes still thinks it's playing and BM-Link (unresponsive but not hung). Followed same process, stopped and restarted BM-Link all okay again.
12 hours later same thing again. 🙁
We've a party on Saturday and as well as a live band I've made lots of play lists for dancing into the night so clearly this random stopping is not a good thing. So today's job is to downgrade back to Leopard via a full re-install of Leopard and restore of files from Time Machine 🙁
So...
If anyone else is upgrading please proceed with this knowledge and test your rig fully for a few hours. I hope this warning helps. Also if you do upgrade I'd be very interested if you get similar symptoms or if it's something in my set-up.
Best
Rob
