Hello Phil
A big thank you also from me ...
I am using LinkPlayer to feed music from my Mac XServe Media Server (via a Cambridge DAC Maginc) to the BS9000, and I am very happy. However, I only use it to serve N.MUSIC and N.RADIO, and I may not be the best of testers, as I am less interested in the local functions, given the server is in the basement of the house.
The only thing I could nag are two features of usability:
1) It would be swell if we could configure Linkplayer on which sources he should present to the user - and which not. For example I have no use for the functions A.MEM and A.AUX, so why offer them as a choice?
2) Given the transparent background of the remote, the red dot display seems hardly readable to me (see screenshot below). It is acceptable however if one uses white dot colour.
May I propose you open a new discussion thread to discuss your work? I (happily) think, that the topic has gone way beyond "Snow Leopard - Update: BM-Link not 100% compatible. Don't upgrade yet!"
Best regards
Stefan
