I have ours set to 12 characters and longer, both options selected. I have not had any failure for some time now. I have to keep turning the program back on after the 1 hour timeout.
Your tests sound much better and more technical than mine.
Finally i could stop the crashes by reprogramming the BeoSound to A.OPT 1 and Linkplayer too. So iTunes reacts on the Beo4 COmmands.
The only thing missing now is sound. The Audio connection between the Mac and PC2 doesn't seem to be triggered appropriate.
When i try with BM-Link i can verify that when N.Music is running and i remove the cable connected to the Headphone Output that if i touch the cable running to PC2 with my fingers i hear a humming noise via the speakers. I don't experience the same behaviour when using LinkPlayer even though iTunes responds and plays. It seems that in my case LinkPlayer doesn't seem to route the Audio to the BeoSOund.
Dear all,
Thanks to the bug reports that I have received from some of you I have identified the two causes of freeze.
One is due to sending messages to the Masterlink too quickly, the other is due to iTunes not responding when I am trying to read the current song title.
The first problem happens more often since I have introduced the song title display as I am sending longer messages on the bus.
I my internal development version, I have already fixed the first cause, and will be working on the other one this week.
I am also aware that compatibility with Leopard (10.5.x) has been broken since 0.5, but I'll try and fix that in the next version as well.
I'd like to know if some of have managed to get song titles diplayed on a Beosound with "Longer display".
If experiencing any other problem than the 2 mentioned here (freeze and leopard compatibility), please report to me by email.
Thanks all for your help.
Philippe
i am interested in being a beta tester. have beolink pc2 attached to a macmini. audiomaster in different room is beosound 3200. i can distribute n.music, and can control itunes (either direct or via frontrow) but i can't listen to audio sources like cd, radio, a.mem via the Mac.
that's because I have been in IT a long time ... I started programming in 1967 !
I am having similar problems, but I don't know if it is the software or the actually Macbook headphone jack - sometime wiggling the cable cures the problem, but other times even when I remove it I dont hear anything through the Macbook speakers - very strange.
I plan to do test in the weekend to try to isolate it.
I will probably find it is my ears that are loose :D
Hmm, I will try that test tonight !
but i can't listen to audio sources like cd, radio, a.mem via the Mac.Hmm, I will try that test tonight !
No problems today with headphone jack connectivity, and so I had a very successful 60 minute test to address violinman's requirements.
I used the LinkPlayer Virtual Remote aka VR (i.e. the screen interface, see below, pardon my desktop in the screen shots!) to:
All in all a very satisfactory result, I will later repeat this type of test sequence using a Beo4 on the BeoPort/LinkPlayer rather than the VR on the MacBook ... and hopefully include devices such as my BeoCord 5000, BeoCord VHS, and the PlayStation itself (or perhaps a "real" DVD player that I have as a spare)
LinkPlayer Virtual Remote (VR) playing BeoSound 4's CD and then its SD Card, and then playing the BeoVion 8's Foxtel/Sky STB
I think Violinman is talking about BMLink, as he has just requested to be a Beta tester, and I have not sent the version yet.
Been very actively working on 0.6 and it will be released this weekend.
Lot's of bug fixes, but surely not all unfortunately, many improvements and a couple of new features.
For those who have not seen it yet, here is the website:
Hey P,
you are doing a great job !]
E :-)
Hey P,
E :-)
cool project! i am happy on the final version.
if you still need some beta tester, let it me know.
