Rumor: Apple to offer iTunes Remote App?
see this link:
http://www.macrumors.com/2008/06/26/apple-to-offer-itunes-remote-control-app-for-iphone-and-ipod-touch/
I'm excited by it.
yes ... i might get me an ipod touch then .... I know I know remote buddy ..... i do not want to fiddle with that though ...
Looking forward to iControl (which is what it's been called in the SDK package). I like using Remote Buddy, but any solution that is embedded in the OS is probably going to outperform that.
In a setup involving Beoport or similar functioning Mac Software, it shouldn't be too much of a stretch to re-introduce 2 way communication (via wifi) - and that would be very cool indeed...even compatibility with IR based 2 way communication is not an impossibility. As a fan of the system, particularly MCPs and the Beolink 7000 this would be a fabulous thing to get working.
Thanks TWG, this is great news!
I converted my BeoPort to run on my Mac rather than a PC running XP and have never looked back. As I also have an iPhone this could be a great combo. Only one thought I assume you'll have to have the WiFi on the iPhone on all the time to make the remote function usable, I wonder what the battery life will be?
I'm looking forward to getting the new iPhone 2.0 AND iTunes 7.7 now...
Best
Rob
i've given up on remote buddy , it's just so unreliable
i'm sitting 3 feet away from my mac pro and half the time it can't detect it
i'm sure apple will come up with something vastly more impressive - as usual
Interesting, Flappo. I've never had any trouble with RB not being detected by the Touch - and I've actually even used it from my downstairs neighbour's flat on one occasion, controlling the media in my flat, when I was demonstrating it. (We could hear the music through the floor - ahem ...)
Are you using a Mac pro station? The wireless antenna on that is quite bad (the detachable, white plastic T antenna). Without that antenna it's even worse.
Sounds like your problem is unrelated to RB, and is due to a connection issue.
As you, I'm looking forwards to the SDK solutions, I've already seen a few and think I'll have a hard time deciding which to go for. And I'm very curious about Apple's iControl.
>>Interesting, Flappo. I've never had any trouble with RB not being detected by the Touch <<
it probably is. I think the apple solution most likely wouldn't address that unless it is using blue tooth or something.
This is actually why I avoid the Wifi solution. I had IR for a while but it had many little hick ups probably caused USB implementation on the early imacs that I gave up on it.
B&O all the way, except the Apple TV which I can run acceptable through Beo 4 and BV8.
I hope they get teh BS5 out before christmas
