Noooo! It's random shutdown syndrome!
Just recently my Black Macbook has started randomly shutting down.  I took it to the Mac shop and they wre recommending a new logic board.  At £400 I don't blame them (they are a business after all) but fromwhat I've read on the internet, that doesn't always fix the problem anyway.
I'm sure that it's in some way temperature related because if it happens, and I turn it on again, it occurs again very quickly.Also, if I type"yes" into the terminal to make the processor go atfull, it causes a shutdown after about 20 seconds.  However,I downloaded a temperature monitor and it indicated fairly low temperatures (about 48 degrees C) so I'm not sure what exactly is wrong
I'm now using my 5 year old "trusty" dell laptop and wondering where to go next. Can anyone recommend anything? If I bought a new machine, it would be an upgrade to a Macbook Pro but at £1300 and Christmas presents to buy for others, I really can't afford it right now
I expect you've probably already done this, but try installing
It's now out of warrenty and apprently the RRS problem only really surfaces on somewhat older equipment anyway.  I've been wondering about perhaps buying a second hand system and replacing the hardrive with my one. Would that work?
I'm in a horrible dilema about it... On one hand I'm furious at Apple because I've effectively paid a lot of money for a system that's now useless, out of warrenty and going to cost £400 to fix (a fix that might not even work). However, on the other hand I couldn't go back to owning a PC with all the visuses, spyware terrible OS and crashing etc.  If anyone happens to be selling a MacbookPro for a decent price, I'd love to take it off their hands
It should work as long as the MacBook you buy is similar to yours. Some of the hardware changed from generation to generation.
As for the MacBook Pro, if/when you can afford it, get it! It'll be one of the best computers you've ever owned. I've had two now, as my first one was a lemon (bought it not long after they had first come out), and I had a million and one problems with it, persisting from a few months after I got it. Apple replaced it with my current one outside of warranty, but only because they admitted that the number of issues I'd had were way beyond what you would expect from a relatively recent computer and that they'd first began before the warranty expired (even though it had already been in for service several times). The one I've got now is absolutely fantastic - best computer I've ever had...
Interestingly recent music press I've read advocate just getting a Macbook as the extra cost of the "Pro" really only buys you extra graphics capabilities (which are unecessary for music making but then maybe you're a Video editor or a graphic artist)
I mentioned it to a friend earlier this evening and he recommended that because nearly all the work I do is in my living room, I should just buy a Mac Mini, hook it up to my AV setup and get a wireless mouseand keyboard.  I half agree with it actually, seeing as it's the same spec as a basic Macbook and I don't really have the use for a laptop now that I once did.  My laptop use was mainly on trains and taking to uni, and even if I go home, I suspect that it's quite easy to pack a Mini in a suitacase and hook it up to a spare computer monitor and mouse lying in the office.
My main concern would be that I use a projector but then if I use a computer for 5 hours per night and a bit ovre over the weekend, that's about 40 hours per week = about 2100 hours per year. At that rate (and because my bulb is 4000 hours) it works out at about a new £200 bulb every two years.  In 5 years (the break eevn cost) I'd have loads of cash and almost certainly be wanting a new system anyway.
As they say, I think I need to think about it over the next few days
I disagree with the "not being worth" it though agrument against the Pro. I think that if you choose to spend £900 (on a Mac) rather than £300 (on a generic PC) then you may as well just spend the extra £400 to get the memory and sheer power.  I agreed with the statement when I first went to get some kit, but then every time I saw a Pro, I would think of the £100 I wasted on a night out and think why did I not just save a bit longer.
Would I expect anything else😁
Are the Macbook and the Macbook Pro you're comparing both current, as similar spec as you can get, models??
BTW - young fellow me lad, you seem to have stopped PM'ing me about your music - I still play your last EP in my car (albeit a lowly Ford Focus without B&O sound system)
How much RAM do you have in the MBP compared to the MB? Just bought a Black MB for my wife with 2Mb of Ram and it seems to fly!
I think thats their point - from a hardware point of view you can buy pretty much the same horsepower for a lot less with a Macbook - with a Macbook Pro you get a larger screen with a higher resolution  - the question being what do you need you notebook for - to do what you need to do or to impress other Macites?
