Hi gk31ax
Which PC to TV converter did you end up buying?
I am thinking of getting a MacMini and use the dual video out-put to connect to both the DVI and Scart (for link rooms) on my BV7-32. Do you think this would be possible?
Thanx
Toby
Hi gk31ax
Thanx
Toby
Toby
Sorry for the delayed response.....
I ended up getting the Laptop/ PC to TV Converter III
Works a treat, but not sure about your question on dual output, in theory it should work...
Cheers
Gary
Hi Toby
Did you end up getting the mac mini and try to do the double connection to link it?
I'm trying to do something similar and don't know if getting the PC to TV converter is the solution.
Luis
Hi Gary
I'm not an expert on this at all, but what still surprises me is that with just one apple cable you convert the video signal from digital (mini-dvi) to analog (vga)...; then, once you have it analog, the pc to tv covnerter does the rest (that, I understand).
L
