Metadata software for Mac
Hi all,
I currently have something around 98Gb of music mostly with all details, however there are several ones that have no information at all.
As I'm not quite familiar with, is there any software that I could download and use in order to get all necessary information for some of my albums?
Many thanks in advance for any tip!
Best regards
Spiros
Anybody some hint!?!!!???!?
Select the songs in iTunes and choose Advance > Get Track names
It works better if you select all the songs of 1 album at the same time and in the correct order.
P.
Already tried it but not very successful.
I saw that there are plenty of software for this reason but which one is the best?
tried a few Mac SW 2yrs ago...back then there was nothing so i installed WM Ware and MediaMonkey on WinXP install - much better for batch meta data management and save it hardocded into the tags of the files......
If u use iTunes for media tagging it only saves it into its own XML so when you add the files to another iTunes or you reinstall iTunes on another computer you will have to redo the tagging.....
i'm sure that the SW has improved/new releases in the last 2yrs......but don't know...
Hi Klas,
Many thanks. Just tried Media Monkey and seems that it is working (at least better than iTunes!!!)
Best regards
Spiros
Some native OS X tools you can look at:
adding meta data including song text:
link
Adding covers from multiple - self definable sources:
link
I use both of them and like them.
They have been on sale previously at MacUpdate as well, so maybe they will return in the future for a reduced price again.
Hi Harry,
Quite interesting. I probably will check it during weekend.
Many thanks for the links.
Best regards
Spiros
Spiros wrote:
Hi Harry, Quite interesting. I probably will check it during weekend. Many thanks for the links. Best regards Spiros
Hi Spiros,
Have you bought the software indeed and what are your experiences with it so far?
Harry
Hi Harry,
Still have not tried anything!!!
I had an issue with my music folders and now have to recover everything.
Most probably will do everything during Christmas holidays.
Best regards
Spiros
