Macbook Pro: Optical Out --> where put in into B&O equipment
Have a Ouverture as audio master and a BV3-32 as video master. The BV has a DTS module with digital input ports. Can I plugin the digital out of the Macbook?
Yes, I see no reason why not. Do you have the correct adapter for the MacBook? The digital output is hidden in the standard headphones connection and you need an adapter to enable it.
Mine was £30, and to my ears it sounds fine! I've only ever used it to connect to my Rotel receiver though, maybe a better DAC would reveal any faults.
Excuse my ignorance but I have just attached a Mac Mini to my Beovision 6-26 with the dolby 5.1 surround sound card.  I am currently using the standard mini jack to phone cable however I believe that if I use a digital output I will get better sound quality?
Firstly I'm not sure which input on the TV will work with the PC input as the only digital  inputs I see are INPUT 1 which is listed as digital input for equipment connected to the AV socket and INPUT 2 - for digital input from equipment connected to the V.TAPE socket?
Then I need to get one of these
Toslink to Coax (S/PDIF) Converter
http://www.svideo.com/toslinkcoax1.html
and
S/PDIF 3 ft.
http://www.svideo.com/spdif3.html
and
Toslink to Coax Adapters are selling for mere 10 Euro at Ebay. You can safely go with a budget version. It just convert the plug type without affecting the sound.
 a good tip regarding converters:
If you have the space for it, go and buy an old DAT- or DCC-Recorder.  Most of them can act as a DA-Converter in Record-Standby-Mode.
This makes sure that you REALY have a high quality signal conversion!
There is no such thing as "high quality" signal conversion in TOS to COAX converters. It is digital-digital. It just changes the way of connection. There is no need to use a bulky recorder for that task that can be done with a 5 euro cigar pack size box. ;-)
Exactly, although you can debate that impedance matching may play a small role in making sure every bit gets through.
