Leopard and BM-Link 1.5
You can easily create your own Apple Scripts and use them with BM-Link and control in basicly any appliction on your Mac with your BEO4.
With a small change to the existing Frontrow script in BM-Link, you can control Frontrow again under Leopard.
Have you made the changes? it would be nice if you could publish/send us the new applescripts...
p.
With iTunes 7.6 (and BM-link 1.5) everything is back to normal, even the YBRG buttons work again.
Maarten
BM-Link version 1.5 starts Front Row using the command 'tell application "Front Row" to activate'.
But this doesn't work for Front Row version 2.x.x. This only works for Front Row version 1.x.x.
You have to write your own script to start Front Row.
For example Beo4VRC does it like this:
tell application "System Events"
tell process “Front Row”
key code 53 using {command down}
end tell
end tell
Not for me :-( Still no luck...
cheers
-tb
Maarten:
Maarten
Great News!!! I will test it this evening ... and sent some feedback
Thomas
It's not work, at all!!! I try everything, restart all Link Devices, Install BM-Link again, update BeoPort ..... Nothing worked.
You are shure that Leopard and BM-Link work together?
Thomas
