Leopard and BM-Link 1.5
Does anyone know whether BM-Link runs on Leopard?  It could make Friday a little stressful if it doesn't.
I have just sent an email to the developper...
It works fine. Installed Leopard last night, everything worked.
Maarten
Excellent.
Thanks.
It works fine except for frontrow for me.
p.
Colored, FF and RW buttons no longer work with N.MUSIC and FrontRow does not work anymore!
Aha, I've never used the FrontRow function and I'm actually happy the color buttons don't work anymore, I always managed to get into a fine mess using them!
N.RADIO works without problems
Still pleased with Leopard, it just feels smoother.
 Maarten
Can anyone test how it works with the new iTunes 7.5 and report back here?
BM-Link check the version of iTunes in order to handle some differences between versions, and it seems like the scripts only handle version numbers with a single decimal (the string "7.5" can be converted to a number, but "7.3.2" can't)
(Still in the US, still no access to my development machine)
I have a Problem with BM-Link 1.5. Leopard and iTunes 7.5. It's did not work. I press N.Musik from the Beo4, nothing happens. I look as well to the BM-Link Website and saw that the actual Firmware Version is 1.3.1, I updated my BeoPort but nothing chance.
Any Idea?
Thomas
