Leopard and BM-Link 1.5
I suggest you contact the developer directly as he may not be reading this forum.
iTunes 7.5 and BM-link do not like eachother! I could not access BM-link in the System Preferences. So, I uninstalled iTunes 7.5 and BM-link and went back to iTunes 7.4.2. and installed BM-link again. Now it works again, with the known limitations already mentioned.
Maarten
He usually answers quickly. Let us know what he says.
P.
I sent him last week a Mail but I did not got any response. Maybe in the next day, I let you know when I get a answer
Thomas
Hi Lely
Where can I download iTunes 7.4.2? I could not find it on Apples support web site.
Regards,
Chris
I used AppZapper to remove iTunes 7.5: link
I downloaded iTunes 7.4.2 from versiontracker.com:
Maarten
are there any new things to mention about this little b&o vs. mac problem?
my family is coming to christmas and i will show them my awsome mac features :D
wish you all merry christmas and a happy new year!
It appears that Leopard with iTunes 7.5 on Intel machines does not like BM-link 1.5.
I'm using Leopard with  iTunes 7.4.2. which, besides the color buttons mentioned in previous posts, is working fine.
Maarten
The versiontracker points to apple who seems to have removed 7.42 - tried to google but can't find - anyone here who can share the 7.42dmg file or knows where to get hold of it?
Thx
Klas
He who search will find......got hold of this link at an apple discussion forum:
Old Mac iTunes versions for download
Hi everybody,
I have a weird problem w/ BM-Link. It used to run on my Leopard iMac (not sure which iTunes version, however). At some point I plugged one of these USB card readers into a spare USB port - which created some havoc on my USB bus (Parallels would freak out, for instance). Some days later I wanted to listen to iTunes music on my B&O - nothing. In the meantime iTunes 7.5 had installed, so I thought I follow the tips here and downgraded - no luck. Still silence on my speaker.
Funny enough, though, when I fire up Parallels and use B&O's own stupid BeoPort software, everything works fine. So it can't be the BeoPC box, it's got to be something on MacOSX - but what? I noticed I can not shut down BM Link - if I click on shut down, it say shuttign down, and that's it - no progress. And BM Link's three processes hang around forever. I can kill (-11) them, though. Anyone have a clue?
cheers
Torsten
