I put a DACmagic inbetween the iMac and the Beoport.
First try was to use the optical cable to connect between iMac and DAC and a Cinch to 3,5jack cable to the Beoport. No Sound. nothing. Th iMac recognises the optical cable in system settings.
Second I used the USB Port to the DAC and then the same cable to Beoport. No Sound, but very silent noise (from the source I was playing). System settings were put to USB.
The Input selector of the DAC was set correctly. The Phase / Filter settings do not change anything.
What is wrong?
New start of BM-Link done - no change.
Thanks for your input.
Heribert
