How can i get the covers into iTunes if i user .wav format ?
Some covers are missing and the software CoverScout dont works with .wav files ? Any ideas ?
Olof, given you mention Coverscout and this is a Mac forum, I assume you are using iTunes for Mac OSX?
If so, doesn't iTunes convert the WAV-formatted files to AAC or MP3?
Anyway, if Coverscout fails to find Cover information, you may try to install the following Apple script:
link
link
Hi Stefan,
the script works, but iTunes doesnt allow me to copy the cover into the file ? :-(
 Kind regards
Jan
Hello Jan
I googled a little bit - it seems WAV does not support artwork:
http://support.apple.com/kb/TA27633?viewlocale=en_US
So you will have to decide if you listen to these tracks without artwork or if you convert the file to e.g. AAC and add the artwork then.
Kind regards
Stefan
