Some covers are missing and the software CoverScout dont works with .wav files ? Any ideas ?
How can i get the covers into iTunes if i user .wav format ?
Hi Stefan,
the script works, but iTunes doesnt allow me to copy the cover into the file ? :-(
Kind regards
Jan
Hello Jan
I googled a little bit - it seems WAV does not support artwork:
http://support.apple.com/kb/TA27633?viewlocale=en_US
So you will have to decide if you listen to these tracks without artwork or if you convert the file to e.g. AAC and add the artwork then.
Kind regards
Stefan
