Hi
Better late than never is a phrase users of BM-Link should be way too familiar with by now.
Anyway... a new version is available for download at the usual place:
Hi
Many thanks Anders for the work and the post.
I will download and use it once the sun has risen!
many thanks anders! it´s working perfect!
I'm pretty sure perfect is a bit too good of a review, beta testers have reported that the application still locks up every now and then, but at least it works to some extent :)
Hi Anders,
is the firmware in the package necessary to make the BeoPort work with this update ?
Ed~2
It shouldn't be, it's the same firmware that's been on the disk image for the last couple of releases
/A
Great - thank you !
I just did not want to unnecessarily "disturb" my set-up.
Tesing of BM-Link:
I have not tested any special keys (other than ^ and v) on the Beo4.
I forgot, there are no special keys to test :(
I ran the new BM-Link for 8 hours without any issues or problems.
I also used its Net-Radio function.
Today I will experiment some more with the Net-Radio, and also try out the FrontRow option.
As promised, I tested Net-Radio and it worked fine once I actually connected the internet (*doh*)
The BeoSound 4 displayed the details of each of the stations I "tuned" into
I also tested FrontRow, smoothly invoked, and operated.
My conclusion would be that if all you wanted was music stored in iTunes, then BM-Link is once again a contender; however is you want diversity of video materials then LinkPlayer is the contender.
However I do say I would do some comparisons with the latest beta of LinkPlayer and this is what I can report:
