After a couple years in the closet following a move, I've finally got my BeoLink PC2 up and running again. Whoo-Hoo!!! 🤩
I've noticed that the >> and << keys do not always work. Most of the time, they skip ahead/back to the next group as designed. However, for some areas within the iTunes library, the command is either ignored or triggers a "fast forward". For example, if I'm skipping around by artist, certain artists will not skip forward/back. Once I navigate via single song forward/back (up/down arrow) out of the artist, it works again. I tried deleting the bad artist from the library, but that just moved problem up. I also tried deleting the following artist (maybe it having a problem "getting next artist" - so it's actually the "next artist" that is bad), but the problem persisted. Re-adding the "bad" music returned the problem to the same artist.
My assumption is that I have some corruption in my iTunes meta-data... since the weird behavior seems dependent on what song iTunes is playing. I haven't yet found any rhyme or reason behind the artists that work vs. those that work, but I vaguely remember running into an issue some time ago where iTunes-Lame was not working correctly with certain versions of iTunes, and my theory is that this has in some way corrupted my library.
I've done a little reasearch and found that iTunes has both binary and xml metadata. Does anybody know if BM-Link uses the xml or binary metadata? Digging further, does anybody know the applescript call that (I assume) BM-Link uses to navigate to the next group (let's say, for example, artist)... my thought is may be expedient to write some kind of test script to help diagnose this...
I'm using iTunes 4.6.2 and BM-Link 1.50.1.
Thanks,
Stan
