BM-link and iTunes 8
Do they play well together?
Works perfectly in my set up. I do use an iPod as a remote though but the Beo4 works as it should.
Including the Digit keys, N.Radio, Colour keys?
No problems.
But I use the old Beoport software version.
The Genius feature has made me use N.Music again after neglecting it for ages.
Coolskin,
I think you're using same setup as I am. Could you please confirm the versions :
- "old" PPC macmini
- beoport - firmware?
- BM-link - version?
Your post sounds promising. I gave up updating versions ages ago facing all sorts of problems each time I tried touching anything.
Thank you
Yes, first edition Mac Mini PowerPC non-IR version.
BM-link version 1.0.1
Beoport firmware version 1.18
Beoport firmware is the latest I believe. I tried to upload the 1.5 software version. At first it worked, but after some time (approx. 2 hours) the connection failed. So I uninstalled this version. And reinstalled the 1.0 version. The firmware didn't change back, and stayed the same (1.18)
Check the internet links below the answer I gave by PM
