{"name":"BeoWorld Forum","description":"Everything Bang &amp; Olufsen","url":"https:\/\/forum.beoworld.org","home":"https:\/\/forum.beoworld.org","gmt_offset":1,"timezone_string":"Europe\/London","page_for_posts":0,"page_on_front":30260,"show_on_front":"page","namespaces":["oembed\/1.0","akismet\/v1","mcare\/v1","wc\/v3","wc\/v1","wc\/pos\/v1\/catalog","yoast\/v1","elementor-one\/v1","jetpack\/v4","elementor\/v1","elementor-pro\/v1","filebird\/v1","filebird\/public\/v1","wc-admin","wc-analytics","wc\/store","wc\/store\/v1","wc\/private","wp-rocket\/v1","solidwp-mail\/v1","solid-mail\/v1","wpstg\/v1","wc\/v2","google-site-kit\/v1","ajax-search-lite","elementor\/v1\/documents","elementor-ai\/v1","elementor\/v1\/feedback","wc-admin-email","wc-telemetry","wccom-site\/v3","import-users-from-csv-with-meta\/v1","front-end-pm\/v1","wp-abilities\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/forum.beoworld.org\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"The URL of the resource for which to fetch oEmbed data.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"The URL of the resource for which to fetch oEmbed data.","type":"string","format":"uri","required":true},"format":{"description":"The oEmbed format to use.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"The maximum width of the embed frame in pixels.","type":"integer","default":600,"required":false},"maxheight":{"description":"The maximum height of the embed frame in pixels.","type":"integer","required":false},"discover":{"description":"Whether to perform an oEmbed discovery request for unsanctioned providers.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/oembed\/1.0\/proxy"}]}},"\/akismet\/v1":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"akismet\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/akismet\/v1"}]}},"\/akismet\/v1\/key":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"A 12-character Akismet API key. Available at akismet.com\/account","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/akismet\/v1\/key"}]}},"\/akismet\/v1\/settings":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"akismet_strictness":{"type":"boolean","description":"If true, Akismet will automatically discard the worst spam automatically rather than putting it in the spam folder.","required":false},"akismet_show_user_comments_approved":{"type":"boolean","description":"If true, show the number of approved comments beside each comment author in the comments list page.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/akismet\/v1\/settings"}]}},"\/akismet\/v1\/stats":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"type":"string","description":"The time period for which to retrieve stats. Options: 60-days, 6-months, all","default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/akismet\/v1\/stats"}]}},"\/akismet\/v1\/stats\/(?P<interval>[\\w+])":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"description":"The time period for which to retrieve stats. Options: 60-days, 6-months, all","type":"string","required":false}}}]},"\/akismet\/v1\/alert":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"key":{"type":"string","description":"A 12-character Akismet API key. Available at akismet.com\/account","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"A 12-character Akismet API key. Available at akismet.com\/account","required":false}}},{"methods":["DELETE"],"args":{"key":{"type":"string","description":"A 12-character Akismet API key. Available at akismet.com\/account","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/akismet\/v1\/alert"}]}},"\/akismet\/v1\/webhook":{"namespace":"akismet\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/akismet\/v1\/webhook"}]}},"\/mcare\/v1":{"namespace":"mcare\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mcare\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/mcare\/v1"}]}},"\/mcare\/v1\/paginate":{"namespace":"mcare\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"function_name":{"required":true},"paged":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/mcare\/v1\/paginate"}]}},"\/wc\/v3":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3"}]}},"\/wc\/v3\/marketplace\/featured":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/featured"}]}},"\/wc\/v1":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1"}]}},"\/wc\/v1\/marketplace\/product-preview":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/marketplace\/product-preview"}]}},"\/wc\/v3\/marketplace\/refresh":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/refresh"}]}},"\/wc\/v3\/marketplace\/subscriptions":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/subscriptions"}]}},"\/wc\/v3\/marketplace\/subscriptions\/connect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/connect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate-plugin":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate-plugin"}]}},"\/wc\/v3\/marketplace\/subscriptions\/disconnect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/disconnect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate"}]}},"\/wc\/v3\/marketplace\/subscriptions\/install-url":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/subscriptions\/install-url"}]}},"\/wc\/v3\/marketplace\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/marketplace\/create-order"}]}},"\/wc\/pos\/v1\/catalog":{"namespace":"wc\/pos\/v1\/catalog","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/pos\/v1\/catalog","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/pos\/v1\/catalog"}]}},"\/wc\/pos\/v1\/catalog\/create":{"namespace":"wc\/pos\/v1\/catalog","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"force":{"type":"boolean","default":false,"description":"Force regeneration of the feed. NOOP if generation is in progress.","required":false},"_product_fields":{"type":"string","description":"Comma-separated list of fields to include for non-variable products.","required":false},"_variation_fields":{"type":"string","description":"Comma-separated list of fields to include for variations.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/pos\/v1\/catalog\/create"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}},{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}},{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}},{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}},{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}},{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/site_kit_manage_consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/site_kit_manage_consent"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/time_based_seo_metrics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"limit":{"type":"int","default":5,"required":false},"options":{"type":"object","properties":{"widget":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/time_based_seo_metrics"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"cornerstone":{"required":true},"orphaned":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/yoast\/v1\/ai\/optimize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"assessment":{"type":"string","enum":["seo-keyphrase-introduction","seo-keyphrase-density","seo-keyphrase-distribution","seo-keyphrase-subheadings","read-sentence-length","read-paragraph-length"],"description":"The assessment.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false},"synonyms":{"type":"string","description":"The synonyms for the focus keyphrase.","required":false},"editor":{"type":"string","enum":["Classic","Gutenberg"],"description":"The editor type, either Classic or Gutenberg.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai\/optimize"}]}},"\/yoast\/v1\/ai\/summarize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for a summary.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/ai\/summarize"}]}},"\/yoast\/v1\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prominent_words":{"type":"object","description":"Stems of prominent words and their term frequencies we want link suggestions based on","required":true},"object_id":{"type":"integer","description":"The object id of the current indexable.","required":true},"object_type":{"type":"string","description":"The object type of the current indexable.","required":true},"limit":{"default":5,"type":"integer","description":"The maximum number of link suggestions to retrieve","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/link_suggestions"}]}},"\/yoast\/v1\/prominent_words\/get_content":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/prominent_words\/get_content"}]}},"\/yoast\/v1\/prominent_words\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/prominent_words\/complete"}]}},"\/yoast\/v1\/prominent_words\/save":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","items":{"type":"object","properties":{"object_id":{"type":"number","required":true},"prominent_words":{"type":"object","required":false}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/prominent_words\/save"}]}},"\/yoast\/v1\/workouts\/noindex":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts\/noindex"}]}},"\/yoast\/v1\/workouts\/remove_redirect":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true},"permalink":{"type":"string","required":true},"redirect_url":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts\/remove_redirect"}]}},"\/yoast\/v1\/workouts\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"indexableId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts\/link_suggestions"}]}},"\/yoast\/v1\/workouts\/last_updated":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts\/last_updated"}]}},"\/yoast\/v1\/workouts\/cornerstone_data":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts\/cornerstone_data"}]}},"\/yoast\/v1\/workouts\/enable_cornerstone":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/workouts\/enable_cornerstone"}]}},"\/elementor-one\/v1":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-one\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1"}]}},"\/elementor-one\/v1\/connect\/authorize":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/connect\/authorize"}]}},"\/elementor-one\/v1\/connect\/disconnect":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/connect\/disconnect"}]}},"\/elementor-one\/v1\/connect\/switch-domain":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/connect\/switch-domain"}]}},"\/elementor-one\/v1\/connect\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/connect\/deactivate"}]}},"\/elementor-one\/v1\/top-bar\/notifications":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"app_name":{"type":"string","required":true},"app_version":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/top-bar\/notifications"}]}},"\/elementor-one\/v1\/top-bar\/feedback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product":{"type":"string","required":true},"subject":{"type":"string","required":true},"title":{"type":"string","required":true},"description":{"type":"string","required":true},"countryCode":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/top-bar\/feedback"}]}},"\/elementor-one\/v1\/themes":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The theme activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/themes"}]}},"\/elementor-one\/v1\/themes\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true}}}]},"\/elementor-one\/v1\/plugins":{"namespace":"elementor-one\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"status":{"description":"Limits results to plugins with the given status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/plugins"}]}},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/upgrade":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["active"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/run":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true},"force":{"type":"boolean","default":true,"description":"Force migration even if the plugin is already connected.","required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/rollback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true}}}]},"\/elementor-one\/v1\/settings":{"namespace":"elementor-one\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-one\/v1\/settings"}]}},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Prefix to add before the stats identifiers.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/site-editor":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/site-editor"}]}},"\/elementor\/v1\/site-editor\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/site-editor\/templates"}]}},"\/elementor\/v1\/site-editor\/templates\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}}]},"\/elementor\/v1\/site-editor\/conditions-config":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/site-editor\/conditions-config"}]}},"\/elementor\/v1\/site-editor\/templates-conditions\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}}]},"\/elementor\/v1\/site-editor\/templates-conditions-conflicts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/site-editor\/templates-conditions-conflicts"}]}},"\/elementor-pro\/v1":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-pro\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1"}]}},"\/elementor-pro\/v1\/license\/tier-features":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1\/license\/tier-features"}]}},"\/elementor-pro\/v1\/license\/get-license-status":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1\/license\/get-license-status"}]}},"\/filebird\/v1":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"filebird\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1"}]}},"\/filebird\/v1\/license-old-site":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/license-old-site"}]}},"\/filebird\/v1\/fb-get-old-data":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/fb-get-old-data"}]}},"\/filebird\/v1\/fb-insert-old-data":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/fb-insert-old-data"}]}},"\/filebird\/v1\/fb-wipe-old-data":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/fb-wipe-old-data"}]}},"\/filebird\/v1\/fb-wipe-clear-all-data":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/fb-wipe-clear-all-data"}]}},"\/filebird\/v1\/fb-no-thanks":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/fb-no-thanks"}]}},"\/filebird\/v1\/get-folders":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/get-folders"}]}},"\/filebird\/v1\/gutenberg-get-folders":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/gutenberg-get-folders"}]}},"\/filebird\/v1\/new-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/new-folder"}]}},"\/filebird\/v1\/update-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/update-folder"}]}},"\/filebird\/v1\/update-folder-color":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/update-folder-color"}]}},"\/filebird\/v1\/update-folder-ord":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/update-folder-ord"}]}},"\/filebird\/v1\/delete-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/delete-folder"}]}},"\/filebird\/v1\/assign-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/assign-folder"}]}},"\/filebird\/v1\/set-folder-counter":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/set-folder-counter"}]}},"\/filebird\/v1\/generate-attachment-size":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/generate-attachment-size"}]}},"\/filebird\/v1\/duplicate-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/duplicate-folder"}]}},"\/filebird\/v1\/fbv-api":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/fbv-api"}]}},"\/filebird\/public\/v1":{"namespace":"filebird\/public\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"filebird\/public\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/public\/v1"}]}},"\/filebird\/public\/v1\/folders":{"namespace":"filebird\/public\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/public\/v1\/folders"}]}},"\/filebird\/public\/v1\/folder":{"namespace":"filebird\/public\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/public\/v1\/folder"}]}},"\/filebird\/public\/v1\/folder\/set-attachment":{"namespace":"filebird\/public\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/public\/v1\/folder\/set-attachment"}]}},"\/filebird\/public\/v1\/attachment-id":{"namespace":"filebird\/public\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/public\/v1\/attachment-id"}]}},"\/filebird\/public\/v1\/attachment-count":{"namespace":"filebird\/public\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/public\/v1\/attachment-count"}]}},"\/filebird\/v1\/set-settings":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/set-settings"}]}},"\/filebird\/v1\/set-user-settings":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/set-user-settings"}]}},"\/filebird\/v1\/export-csv":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/export-csv"}]}},"\/filebird\/v1\/import-csv":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/import-csv"}]}},"\/filebird\/v1\/import-csv-detail":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/import-csv-detail"}]}},"\/filebird\/v1\/pt-import":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-import"}]}},"\/filebird\/v1\/pt-import-run":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-import-run"}]}},"\/filebird\/v1\/pt-folders":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-folders"}]}},"\/filebird\/v1\/pt-new-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-new-folder"}]}},"\/filebird\/v1\/pt-edit-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-edit-folder"}]}},"\/filebird\/v1\/pt-update-tree":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-update-tree"}]}},"\/filebird\/v1\/pt-delete-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-delete-folder"}]}},"\/filebird\/v1\/pt-set-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-set-folder"}]}},"\/filebird\/v1\/pt-set-folder-color":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-set-folder-color"}]}},"\/filebird\/v1\/pt-set-setting":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-set-setting"}]}},"\/filebird\/v1\/pt-folder-counter":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-folder-counter"}]}},"\/filebird\/v1\/pt-duplicate-folder":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/pt-duplicate-folder"}]}},"\/filebird\/v1\/import\/get-folders\/(?P<prefix>[a-zA-Z]+)":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/filebird\/v1\/import\/get-attachments\/(?P<prefix>[a-zA-Z]+)":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/filebird\/v1\/get-backup-files":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/get-backup-files"}]}},"\/filebird\/v1\/download-backup":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/download-backup"}]}},"\/filebird\/v1\/backup-now":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/backup-now"}]}},"\/filebird\/v1\/import\/run\/(?P<prefix>[a-zA-Z]+)":{"namespace":"filebird\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/filebird\/v1\/gutenberg-get-images":{"namespace":"filebird\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/filebird\/v1\/gutenberg-get-images"}]}},"\/wc-admin":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin"}]}},"\/wc-admin\/notice\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/notice\/dismiss"}]}},"\/wc-admin\/features":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/features"}]}},"\/wc-admin\/experiments\/assignment":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/experiments\/assignment"}]}},"\/wc-admin\/marketing\/recommended":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/recommended"}]}},"\/wc-admin\/marketing\/knowledge-base":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/knowledge-base"}]}},"\/wc-admin\/marketing\/misc-recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/misc-recommendations"}]}},"\/wc-admin\/marketing\/overview\/activate-plugin":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/overview\/activate-plugin"}]}},"\/wc-admin\/marketing\/overview\/installed-plugins":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/overview\/installed-plugins"}]}},"\/wc-admin\/marketing\/recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","enum":["channels","extensions"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/recommendations"}]}},"\/wc-admin\/marketing\/channels":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/channels"}]}},"\/wc-admin\/marketing\/campaigns":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/campaigns"}]}},"\/wc-admin\/marketing\/campaign-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/marketing\/campaign-types"}]}},"\/wc-admin\/options":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/options"}]}},"\/wc-admin\/legacy-settings":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"schema":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/legacy-settings"}]}},"\/wc-admin\/payment-gateway-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Return the default payment suggestions when woocommerce_show_marketplace_suggestions and woocommerce_setting_payments_recommendations_hidden options are set to no","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/payment-gateway-suggestions"}]}},"\/wc-admin\/payment-gateway-suggestions\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/payment-gateway-suggestions\/dismiss"}]}},"\/wc-admin\/themes":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"pluginzip":{"description":"A zip file of the theme to be uploaded.","type":"file","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/themes"}]}},"\/wc-admin\/plugins\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/install"}]}},"\/wc-admin\/plugins\/install\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/install\/status"}]}},"\/wc-admin\/plugins\/install\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-admin\/plugins\/active":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/active"}]}},"\/wc-admin\/plugins\/installed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/installed"}]}},"\/wc-admin\/plugins\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/activate"}]}},"\/wc-admin\/plugins\/activate\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/activate\/status"}]}},"\/wc-admin\/plugins\/activate\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-admin\/plugins\/connect-jetpack":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/connect-jetpack"}]}},"\/wc-admin\/plugins\/request-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/request-wccom-connect"}]}},"\/wc-admin\/plugins\/finish-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/finish-wccom-connect"}]}},"\/wc-admin\/plugins\/connect-wcpay":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/connect-wcpay"}]}},"\/wc-admin\/plugins\/connect-square":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/plugins\/connect-square"}]}},"\/wc-admin\/onboarding\/free-extensions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/free-extensions"}]}},"\/wc-admin\/onboarding\/product-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/product-types"}]}},"\/wc-admin\/onboarding\/profile":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"completed":{"type":"boolean","description":"Whether or not the profile was completed.","required":false},"skipped":{"type":"boolean","description":"Whether or not the profile was skipped.","required":false},"industry":{"type":"array","description":"Industry.","items":{"type":"string"},"required":false},"business_extensions":{"type":"array","description":"Extra business extensions to install.","items":{"type":"string"},"required":false},"is_agree_marketing":{"type":"boolean","description":"Whether or not this store agreed to receiving marketing contents from WooCommerce.com.","required":false},"store_email":{"type":"string","description":"Store email address.","required":false},"is_store_country_set":{"type":"boolean","description":"Whether or not this store country is set via onboarding profiler.","required":false},"is_plugins_page_skipped":{"type":"boolean","description":"Whether or not plugins step in core profiler was skipped.","required":false},"business_choice":{"type":"string","description":"Business choice.","required":false},"selling_online_answer":{"type":"string","description":"Selling online answer.","required":false},"selling_platforms":{"type":["array","null"],"description":"Selling platforms.","items":{"type":["string","null"]},"required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/profile"}]}},"\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill"}]}},"\/wc-admin\/onboarding\/profile\/progress":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/profile\/progress"}]}},"\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","description":"The Core Profiler step to mark as complete.","enum":["intro-opt-in","skip-guided-setup","user-profile","business-info","plugins","intro-builder","skip-guided-setup"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete"}]}},"\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"description":"Country code.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units"}]}},"\/wc-admin\/onboarding\/tasks\/import_sample_products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/tasks\/import_sample_products"}]}},"\/wc-admin\/onboarding\/tasks\/create_homepage":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/tasks\/create_homepage"}]}},"\/wc-admin\/onboarding\/tasks\/create_product_from_template":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template_name":{"type":"string","description":"Product template name.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/tasks\/create_product_from_template"}]}},"\/wc-admin\/onboarding\/tasks":{"namespace":"wc-admin","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"ids":{"description":"Optional parameter to get only specific task lists by ID.","type":"array","items":{"enum":[],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"ids":{"description":"Optional parameter to get only specific task lists by ID.","type":"array","items":{"enum":[],"type":"string"},"required":false},"extended_tasks":{"description":"List of extended deprecated tasks from the client-side filter.","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/tasks"}]}},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/unhide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_-]+)\/snooze":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"duration":{"description":"Time period to snooze the task.","type":"string","required":false},"task_list_id":{"description":"Optional parameter to query specific task list.","type":"string","required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/action":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_snooze":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/onboarding\/themes\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/themes\/install"}]}},"\/wc-admin\/onboarding\/themes\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/themes\/activate"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate-async":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"description":"A list of plugins to install","type":"array","items":"string","required":true},"source":{"description":"The source of the request","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate-async"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate"}]}},"\/wc-admin\/onboarding\/plugins\/scheduled-installs\/(?P<job_id>\\w+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"The URL to redirect to after authorization","type":"string","required":true},"from":{"description":"from value for the jetpack authorization page","type":"string","default":"woocommerce-onboarding","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url"}]}},"\/wc-admin\/onboarding\/products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/onboarding\/products"}]}},"\/wc-admin\/mobile-app\/send-magic-link":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/mobile-app\/send-magic-link"}]}},"\/wc-admin\/mobile-app":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/mobile-app"}]}},"\/wc-admin\/shipping-partner-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Return the default shipping partner suggestions when woocommerce_show_marketplace_suggestions option is set to no","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/shipping-partner-suggestions"}]}},"\/wc-analytics":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-analytics","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics"}]}},"\/wc-analytics\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"registered_before":{"description":"Limit response to objects registered before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limit response to objects registered after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limit response to objects with a customer field containing the search term. Searches the field provided by 'searchby'.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limit response to objects with specific names.","type":"string","required":false},"name_excludes":{"description":"Limit response to objects excluding specific names.","type":"string","required":false},"username_includes":{"description":"Limit response to objects with specific usernames.","type":"string","required":false},"username_excludes":{"description":"Limit response to objects excluding specific usernames.","type":"string","required":false},"email_includes":{"description":"Limit response to objects including emails.","type":"string","required":false},"email_excludes":{"description":"Limit response to objects excluding emails.","type":"string","required":false},"country_includes":{"description":"Limit response to objects with specific countries.","type":"string","required":false},"country_excludes":{"description":"Limit response to objects excluding specific countries.","type":"string","required":false},"last_active_before":{"description":"Limit response to objects last active before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limit response to objects last active after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limit response to objects with an order count greater than or equal to given integer.","type":"integer","required":false},"orders_count_max":{"description":"Limit response to objects with an order count less than or equal to given integer.","type":"integer","required":false},"orders_count_between":{"description":"Limit response to objects with an order count between two given integers.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limit response to objects with a total order spend greater than or equal to given number.","type":"number","required":false},"total_spend_max":{"description":"Limit response to objects with a total order spend less than or equal to given number.","type":"number","required":false},"total_spend_between":{"description":"Limit response to objects with a total order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limit response to objects with an average order spend greater than or equal to given number.","type":"number","required":false},"avg_order_value_max":{"description":"Limit response to objects with an average order spend less than or equal to a given number.","type":"number","required":false},"avg_order_value_between":{"description":"Limit response to objects with an average order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limit response to objects with last order before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limit response to objects with last order after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"users":{"description":"Limit result to items with specified user IDs.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filter out results where any of the passed fields are empty","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limit result to items with specified user type.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Includes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"location_excludes":{"description":"Excludes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"include":{"description":"Limit result to items with specified customer IDs.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/customers"}]}},"\/wc-analytics\/customers\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"registered_before":{"description":"Limit response to objects registered before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limit response to objects registered after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limit response to objects with a customer field containing the search term. Searches the field provided by 'searchby'.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limit response to objects with specific names.","type":"string","required":false},"name_excludes":{"description":"Limit response to objects excluding specific names.","type":"string","required":false},"username_includes":{"description":"Limit response to objects with specific usernames.","type":"string","required":false},"username_excludes":{"description":"Limit response to objects excluding specific usernames.","type":"string","required":false},"email_includes":{"description":"Limit response to objects including emails.","type":"string","required":false},"email_excludes":{"description":"Limit response to objects excluding emails.","type":"string","required":false},"country_includes":{"description":"Limit response to objects with specific countries.","type":"string","required":false},"country_excludes":{"description":"Limit response to objects excluding specific countries.","type":"string","required":false},"last_active_before":{"description":"Limit response to objects last active before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limit response to objects last active after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limit response to objects with an order count greater than or equal to given integer.","type":"integer","required":false},"orders_count_max":{"description":"Limit response to objects with an order count less than or equal to given integer.","type":"integer","required":false},"orders_count_between":{"description":"Limit response to objects with an order count between two given integers.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limit response to objects with a total order spend greater than or equal to given number.","type":"number","required":false},"total_spend_max":{"description":"Limit response to objects with a total order spend less than or equal to given number.","type":"number","required":false},"total_spend_between":{"description":"Limit response to objects with a total order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limit response to objects with an average order spend greater than or equal to given number.","type":"number","required":false},"avg_order_value_max":{"description":"Limit response to objects with an average order spend less than or equal to a given number.","type":"number","required":false},"avg_order_value_between":{"description":"Limit response to objects with an average order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limit response to objects with last order before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limit response to objects with last order after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"users":{"description":"Limit result to items with specified user IDs.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filter out results where any of the passed fields are empty","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limit result to items with specified user type.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Includes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"location_excludes":{"description":"Excludes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"include":{"description":"Limit result to items with specified customer IDs.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wc-analytics\/leaderboards":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"URL query to persist across links.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/leaderboards"}]}},"\/wc-analytics\/leaderboards\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/leaderboards\/allowed"}]}},"\/wc-analytics\/leaderboards\/(?P<leaderboard>\\w+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"leaderboard":{"type":"string","enum":["customers","coupons","categories","products"],"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"URL query to persist across links.","type":"string","required":false}}}]},"\/wc-analytics\/reports":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports"}]}},"\/wc-analytics\/reports\/import":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"days":{"description":"Number of days to import.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"Skip importing existing order data.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/import"}]}},"\/wc-analytics\/reports\/import\/cancel":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/import\/cancel"}]}},"\/wc-analytics\/reports\/import\/delete":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/import\/delete"}]}},"\/wc-analytics\/reports\/import\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/import\/status"}]}},"\/wc-analytics\/reports\/import\/totals":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"days":{"description":"Number of days to import.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"Skip importing existing order data.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/import\/totals"}]}},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"report_args":{"description":"Parameters to pass on to the exported report.","type":"object","required":false},"email":{"description":"When true, email a link to download the export to the requesting user.","type":"boolean","required":false}}}]},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export\/(?P<export_id>[a-z0-9]+)\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wc-analytics\/reports\/products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","product_name","variations","sku"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"categories":{"description":"Limit result to items from the specified categories.","type":"array","items":{"type":"integer"},"required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"products":{"description":"Limit result to items with specified product IDs.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Add additional piece of info about each product to the report.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/products"}]}},"\/wc-analytics\/reports\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","sku"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limit result set to items that have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Limit result to items with specified variation IDs.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Add additional piece of info about each variation to the report.","type":"boolean","default":false,"required":false},"attribute_is":{"description":"Limit result set to variations that include the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to variations that don't include the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"category_includes":{"description":"Limit result set to variations in the specified categories.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limit result set to variations not in the specified categories.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Limit result to items with specified product IDs.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/variations"}]}},"\/wc-analytics\/reports\/products\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Limit stats fields to the specified items.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"categories":{"description":"Limit result to items from the specified categories.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Limit result to items with specified product IDs.","type":"array","items":{"type":"integer"},"required":false},"variations":{"description":"Limit result to items with specified variation IDs.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segment the response by additional constraint.","type":"string","enum":["product","category","variation"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/products\/stats"}]}},"\/wc-analytics\/reports\/variations\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Limit stats fields to the specified items.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"category_includes":{"description":"Limit result to items from the specified categories.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limit result set to variations not in the specified categories.","type":"array","items":{"type":"integer"},"required":false},"product_includes":{"description":"Limit result set to items that have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Limit result to items with specified variation IDs.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segment the response by additional constraint.","type":"string","enum":["product","category","variation"],"required":false},"attribute_is":{"description":"Limit result set to orders that include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to orders that don't include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/variations\/stats"}]}},"\/wc-analytics\/reports\/revenue\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","total_sales","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold","gross_sales"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"segmentby":{"description":"Segment the response by additional constraint.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false},"date_type":{"description":"Override the \"woocommerce_date_type\" option that is used for the database date field considered for revenue reports.","type":"string","enum":["date_paid","date_created","date_completed"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/revenue\/stats"}]}},"\/wc-analytics\/reports\/orders":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","num_items_sold","net_total"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"product_includes":{"description":"Limit result set to items that have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limit result set to items that have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limit result set to items that don't have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Limit result set to items that have the specified coupon(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Limit result set to items that don't have the specified coupon(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Limit result set to items that have the specified tax rate(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Limit result set to items that don't have the specified tax rate(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status_is":{"description":"Limit result set to items that have the specified order status.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limit result set to items that don't have the specified order status.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"customer_type":{"description":"Limit result set to returning or new customers.","type":"string","default":"","enum":["","returning","new"],"required":false},"refunds":{"description":"Limit result set to specific types of refunds.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"extended_info":{"description":"Add additional piece of info about each coupon to the report.","type":"boolean","default":false,"required":false},"order_includes":{"description":"Limit result set to items that have the specified order IDs.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limit result set to items that don't have the specified order IDs.","type":"array","items":{"type":"integer"},"required":false},"attribute_is":{"description":"Limit result set to orders that include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to orders that don't include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/orders"}]}},"\/wc-analytics\/reports\/orders\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","net_revenue","orders_count","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"status_is":{"description":"Limit result set to items that have the specified order status.","type":"array","default":null,"items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limit result set to items that don't have the specified order status.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"product_includes":{"description":"Limit result set to items that have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limit result set to items that have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limit result set to items that don't have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Limit result set to items that have the specified coupon(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Limit result set to items that don't have the specified coupon(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Limit result set to items that have the specified tax rate(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Limit result set to items that don't have the specified tax rate(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"customer":{"description":"Alias for customer_type (deprecated).","type":"string","enum":["new","returning"],"required":false},"customer_type":{"description":"Limit result set to orders that have the specified customer_type","type":"string","enum":["new","returning"],"required":false},"refunds":{"description":"Limit result set to specific types of refunds.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"attribute_is":{"description":"Limit result set to orders that include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to orders that don't include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"segmentby":{"description":"Segment the response by additional constraint.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/orders\/stats"}]}},"\/wc-analytics\/reports\/categories":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"category_id","enum":["category_id","items_sold","net_revenue","orders_count","products_count","category"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"status_is":{"description":"Limit result set to items that have the specified order status.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limit result set to items that don't have the specified order status.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"categories":{"description":"Limit result set to all items that have the specified term assigned in the categories taxonomy.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Add additional piece of info about each category to the report.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/categories"}]}},"\/wc-analytics\/reports\/taxes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"tax_rate_id","enum":["name","tax_rate_id","tax_code","rate","order_tax","total_tax","shipping_tax","orders_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"taxes":{"description":"Limit result set to items assigned one or more tax rates.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/taxes"}]}},"\/wc-analytics\/reports\/taxes\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","items_sold","total_sales","orders_count","products_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Limit stats fields to the specified items.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"taxes":{"description":"Limit result set to all items that have the specified term assigned in the taxes taxonomy.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segment the response by additional constraint.","type":"string","enum":["tax_rate_id"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/taxes\/stats"}]}},"\/wc-analytics\/reports\/coupons":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"coupon_id","enum":["coupon_id","code","amount","orders_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"coupons":{"description":"Limit result set to coupons assigned specific coupon IDs.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Add additional piece of info about each coupon to the report.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/coupons"}]}},"\/wc-analytics\/reports\/coupons\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","amount","coupons_count","orders_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Limit stats fields to the specified items.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"coupons":{"description":"Limit result set to coupons assigned specific coupon IDs.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segment the response by additional constraint.","type":"string","enum":["product","variation","category","coupon"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/coupons\/stats"}]}},"\/wc-analytics\/reports\/stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"stock_status","enum":["stock_status","stock_quantity","date","id","include","title","sku"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limit result set to items assigned a stock report type.","type":"string","default":"all","enum":["all","lowstock","instock","outofstock","onbackorder"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/stock"}]}},"\/wc-analytics\/reports\/stock\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/stock\/stats"}]}},"\/wc-analytics\/reports\/downloads":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","product"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: products, orders, username, ip_address.","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limit result set to items that have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Limit result set to items that have the specified order IDs.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limit result set to items that don't have the specified order IDs.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Limit response to objects that have the specified user IDs.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Limit response to objects that don't have the specified user IDs.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Limit response to objects that have a specified IP address.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Limit response to objects that don't have a specified IP address.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/downloads"}]}},"\/wc-analytics\/reports\/downloads\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","download_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Limit stats fields to the specified items.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Time interval to use for buckets in the returned data.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limit result set to items that have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified product(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Limit result set to items that have the specified order IDs.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limit result set to items that don't have the specified order IDs.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Limit response to objects that have the specified customer IDs.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Limit response to objects that don't have the specified customer IDs.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Limit response to objects that have a specified IP address.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Limit response to objects that don't have a specified IP address.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/downloads\/stats"}]}},"\/wc-analytics\/reports\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"registered_before":{"description":"Limit response to objects registered before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limit response to objects registered after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limit response to objects with a customer field containing the search term. Searches the field provided by 'searchby'.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limit response to objects with specific names.","type":"string","required":false},"name_excludes":{"description":"Limit response to objects excluding specific names.","type":"string","required":false},"username_includes":{"description":"Limit response to objects with specific usernames.","type":"string","required":false},"username_excludes":{"description":"Limit response to objects excluding specific usernames.","type":"string","required":false},"email_includes":{"description":"Limit response to objects including emails.","type":"string","required":false},"email_excludes":{"description":"Limit response to objects excluding emails.","type":"string","required":false},"country_includes":{"description":"Limit response to objects with specific countries.","type":"string","required":false},"country_excludes":{"description":"Limit response to objects excluding specific countries.","type":"string","required":false},"last_active_before":{"description":"Limit response to objects last active before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limit response to objects last active after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limit response to objects with an order count greater than or equal to given integer.","type":"integer","required":false},"orders_count_max":{"description":"Limit response to objects with an order count less than or equal to given integer.","type":"integer","required":false},"orders_count_between":{"description":"Limit response to objects with an order count between two given integers.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limit response to objects with a total order spend greater than or equal to given number.","type":"number","required":false},"total_spend_max":{"description":"Limit response to objects with a total order spend less than or equal to given number.","type":"number","required":false},"total_spend_between":{"description":"Limit response to objects with a total order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limit response to objects with an average order spend greater than or equal to given number.","type":"number","required":false},"avg_order_value_max":{"description":"Limit response to objects with an average order spend less than or equal to a given number.","type":"number","required":false},"avg_order_value_between":{"description":"Limit response to objects with an average order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limit response to objects with last order before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limit response to objects with last order after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"customers":{"description":"Limit result to items with specified customer IDs.","type":"array","items":{"type":"integer"},"required":false},"users":{"description":"Limit result to items with specified user IDs.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filter out results where any of the passed fields are empty","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limit result to items with specified user type.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Includes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"location_excludes":{"description":"Excludes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/customers"}]}},"\/wc-analytics\/reports\/customers\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"registered_before":{"description":"Limit response to objects registered before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limit response to objects registered after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"match":{"description":"Indicates whether all the conditions should be true for the resulting set, or if any one of them is sufficient. Match affects the following parameters: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limit response to objects with a customer field containing the search term. Searches the field provided by 'searchby'.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limit response to objects with specific names.","type":"string","required":false},"name_excludes":{"description":"Limit response to objects excluding specific names.","type":"string","required":false},"username_includes":{"description":"Limit response to objects with specific usernames.","type":"string","required":false},"username_excludes":{"description":"Limit response to objects excluding specific usernames.","type":"string","required":false},"email_includes":{"description":"Limit response to objects including emails.","type":"string","required":false},"email_excludes":{"description":"Limit response to objects excluding emails.","type":"string","required":false},"country_includes":{"description":"Limit response to objects with specific countries.","type":"string","required":false},"country_excludes":{"description":"Limit response to objects excluding specific countries.","type":"string","required":false},"last_active_before":{"description":"Limit response to objects last active before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limit response to objects last active after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limit response to objects last active between two given ISO8601 compliant datetime.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limit response to objects with an order count greater than or equal to given integer.","type":"integer","required":false},"orders_count_max":{"description":"Limit response to objects with an order count less than or equal to given integer.","type":"integer","required":false},"orders_count_between":{"description":"Limit response to objects with an order count between two given integers.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limit response to objects with a total order spend greater than or equal to given number.","type":"number","required":false},"total_spend_max":{"description":"Limit response to objects with a total order spend less than or equal to given number.","type":"number","required":false},"total_spend_between":{"description":"Limit response to objects with a total order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limit response to objects with an average order spend greater than or equal to given number.","type":"number","required":false},"avg_order_value_max":{"description":"Limit response to objects with an average order spend less than or equal to a given number.","type":"number","required":false},"avg_order_value_between":{"description":"Limit response to objects with an average order spend between two given numbers.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limit response to objects with last order before (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limit response to objects with last order after (or at) a given ISO8601 compliant datetime.","type":"string","format":"date-time","required":false},"customers":{"description":"Limit result to items with specified customer IDs.","type":"array","items":{"type":"integer"},"required":false},"fields":{"description":"Limit stats fields to the specified items.","type":"array","items":{"type":"string"},"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/customers\/stats"}]}},"\/wc-analytics\/imports\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/imports\/status"}]}},"\/wc-analytics\/imports\/trigger":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/imports\/trigger"}]}},"\/wc-analytics\/reports\/performance-indicators":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Limit response to specific report stats. Allowed values: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/performance-indicators"}]}},"\/wc-analytics\/reports\/performance-indicators\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Limit response to specific report stats. Allowed values: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/reports\/performance-indicators\/allowed"}]}},"\/wc-analytics\/admin\/notes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["note_id","date","type","title","status"],"required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"type":{"description":"Type of note.","type":"array","items":{"enum":["error","warning","update","info","marketing","survey"],"type":"string"},"required":false},"status":{"description":"Status of note.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false},"source":{"description":"Source of note.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/admin\/notes"}]}},"\/wc-analytics\/admin\/notes\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false}}}]},"\/wc-analytics\/admin\/notes\/delete\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}]},"\/wc-analytics\/admin\/notes\/delete\/all":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"status":{"description":"Status of note.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/admin\/notes\/delete\/all"}]}},"\/wc-analytics\/admin\/notes\/update":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/admin\/notes\/update"}]}},"\/wc-analytics\/admin\/notes\/experimental-activate-promo\/(?P<promo_note_name>[\\w-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-analytics\/admin\/notes\/(?P<note_id>[\\d-]+)\/action\/(?P<action_id>[\\d-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"note_id":{"description":"Unique ID for the Note.","type":"integer","required":false},"action_id":{"description":"Unique ID for the Note Action.","type":"integer","required":false}}}]},"\/wc-analytics\/coupons":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to coupons with codes matching a given string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limit result set to resources with a specific code.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Coupon code.","type":"string","required":true},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"default":false,"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/coupons"}]}},"\/wc-analytics\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"code":{"description":"Coupon code.","type":"string","required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc-analytics\/coupons\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Coupon code.","type":"string","required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/coupons\/batch"}]}},"\/wc-analytics\/data":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/data"}]}},"\/wc-analytics\/data\/countries\/locales":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/data\/countries\/locales"}]}},"\/wc-analytics\/data\/countries":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/data\/countries"}]}},"\/wc-analytics\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"ISO3166 alpha-2 country code.","type":"string","required":false}}}]},"\/wc-analytics\/data\/download-ips":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/data\/download-ips"}]}},"\/wc-analytics\/orders":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":["any"],"description":"Limit result set to orders which have specific statuses.","type":"array","items":{"type":"string","enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limit result set to orders created via specific sources (e.g. checkout, admin).","type":"array","items":{"type":"string"},"required":false},"number":{"description":"Limit result set to orders matching part of an order number.","type":"string","required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"created_via":{"description":"Shows where the order was created.","type":"string","required":false},"status":{"default":"pending","description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"GBP","description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"manual_update":{"default":false,"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/orders"}]}},"\/wc-analytics\/orders\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"created_via":{"description":"Shows where the order was created.","type":"string","required":false},"status":{"description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc-analytics\/orders\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"created_via":{"description":"Shows where the order was created.","type":"string","required":false},"status":{"description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/orders\/batch"}]}},"\/wc-analytics\/products":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Search by similar product name or SKU.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute. Use the taxonomy name\/attribute slug.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limit results to those with a SKU that partial matches a string. This argument takes precedence over 'sku'.","type":"string","required":false},"search_name_or_sku":{"description":"Limit results to those with a name or SKU that partial matches a string. This argument takes precedence over 'search', 'sku' and 'search_sku'.","type":"string","required":false},"search_fields":{"description":"Limit search to specific fields when used with search parameter. Available fields: name, sku, global_unique_id, description, short_description. This argument takes precedence over all other search parameters.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limit result set to products with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude products with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limit result set to products with any of the types.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"exclude_types":{"description":"Exclude products with any of the types from result set.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"downloadable":{"description":"Limit result set to downloadable products.","type":"boolean","required":false},"virtual":{"description":"Limit result set to virtual products.","type":"boolean","required":false},"pos_products_only":{"description":"Limit result set to products visible in Point of Sale.","type":"boolean","required":false},"low_in_stock":{"description":"Limit result set to products that are low or out of stock. (Deprecated)","type":"boolean","default":false,"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"description":"Whether to bypass bin and force deletion.","type":"boolean","required":false}}}]},"\/wc-analytics\/products\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/batch"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false}}}]},"\/wc-analytics\/products\/suggested-products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute. Use the taxonomy name\/attribute slug.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limit result set to products in stock or out of stock.","type":"boolean","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"categories":{"description":"Limit result set to specific product categorie ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limit result set to specific product tag ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limit result set to specific amount of suggested products.","type":"integer","default":5,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/suggested-products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc-analytics\/products\/attributes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"search":{"description":"Search by similar attribute name.","type":"string","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Name for the resource.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"default":"select","description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/attributes"}]}},"\/wc-analytics\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc-analytics\/products\/attributes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/attributes\/batch"}]}},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug identifier for the resource.","type":"string","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)\/terms":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false}}}]},"\/wc-analytics\/products\/categories":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"default":"default","description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/categories"}]}},"\/wc-analytics\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc-analytics\/products\/categories\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/categories\/batch"}]}},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Search by similar product name, SKU, or attribute value.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Attribute slug."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"type":{"default":"variation","description":"Product type.","type":"string","enum":["variation"],"required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"name":{"description":"Product parent name.","type":"string","required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"type":{"description":"Product type.","type":"string","enum":["variation"],"required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"name":{"description":"Product parent name.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"type":{"description":"Product type.","type":"string","enum":["variation"],"required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"name":{"description":"Product parent name.","type":"string","required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"delete":{"description":"Deletes unused variations.","type":"boolean","required":false},"default_values":{"description":"Default values for generated variations.","type":"object","properties":{"type":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Product type.","type":"string","enum":["variation"]},"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation description.","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock Keeping Unit.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN or ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation regular price.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation sale price.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Start date of sale price, in the site's timezone.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Start date of sale price, as GMT.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"End date of sale price, in the site's timezone.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"End date of sale price, in the site's timezone.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation status.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"If the variation is virtual.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"If the variation is downloadable.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Number of times downloadable files can be downloaded after purchase.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Number of days until access to downloadable files expires.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tax status.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tax class.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock management at variation level.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock quantity.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Low Stock amount for the variation.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation weight (kg).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Shipping class slug.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Menu order, used to custom sort products.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}},"parent_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Product parent ID.","type":"integer"},"name":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Product parent name.","type":"string"}},"required":false},"type":{"default":"variation","description":"Product type.","type":"string","enum":["variation"],"required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"name":{"description":"Product parent name.","type":"string","required":false}}}]},"\/wc-analytics\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Search by similar product name, SKU, or attribute value.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Attribute slug."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/variations"}]}},"\/wc-analytics\/products\/reviews":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to reviews published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Limit result set to reviews assigned to specific user IDs.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"Ensure result set excludes reviews assigned to specific user IDs.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Limit result set to that from a specific author email.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Limit result set to reviews assigned to specific product IDs.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Limit result set to reviews assigned a specific status.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the product.","type":"integer","required":true},"product_name":{"description":"Product name.","type":"string","required":false},"status":{"default":"approved","description":"Status of the review.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Name of the reviewer.","required":true},"reviewer_email":{"type":"string","description":"Email of the reviewer.","required":true},"review":{"type":"string","description":"Review content.","required":true},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/reviews"}]}},"\/wc-analytics\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"product_id":{"description":"Unique identifier for the product that the review belongs to.","type":"integer","required":false},"product_name":{"description":"Product name.","type":"string","required":false},"status":{"description":"Status of the review.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Reviewer name.","type":"string","required":false},"reviewer_email":{"description":"Reviewer email.","type":"string","format":"email","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc-analytics\/products\/reviews\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the product that the review belongs to.","type":"integer","required":false},"product_name":{"description":"Product name.","type":"string","required":false},"status":{"description":"Status of the review.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Reviewer name.","type":"string","required":false},"reviewer_email":{"description":"Reviewer email.","type":"string","format":"email","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/reviews\/batch"}]}},"\/wc-analytics\/products\/low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"status":{"default":"publish","description":"Limit result set to products assigned a specific status.","type":"string","enum":["draft","pending","private","publish","future"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/low-in-stock"}]}},"\/wc-analytics\/products\/count-low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"status":{"default":"publish","description":"Limit result set to products assigned a specific status.","type":"string","enum":["draft","pending","private","publish","future"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/products\/count-low-in-stock"}]}},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"value":{"description":"Setting value.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"id":{"description":"Unique identifier for the resource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"value":{"description":"Setting value.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc-analytics\/taxes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Sort collection by object attribute.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Sort by tax class.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"search":{"description":"Search by similar tax code.","type":"string","required":false},"include":{"description":"Limit result set to items that have the specified rate ID(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"default":1,"description":"Tax priority.","type":"integer","required":false},"compound":{"default":false,"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"default":true,"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"default":"standard","description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"List of postcodes \/ ZIPs. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"List of city names. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/taxes"}]}},"\/wc-analytics\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"List of postcodes \/ ZIPs. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"List of city names. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc-analytics\/taxes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"List of postcodes \/ ZIPs. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"List of city names. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-analytics\/taxes\/batch"}]}},"\/wc-admin\/launch-your-store\/initialize-coming-soon":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/launch-your-store\/initialize-coming-soon"}]}},"\/wc-admin\/launch-your-store\/update-survey-status":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"status":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/launch-your-store\/update-survey-status"}]}},"\/wc-admin\/launch-your-store\/survey-completed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/launch-your-store\/survey-completed"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders":{"namespace":"wc-admin","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders"}]}},"\/wc\/store":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store"}]}},"\/wc\/store\/batch":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/batch"}]}},"\/wc\/store\/cart":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart"}]}},"\/wc\/store\/cart\/add-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"The basket item product or variation ID.","type":"integer","required":false},"quantity":{"description":"Quantity of this item to add to the basket.","type":"number","required":false},"variation":{"description":"Chosen attributes (for variations).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Variation attribute name.","type":"string","context":["view","edit"]},"value":{"description":"Variation attribute value.","type":"string","context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/add-item"}]}},"\/wc\/store\/cart\/apply-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/apply-coupon"}]}},"\/wc\/store\/cart\/coupons":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"The coupon's unique code.","type":"string","required":false},"discount_type":{"description":"The discount type for the coupon (eg percentage or fixed amount)","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/coupons"}]}},"\/wc\/store\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false}}}]},"\/wc\/store\/cart\/extensions":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Extension's name - this will be used to ensure the data in the request is routed appropriately.","type":"string","required":false},"data":{"description":"Additional data to pass to the extension","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/extensions"}]}},"\/wc\/store\/cart\/items":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":[],"default":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/items"}]}},"\/wc\/store\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier for the item within the basket.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier for the item within the basket.","type":"string","required":false},"extensions":{"type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier for the item within the basket.","type":"string","required":false}}}]},"\/wc\/store\/cart\/remove-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/remove-coupon"}]}},"\/wc\/store\/cart\/remove-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier (key) for the basket item.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/remove-item"}]}},"\/wc\/store\/cart\/select-shipping-rate":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"The ID of the package being shipped. Leave blank to apply to all packages.","type":["integer","string","null"],"required":false},"rate_id":{"description":"The chosen rate ID for the package.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/select-shipping-rate"}]}},"\/wc\/store\/cart\/update-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier (key) for the basket item to update.","type":"string","required":false},"quantity":{"description":"New quantity of the item in the basket.","type":"number","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/update-item"}]}},"\/wc\/store\/cart\/update-customer":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/cart\/update-customer"}]}},"\/wc\/store\/checkout":{"namespace":"wc\/store","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Data to pass through to the payment method when processing payment.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Customer password for new accounts, if applicable.","type":"string","required":false},"customer_note":{"description":"Note added to the order by the customer during checkout.","type":"string","required":false},"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"The ID of the payment method being used to process the payment.","type":"string","enum":["","bacs","cheque","cod"],"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"payment_method":{"description":"The ID of the payment method being used to process the payment.","type":"string","enum":["","bacs","cheque","cod"],"required":false},"order_notes":{"description":"Order notes.","type":"string","required":false},"customer_note":{"description":"Note added to the order by the customer during checkout.","type":"string","required":false},"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/checkout"}]}},"\/wc\/store\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Data to pass through to the payment method when processing payment.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Note added to the order by the customer during checkout.","type":"string","required":false},"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"The ID of the payment method being used to process the payment.","type":"string","enum":["","bacs","cheque","cod"],"required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}}]},"\/wc\/store\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/attributes":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products\/attributes"}]}},"\/wc\/store\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Unique identifier for the attribute.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}]},"\/wc\/store\/products\/categories":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products\/categories"}]}},"\/wc\/store\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/brands":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products\/brands"}]}},"\/wc\/store\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Unique identifier for the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/collection-data":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"slug":{"description":"Limit result set to products with specific slug(s). Use commas to separate.","type":"string","required":false},"after":{"description":"Limit response to resources created after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources created before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"date_column":{"description":"When limiting response using after\/before, which date column to compare against.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a set of category IDs or slugs, separated by commas.","type":"string","required":false},"category_operator":{"description":"Operator to compare product category terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limit result set to products assigned a set of brand IDs or slugs, separated by commas.","type":"string","required":false},"brand_operator":{"description":"Operator to compare product brand terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limit result set to products assigned a set of tag IDs or slugs, separated by commas.","type":"string","required":false},"tag_operator":{"description":"Operator to compare product tags.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price, provided using the smallest unit of the currency.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price, provided using the smallest unit of the currency.","type":"string","required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limit result set to products with selected global attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Attribute taxonomy name.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"List of attribute term IDs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"List of attribute slug(s). If a term ID is provided, this will be ignored.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operator to compare product attribute terms.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"The logical relationship between attributes when filtering across several at once.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determines if hidden or visible catalogue products are shown.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limit result set to products with a certain average rating.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"calculate_price_range":{"description":"If true, calculates the minimum and maximum product prices for the collection.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"If true, calculates stock counts for products in the collection.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"If requested, calculates attribute term counts for products in the collection.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Taxonomy name.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Filter condition\t being performed which may affect counts. Valid values include \"and\" and \"or\".","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"required":false},"calculate_rating_counts":{"description":"If true, calculates rating counts for products in the collection.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"If requested, calculates taxonomy term counts for products in the collection.","type":"array","items":{"type":"string","description":"Taxonomy name."},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products\/collection-data"}]}},"\/wc\/store\/products\/reviews":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Limit result set to reviews from specific category IDs.","type":"string","required":false},"product_id":{"description":"Limit result set to reviews from specific product IDs.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products\/reviews"}]}},"\/wc\/store\/products\/tags":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products\/tags"}]}},"\/wc\/store\/products":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"slug":{"description":"Limit result set to products with specific slug(s). Use commas to separate.","type":"string","required":false},"after":{"description":"Limit response to resources created after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources created before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"date_column":{"description":"When limiting response using after\/before, which date column to compare against.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a set of category IDs or slugs, separated by commas.","type":"string","required":false},"category_operator":{"description":"Operator to compare product category terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limit result set to products assigned a set of brand IDs or slugs, separated by commas.","type":"string","required":false},"brand_operator":{"description":"Operator to compare product brand terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limit result set to products assigned a set of tag IDs or slugs, separated by commas.","type":"string","required":false},"tag_operator":{"description":"Operator to compare product tags.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price, provided using the smallest unit of the currency.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price, provided using the smallest unit of the currency.","type":"string","required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limit result set to products with selected global attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Attribute taxonomy name.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"List of attribute term IDs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"List of attribute slug(s). If a term ID is provided, this will be ignored.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operator to compare product attribute terms.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"The logical relationship between attributes when filtering across several at once.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determines if hidden or visible catalogue products are shown.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limit result set to products with a certain average rating.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/products"}]}},"\/wc\/store\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug of the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1"}]}},"\/wc\/store\/v1\/batch":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/batch"}]}},"\/wc\/store\/v1\/cart":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart"}]}},"\/wc\/store\/v1\/cart\/add-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"The basket item product or variation ID.","type":"integer","required":false},"quantity":{"description":"Quantity of this item to add to the basket.","type":"number","required":false},"variation":{"description":"Chosen attributes (for variations).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Variation attribute name.","type":"string","context":["view","edit"]},"value":{"description":"Variation attribute value.","type":"string","context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/add-item"}]}},"\/wc\/store\/v1\/cart\/apply-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/apply-coupon"}]}},"\/wc\/store\/v1\/cart\/coupons":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"The coupon's unique code.","type":"string","required":false},"discount_type":{"description":"The discount type for the coupon (eg percentage or fixed amount)","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/coupons"}]}},"\/wc\/store\/v1\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false}}}]},"\/wc\/store\/v1\/cart\/extensions":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Extension's name - this will be used to ensure the data in the request is routed appropriately.","type":"string","required":false},"data":{"description":"Additional data to pass to the extension","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/extensions"}]}},"\/wc\/store\/v1\/cart\/items":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":[],"default":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/items"}]}},"\/wc\/store\/v1\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier for the item within the basket.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier for the item within the basket.","type":"string","required":false},"extensions":{"type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier for the item within the basket.","type":"string","required":false}}}]},"\/wc\/store\/v1\/cart\/remove-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Unique identifier for the coupon within the basket.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/remove-coupon"}]}},"\/wc\/store\/v1\/cart\/remove-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier (key) for the basket item.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/remove-item"}]}},"\/wc\/store\/v1\/cart\/select-shipping-rate":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"The ID of the package being shipped. Leave blank to apply to all packages.","type":["integer","string","null"],"required":false},"rate_id":{"description":"The chosen rate ID for the package.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/select-shipping-rate"}]}},"\/wc\/store\/v1\/cart\/update-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Unique identifier (key) for the basket item to update.","type":"string","required":false},"quantity":{"description":"New quantity of the item in the basket.","type":"number","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/update-item"}]}},"\/wc\/store\/v1\/cart\/update-customer":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/cart\/update-customer"}]}},"\/wc\/store\/v1\/checkout":{"namespace":"wc\/store\/v1","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Data to pass through to the payment method when processing payment.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Customer password for new accounts, if applicable.","type":"string","required":false},"customer_note":{"description":"Note added to the order by the customer during checkout.","type":"string","required":false},"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"The ID of the payment method being used to process the payment.","type":"string","enum":["","bacs","cheque","cod"],"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"payment_method":{"description":"The ID of the payment method being used to process the payment.","type":"string","enum":["","bacs","cheque","cod"],"required":false},"order_notes":{"description":"Order notes.","type":"string","required":false},"customer_note":{"description":"Note added to the order by the customer during checkout.","type":"string","required":false},"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/checkout"}]}},"\/wc\/store\/v1\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Data to pass through to the payment method when processing payment.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Note added to the order by the customer during checkout.","type":"string","required":false},"billing_address":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true},"email":{"description":"Email","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Last name","type":"string","context":["view","edit"],"required":true},"company":{"description":"Company","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Address","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Flat, suite, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"City","type":"string","context":["view","edit"],"required":true},"state":{"description":"State\/County code, or name of the state, county, province, or district.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postcode","type":"string","context":["view","edit"],"required":true},"country":{"description":"Country\/Region code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Phone","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"The ID of the payment method being used to process the payment.","type":"string","enum":["","bacs","cheque","cod"],"required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false}}}]},"\/wc\/store\/v1\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/attributes":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products\/attributes"}]}},"\/wc\/store\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Unique identifier for the attribute.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}]},"\/wc\/store\/v1\/products\/categories":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products\/categories"}]}},"\/wc\/store\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/brands":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products\/brands"}]}},"\/wc\/store\/v1\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Unique identifier for the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/collection-data":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"slug":{"description":"Limit result set to products with specific slug(s). Use commas to separate.","type":"string","required":false},"after":{"description":"Limit response to resources created after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources created before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"date_column":{"description":"When limiting response using after\/before, which date column to compare against.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a set of category IDs or slugs, separated by commas.","type":"string","required":false},"category_operator":{"description":"Operator to compare product category terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limit result set to products assigned a set of brand IDs or slugs, separated by commas.","type":"string","required":false},"brand_operator":{"description":"Operator to compare product brand terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limit result set to products assigned a set of tag IDs or slugs, separated by commas.","type":"string","required":false},"tag_operator":{"description":"Operator to compare product tags.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price, provided using the smallest unit of the currency.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price, provided using the smallest unit of the currency.","type":"string","required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limit result set to products with selected global attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Attribute taxonomy name.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"List of attribute term IDs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"List of attribute slug(s). If a term ID is provided, this will be ignored.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operator to compare product attribute terms.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"The logical relationship between attributes when filtering across several at once.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determines if hidden or visible catalogue products are shown.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limit result set to products with a certain average rating.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"calculate_price_range":{"description":"If true, calculates the minimum and maximum product prices for the collection.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"If true, calculates stock counts for products in the collection.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"If requested, calculates attribute term counts for products in the collection.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Taxonomy name.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Filter condition\t being performed which may affect counts. Valid values include \"and\" and \"or\".","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"required":false},"calculate_rating_counts":{"description":"If true, calculates rating counts for products in the collection.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"If requested, calculates taxonomy term counts for products in the collection.","type":"array","items":{"type":"string","description":"Taxonomy name."},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products\/collection-data"}]}},"\/wc\/store\/v1\/products\/reviews":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Limit result set to reviews from specific category IDs.","type":"string","required":false},"product_id":{"description":"Limit result set to reviews from specific product IDs.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products\/reviews"}]}},"\/wc\/store\/v1\/products\/tags":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set. Defaults to no limit if left blank.","type":"integer","minimum":0,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sort ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort by term property.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"If true, empty terms will not be returned.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products\/tags"}]}},"\/wc\/store\/v1\/products":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"slug":{"description":"Limit result set to products with specific slug(s). Use commas to separate.","type":"string","required":false},"after":{"description":"Limit response to resources created after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources created before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"date_column":{"description":"When limiting response using after\/before, which date column to compare against.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a set of category IDs or slugs, separated by commas.","type":"string","required":false},"category_operator":{"description":"Operator to compare product category terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limit result set to products assigned a set of brand IDs or slugs, separated by commas.","type":"string","required":false},"brand_operator":{"description":"Operator to compare product brand terms.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limit result set to products assigned a set of tag IDs or slugs, separated by commas.","type":"string","required":false},"tag_operator":{"description":"Operator to compare product tags.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price, provided using the smallest unit of the currency.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price, provided using the smallest unit of the currency.","type":"string","required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limit result set to products with selected global attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Attribute taxonomy name.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"List of attribute term IDs.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"List of attribute slug(s). If a term ID is provided, this will be ignored.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operator to compare product attribute terms.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"The logical relationship between attributes when filtering across several at once.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determines if hidden or visible catalogue products are shown.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limit result set to products with a certain average rating.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/store\/v1\/products"}]}},"\/wc\/store\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/store\/v1\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug of the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/private":{"namespace":"wc\/private","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/private","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/private"}]}},"\/wc\/private\/patterns":{"namespace":"wc\/private","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/private\/patterns"}]}},"\/wp-rocket\/v1":{"namespace":"wp-rocket\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-rocket\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1"}]}},"\/wp-rocket\/v1\/rocketcdn\/enable":{"namespace":"wp-rocket\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"email":{"required":true},"key":{"required":true},"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/rocketcdn\/enable"}]}},"\/wp-rocket\/v1\/rocketcdn\/disable":{"namespace":"wp-rocket\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"email":{"required":true},"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/rocketcdn\/disable"}]}},"\/wp-rocket\/v1\/cpcss\/post\/(?P<id>[\\d]+)":{"namespace":"wp-rocket\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/wp-rocket\/v1\/support":{"namespace":"wp-rocket\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email":{"required":true},"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/support"}]}},"\/wp-rocket\/v1\/dynamic_lists\/update":{"namespace":"wp-rocket\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/dynamic_lists\/update"}]}},"\/wp-rocket\/v1\/options\/export":{"namespace":"wp-rocket\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/options\/export"}]}},"\/wp-rocket\/v1\/rocket-insights\/pages":{"namespace":"wp-rocket\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":false},"post_id":{"required":false}}},{"methods":["POST"],"args":{"page_url":{"required":true},"source":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/rocket-insights\/pages"}]}},"\/wp-rocket\/v1\/rocket-insights\/pages\/progress":{"namespace":"wp-rocket\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ids":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/rocket-insights\/pages\/progress"}]}},"\/wp-rocket\/v1\/rocket-insights\/pages\/(?P<id>\\d+)":{"namespace":"wp-rocket\/v1","methods":["DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":true},"source":{"required":true}}}]},"\/wp-rocket\/v1\/recommendations":{"namespace":"wp-rocket\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-rocket\/v1\/recommendations"}]}},"\/solidwp-mail\/v1":{"namespace":"solidwp-mail\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"solidwp-mail\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/solidwp-mail\/v1"}]}},"\/solidwp-mail\/v1\/logs":{"namespace":"solidwp-mail\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","default":0,"required":true},"sortby":{"type":"string","default":"timestamp","enum":["timestamp","subject","to"],"required":false},"sort":{"type":"string","default":"desc","enum":["asc","desc"],"required":false},"search_term":{"type":"string","default":"","required":false},"per_page":{"type":"integer","default":10,"required":false},"logIds":{"default":[],"type":"array","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/solidwp-mail\/v1\/logs"}]}},"\/solidwp-mail\/v1\/logs\/delete":{"namespace":"solidwp-mail\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"page":{"type":"integer","default":0,"required":true},"sortby":{"type":"string","default":"timestamp","enum":["timestamp","subject","to"],"required":false},"sort":{"type":"string","default":"desc","enum":["asc","desc"],"required":false},"search_term":{"type":"string","default":"","required":false},"per_page":{"type":"integer","default":10,"required":false},"logIds":{"default":[],"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/solidwp-mail\/v1\/logs\/delete"}]}},"\/solidwp-mail\/v1\/logs\/export-csv":{"namespace":"solidwp-mail\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"date_from":{"type":"string","format":"date","required":true},"date_to":{"type":"string","format":"date","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/solidwp-mail\/v1\/logs\/export-csv"}]}},"\/solid-mail\/v1":{"namespace":"solid-mail\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"solid-mail\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/solid-mail\/v1"}]}},"\/solid-mail\/v1\/connections":{"namespace":"solid-mail\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"name":{"description":"The connection type name.","type":"string","enum":["mailgun","brevo","sendgrid","amazon_ses","postmark","other"],"required":true},"description":{"description":"Description of the connection.","type":"string","required":false},"from_email":{"description":"The email address used as the sender.","type":"string","format":"email","required":false},"from_name":{"description":"The name used as the sender.","type":"string","required":false},"is_active":{"description":"Whether this connection is active.","type":"boolean","required":false},"is_default":{"description":"Whether this connection is used for email addresses not related to a specific connection.","type":"boolean","required":false},"disable_logs":{"description":"Whether logging is disabled for this connection.","type":"boolean","required":false},"delivery_method":{"description":"The delivery method used by the connection.","type":"string","enum":["smtp","api"],"required":false},"smtp_host":{"description":"SMTP server hostname.","type":"string","required":false},"smtp_port":{"description":"SMTP server port.","type":"integer","minimum":0,"required":false},"smtp_auth":{"description":"Whether SMTP authentication is required.","type":"string","enum":["yes","no"],"required":false},"smtp_username":{"description":"SMTP username for authentication.","type":"string","required":false},"smtp_password":{"description":"SMTP password for authentication.","type":"string","required":false},"smtp_secure":{"description":"SMTP encryption method.","type":"string","enum":["","ssl","tls"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/solid-mail\/v1\/connections"}]}},"\/solid-mail\/v1\/connections\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"solid-mail\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the connection.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"The connection type name.","type":"string","enum":["mailgun","brevo","sendgrid","amazon_ses","postmark","other"],"required":false},"description":{"description":"Description of the connection.","type":"string","required":false},"from_email":{"description":"The email address used as the sender.","type":"string","format":"email","required":false},"from_name":{"description":"The name used as the sender.","type":"string","required":false},"is_active":{"description":"Whether this connection is active.","type":"boolean","required":false},"is_default":{"description":"Whether this connection is used for email addresses not related to a specific connection.","type":"boolean","required":false},"disable_logs":{"description":"Whether logging is disabled for this connection.","type":"boolean","required":false},"delivery_method":{"description":"The delivery method used by the connection.","type":"string","enum":["smtp","api"],"required":false},"smtp_host":{"description":"SMTP server hostname.","type":"string","required":false},"smtp_port":{"description":"SMTP server port.","type":"integer","minimum":0,"required":false},"smtp_auth":{"description":"Whether SMTP authentication is required.","type":"string","enum":["yes","no"],"required":false},"smtp_username":{"description":"SMTP username for authentication.","type":"string","required":false},"smtp_password":{"description":"SMTP password for authentication.","type":"string","required":false},"smtp_secure":{"description":"SMTP encryption method.","type":"string","enum":["","ssl","tls"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the connection.","type":"string","required":false}}}]},"\/wpstg\/v1":{"namespace":"wpstg\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpstg\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wpstg\/v1"}]}},"\/wpstg\/v1\/ping":{"namespace":"wpstg\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wpstg\/v1\/ping"}]}},"\/wpstg\/v1\/sse-logs":{"namespace":"wpstg\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wpstg\/v1\/sse-logs"}]}},"\/wc\/v2":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2"}]}},"\/wc\/v2\/products\/brands":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"default":"default","description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/brands"}]}},"\/wc\/v2\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/products\/brands\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/brands\/batch"}]}},"\/wc\/v3\/products\/brands":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"default":"default","description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/brands"}]}},"\/wc\/v3\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/products\/brands\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/brands\/batch"}]}},"\/yoast\/v1\/redirects":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"integer","description":"The redirect type","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"The format of the redirect to create.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/redirects"}]}},"\/yoast\/v1\/redirects\/delete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"string","description":"The redirect format","required":false},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"The format of the redirect to create.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/redirects\/delete"}]}},"\/yoast\/v1\/redirects\/list":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"format":{"description":"The format of the redirects to retrieve.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/redirects\/list"}]}},"\/yoast\/v1\/redirects\/update":{"namespace":"yoast\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"old_origin":{"type":"string","description":"The origin to redirect (old)","required":true},"old_target":{"type":"string","description":"The redirect target (old)","required":false},"old_type":{"type":"integer","description":"The redirect type (old)","required":true},"new_origin":{"type":"string","description":"The origin to redirect (new)","required":true},"new_target":{"type":"string","description":"The redirect target (new)","required":false},"new_type":{"type":"integer","description":"The redirect type (new)","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"The format of the redirects to retrieve.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/redirects\/update"}]}},"\/yoast\/v1\/redirects\/settings":{"namespace":"yoast\/v1","methods":["GET","PUT"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PUT"],"args":{"disable_php_redirect":{"description":"Whether to disable PHP-based redirects and use .htaccess instead.","type":"string","enum":["on","off"],"required":true},"separate_file":{"description":"Whether to write redirects into a separate file instead of .htaccess.","type":"string","enum":["on","off"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/redirects\/settings"}]}},"\/yoast\/v1\/redirects\/undo-for-object":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"obj_id":{"type":"int","description":"The id of the post or term","required":true},"obj_type":{"type":"string","description":"The object type: post or term","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/yoast\/v1\/redirects\/undo-for-object"}]}},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"data":{"type":"object","description":"Settings to set.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false},"data":{"type":"object","description":"Data to set.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Text content to search for.","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/ajax-search-lite":{"namespace":"ajax-search-lite","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ajax-search-lite","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/ajax-search-lite"}]}},"\/ajax-search-lite\/options\/taxonomies\/get":{"namespace":"ajax-search-lite","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/ajax-search-lite\/options\/taxonomies\/get"}]}},"\/ajax-search-lite\/options\/taxonomy_terms\/get":{"namespace":"ajax-search-lite","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/ajax-search-lite\/options\/taxonomy_terms\/get"}]}},"\/ajax-search-lite\/options\/search_instance\/get":{"namespace":"ajax-search-lite","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/ajax-search-lite\/options\/search_instance\/get"}]}},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true}}}]},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/design-system-sync\/stylesheet":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/design-system-sync\/stylesheet"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/operations\/opt-in-v4":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/operations\/opt-in-v4"}]}},"\/elementor\/v1\/feedback":{"namespace":"elementor\/v1\/feedback","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/feedback","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/feedback"}]}},"\/elementor\/v1\/feedback\/submit":{"namespace":"elementor\/v1\/feedback","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/feedback\/submit"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section","container","floating-buttons","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","product","product-archive","loop-item"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/elementor\/v1\/onboarding":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/onboarding"}]}},"\/elementor\/v1\/onboarding\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/onboarding\/user-progress"}]}},"\/elementor\/v1\/onboarding\/user-choices":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/onboarding\/user-choices"}]}},"\/elementor\/v1\/onboarding\/pro-install-screen":{"namespace":"elementor\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/onboarding\/pro-install-screen"}]}},"\/elementor\/v1\/onboarding\/install-pro":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/onboarding\/install-pro"}]}},"\/elementor\/v1\/onboarding\/install-theme":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/onboarding\/install-theme"}]}},"\/elementor\/v1\/global-widget\/templates":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/global-widget\/templates"}]}},"\/elementor-pro\/v1\/posts-widget":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1\/posts-widget"}]}},"\/elementor-pro\/v1\/get-post-type-taxonomies":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"The post type for which to fetch the list of taxonomies.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1\/get-post-type-taxonomies"}]}},"\/elementor-pro\/v1\/refresh-loop":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"The post ID of the page containing the loop.","type":"integer","required":true},"widget_id":{"description":"The ID of the loop widget.","type":"string","required":true},"widget_filters":{"description":"The filters for the loop widget.","type":"object","required":true},"widget_model":{"description":"The model of the loop widget. In Editor mode only.","type":"object","required":false},"pagination_base_url":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1\/refresh-loop"}]}},"\/elementor-pro\/v1\/refresh-search":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"The post ID of the page containing the loop.","type":"integer","required":true},"widget_id":{"description":"The ID of the loop widget.","type":"string","required":true},"widget_model":{"description":"The model of the loop widget. In Editor mode only.","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor-pro\/v1\/refresh-search"}]}},"\/elementor\/v1\/notes":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"status":{"type":"string","description":"The note status (e.g. \"publish\", \"draft\").","enum":["publish","draft"],"default":"publish","required":false},"is_resolved":{"type":"boolean","description":"Whether the note is resolved or not.","required":false},"parent_id":{"type":"integer","description":"The note's parent id (use 0 for top-level).","required":false},"post_id":{"type":"integer","description":"The ID of the post that the note is attached to.","required":false},"only_unread":{"type":"boolean","description":"Show only unread notes (represents an unread thread if one of its replies is unread).","required":false},"only_relevant":{"type":"boolean","description":"Show only notes that are relevant to the current user.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"last_activity_at","enum":["last_activity_at","created_at"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"desc","enum":["asc","desc"],"required":false}}},{"methods":["POST"],"args":{"post_id":{"type":"integer","description":"The id of the post where the note was created at (can be template, post, page, etc.).","required":true},"element_id":{"type":"string","description":"Each note must be attached to an elementor element.","required":true},"content":{"type":"string","description":"The content of the note.","required":true},"position":{"type":"object","properties":{"x":{"required":true,"type":"number"},"y":{"required":true,"type":"number"}},"description":"The position of the note.","required":true},"mentioned_usernames":{"type":"array","description":"List of user names that have been mentioned in the note's content.","default":[],"items":{"type":"string","sanitize_callback":{}},"required":false},"route_post_id":{"description":"The ID of the post that's associated with the route (doesn't always exist, e.g: home page, archive)","required":false},"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"route_title":{"type":"string","description":"The title of the route where the note was created at.","required":false},"parent_id":{"type":"integer","description":"If the new note is a reply to another note, the parent_id should be the thread's id.","default":0,"required":false},"is_public":{"type":"boolean","description":"Should this note be visible for everyone or just for its author.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/notes"}]}},"\/elementor\/v1\/notes\/read-status":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","description":"The id's of the notes.","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"ids":{"type":"array","description":"The id's of the notes.","items":{"type":"integer"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/notes\/read-status"}]}},"\/elementor\/v1\/notes\/summary":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"status":{"type":"string","description":"The note status (e.g. \"publish\", \"draft\").","enum":["publish","draft"],"default":"publish","required":false},"is_resolved":{"type":"boolean","description":"Whether the note is resolved or not.","required":false},"parent_id":{"type":"integer","description":"The note's parent id (use 0 for top-level).","required":false},"post_id":{"type":"integer","description":"The ID of the post that the note is attached to.","required":false},"only_unread":{"type":"boolean","description":"Show only unread notes (represents an unread thread if one of its replies is unread).","required":false},"only_relevant":{"type":"boolean","description":"Show only notes that are relevant to the current user.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"last_activity_at","enum":["last_activity_at","created_at"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"desc","enum":["asc","desc"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/notes\/summary"}]}},"\/elementor\/v1\/notes\/users":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"limit":{"type":"integer","description":"Limit the results.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"display_name","enum":["user_nicename","display_name","user_registered"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"asc","enum":["asc","desc"],"required":false},"search":{"type":"string","description":"Filter users by a search term.","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/notes\/users"}]}},"\/elementor\/v1\/notes\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Note ID to find.","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"The id the note.","required":true},"content":{"type":"string","description":"The content of the note.","required":false},"mentioned_usernames":{"type":"array","description":"List of user names that have been mentioned in the note's content.","items":{"type":"string","sanitize_callback":{}},"required":false},"status":{"type":"string","description":"Note status can be draft or publish.","enum":["publish","draft"],"required":false},"is_public":{"type":"boolean","description":"Should this note be visible for everyone or just for its author.","required":false},"is_resolved":{"type":"boolean","description":"Is this note resolved and should be hidden.","required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"The id of the note.","required":true},"force":{"type":"boolean","description":"Determine if it should be deleted permanently or change the status to trash.","default":false,"required":false}}}]},"\/wc\/v1\/coupons":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Use WP Query arguments to modify the response; private query vars require appropriate authorisation.","required":false},"code":{"description":"Limit result set to resources with a specific code.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Coupon code.","type":"string","required":true},"description":{"description":"Coupon description.","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":"string","required":false},"expiry_date":{"description":"UTC DateTime when the coupon expires.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"default":false,"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":"string","required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":"string","required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/coupons"}]}},"\/wc\/v1\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"code":{"description":"Coupon code.","type":"string","required":false},"description":{"description":"Coupon description.","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":"string","required":false},"expiry_date":{"description":"UTC DateTime when the coupon expires.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":"string","required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":"string","required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v1\/coupons\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Coupon code.","type":"string","required":false},"description":{"description":"Coupon description.","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":"string","required":false},"expiry_date":{"description":"UTC DateTime when the coupon expires.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":"string","required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":"string","required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/coupons\/batch"}]}},"\/wc\/v1\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v1\/customers":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by object attribute.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limit result set to resources with a specific email.","type":"string","format":"email","required":false},"role":{"description":"Limit result set to resources with a specific role.","type":"string","default":"customer","enum":["all","no_private_message","customer","bbp_spectator","bbp_participant","bbp_senior_moderator","bbp_moderator","SILVER Member","BRONZE Member","GOLD Member","FOUNDER Member","shop_manager","editor","administrator","bbp_keymaster","author","bbp_blocked"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"New user email address.","required":true},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"New user username.","type":"string","required":true},"password":{"description":"New user password.","type":"string","required":true},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/customers"}]}},"\/wc\/v1\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"email":{"description":"The email address for the customer.","type":"string","format":"email","required":false},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"Customer login name.","type":"string","required":false},"password":{"description":"Customer password.","type":"string","required":false},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false},"reassign":{"default":0,"type":"integer","description":"ID to reassign posts to.","required":false}}}]},"\/wc\/v1\/customers\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"The email address for the customer.","type":"string","format":"email","required":false},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"Customer login name.","type":"string","required":false},"password":{"description":"Customer password.","type":"string","required":false},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/customers\/batch"}]}},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"note":{"type":"string","description":"Order note content.","required":true},"customer_note":{"default":false,"description":"Shows\/define if the note is only for reference or for the customer (the user will be notified).","type":"boolean","required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"order_id":{"description":"The order ID.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Use WP Query arguments to modify the response; private query vars require appropriate authorisation.","required":false},"status":{"default":"any","description":"Limit result set to orders assigned a specific status.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"amount":{"description":"Refund amount.","type":"string","required":false},"reason":{"description":"Reason for refund.","type":"string","required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/orders":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Use WP Query arguments to modify the response; private query vars require appropriate authorisation.","required":false},"status":{"default":"any","description":"Limit result set to orders assigned a specific status.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"status":{"default":"pending","description":"Order status.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"GBP","description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"set_paid":{"default":false,"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"]},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Line item meta data.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Meta key.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Meta label.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"]},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/orders"}]}},"\/wc\/v1\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"status":{"description":"Order status.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"]},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Line item meta data.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Meta key.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Meta label.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"]},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v1\/orders\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"status":{"description":"Order status.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2.","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"]},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Line item meta data.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Meta key.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Meta label.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"]},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/orders\/batch"}]}},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc\/v1\/products\/attributes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Name for the resource.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"default":"select","description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/attributes"}]}},"\/wc\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/products\/attributes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/attributes\/batch"}]}},"\/wc\/v1\/products\/categories":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"default":"default","description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/categories"}]}},"\/wc\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/products\/categories\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/categories\/batch"}]}},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"review":{"type":"string","description":"Review content.","required":true},"date_created":{"description":"The date the review was created, in the site's timezone.","type":["null","string"],"required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false},"name":{"type":"string","description":"Name of the reviewer.","required":true},"email":{"type":"string","description":"Email of the reviewer.","required":true}}}]},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"date_created":{"description":"The date the review was created, in the site's timezone.","type":["null","string"],"required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false},"name":{"description":"Reviewer name.","type":"string","required":false},"email":{"description":"Reviewer email.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v1\/products\/shipping_classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/shipping_classes"}]}},"\/wc\/v1\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/products\/shipping_classes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/shipping_classes\/batch"}]}},"\/wc\/v1\/products\/tags":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/tags"}]}},"\/wc\/v1\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Tag name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/products\/tags\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tag name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/tags\/batch"}]}},"\/wc\/v1\/products":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Use WP Query arguments to modify the response; private query vars require appropriate authorisation.","required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"sku":{"description":"Limit result set to products with a specific SKU.","type":"string","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"type":{"default":"simple","description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price.","type":"string","required":false},"date_on_sale_to":{"description":"End data of sale price.","type":"string","required":false},"virtual":{"default":false,"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"download_type":{"default":"standard","description":"Download type, this controls the schema on the front-end.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"default":true,"description":"Controls whether or not the product is listed as \"in stock\" or \"out of stock\" on the frontend.","type":"boolean","required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Allow reviews.","type":"boolean","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"List of variations.","type":"array","items":{"type":"object","properties":{"id":{"description":"Variation ID.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"The date the variation was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the variation was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"Variation URL.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Unique identifier.","type":"string","context":["view","edit"]},"price":{"description":"Current variation price.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Variation regular price.","type":"string","context":["view","edit"]},"sale_price":{"description":"Variation sale price.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Start date of sale price.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"End data of sale price.","type":"string","context":["view","edit"]},"on_sale":{"description":"Shows if the variation is on sale.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Shows if the variation can be bought.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"If the variation is visible.","type":"boolean","context":["view","edit"]},"virtual":{"description":"If the variation is virtual.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"List of downloadable files.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Tax status.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Tax class.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Stock quantity.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Controls whether or not the variation is listed as \"in stock\" or \"out of stock\" on the front-end.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Shows if back-orders are allowed.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Shows if the variation is on back-order.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Variation weight (kg).","type":"string","context":["view","edit"]},"dimensions":{"description":"Variation dimensions.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Shipping class slug.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"Shipping class ID.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Variation image data.","type":"object","context":["view","edit"],"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"List of attributes.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products"}]}},"\/wc\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price.","type":"string","required":false},"date_on_sale_to":{"description":"End data of sale price.","type":"string","required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"download_type":{"description":"Download type, this controls the schema on the front-end.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"description":"Controls whether or not the product is listed as \"in stock\" or \"out of stock\" on the frontend.","type":"boolean","required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"List of variations.","type":"array","items":{"type":"object","properties":{"id":{"description":"Variation ID.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"The date the variation was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the variation was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"Variation URL.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Unique identifier.","type":"string","context":["view","edit"]},"price":{"description":"Current variation price.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Variation regular price.","type":"string","context":["view","edit"]},"sale_price":{"description":"Variation sale price.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Start date of sale price.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"End data of sale price.","type":"string","context":["view","edit"]},"on_sale":{"description":"Shows if the variation is on sale.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Shows if the variation can be bought.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"If the variation is visible.","type":"boolean","context":["view","edit"]},"virtual":{"description":"If the variation is virtual.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"List of downloadable files.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Tax status.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Tax class.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Stock quantity.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Controls whether or not the variation is listed as \"in stock\" or \"out of stock\" on the front-end.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Shows if back-orders are allowed.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Shows if the variation is on back-order.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Variation weight (kg).","type":"string","context":["view","edit"]},"dimensions":{"description":"Variation dimensions.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Shipping class slug.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"Shipping class ID.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Variation image data.","type":"object","context":["view","edit"],"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"List of attributes.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"description":"Whether to bypass bin and force deletion.","type":"boolean","required":false}}}]},"\/wc\/v1\/products\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price.","type":"string","required":false},"date_on_sale_to":{"description":"End data of sale price.","type":"string","required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"download_type":{"description":"Download type, this controls the schema on the front-end.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"description":"Controls whether or not the product is listed as \"in stock\" or \"out of stock\" on the frontend.","type":"boolean","required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"List of variations.","type":"array","items":{"type":"object","properties":{"id":{"description":"Variation ID.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"The date the variation was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the variation was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"Variation URL.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Unique identifier.","type":"string","context":["view","edit"]},"price":{"description":"Current variation price.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Variation regular price.","type":"string","context":["view","edit"]},"sale_price":{"description":"Variation sale price.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Start date of sale price.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"End data of sale price.","type":"string","context":["view","edit"]},"on_sale":{"description":"Shows if the variation is on sale.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Shows if the variation can be bought.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"If the variation is visible.","type":"boolean","context":["view","edit"]},"virtual":{"description":"If the variation is virtual.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"List of downloadable files.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Tax status.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Tax class.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Stock quantity.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Controls whether or not the variation is listed as \"in stock\" or \"out of stock\" on the front-end.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Shows if back-orders are allowed.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Shows if the variation is on back-order.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Variation weight (kg).","type":"string","context":["view","edit"]},"dimensions":{"description":"Variation dimensions.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Shipping class slug.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"Shipping class ID.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Variation image data.","type":"object","context":["view","edit"],"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"List of attributes.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/products\/batch"}]}},"\/wc\/v1\/reports\/sales":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Report period.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Return sales for a specific start date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false},"date_max":{"description":"Return sales for a specific end date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/reports\/sales"}]}},"\/wc\/v1\/reports\/top_sellers":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Report period.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Return sales for a specific start date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false},"date_max":{"description":"Return sales for a specific end date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/reports\/top_sellers"}]}},"\/wc\/v1\/reports":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/reports"}]}},"\/wc\/v1\/taxes\/classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tax class name.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/taxes\/classes"}]}},"\/wc\/v1\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"slug":{"description":"Unique slug for the resource.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/taxes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Sort collection by object attribute.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Sort by tax class.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false}}},{"methods":["POST"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode \/ ZIP.","type":"string","required":false},"city":{"description":"City name.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"default":1,"description":"Tax priority.","type":"integer","required":false},"compound":{"default":false,"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"default":true,"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"default":"standard","description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/taxes"}]}},"\/wc\/v1\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode \/ ZIP.","type":"string","required":false},"city":{"description":"City name.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/taxes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode \/ ZIP.","type":"string","required":false},"city":{"description":"City name.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/taxes\/batch"}]}},"\/wc\/v1\/webhooks":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limit result set to webhooks assigned a specific status.","type":"string","enum":["all","active","paused","disabled"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"default":"active","description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Webhook topic.","required":true},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false},"delivery_url":{"type":"string","description":"Webhook delivery URL.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/webhooks"}]}},"\/wc\/v1\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Webhook topic.","type":"string","required":false},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v1\/webhooks\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Webhook topic.","type":"string","required":false},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v1\/webhooks\/batch"}]}},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Unique identifier for the webhook.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Unique identifier for the webhook.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v2\/coupons":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limit result set to resources with a specific code.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Coupon code.","type":"string","required":true},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"default":false,"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/coupons"}]}},"\/wc\/v2\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"code":{"description":"Coupon code.","type":"string","required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v2\/coupons\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Coupon code.","type":"string","required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/coupons\/batch"}]}},"\/wc\/v2\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v2\/customers":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by object attribute.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limit result set to resources with a specific email.","type":"string","format":"email","required":false},"role":{"description":"Limit result set to resources with a specific role.","type":"string","default":"customer","enum":["all","no_private_message","customer","bbp_spectator","bbp_participant","bbp_senior_moderator","bbp_moderator","SILVER Member","BRONZE Member","GOLD Member","FOUNDER Member","shop_manager","editor","administrator","bbp_keymaster","author","bbp_blocked"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"New user email address.","required":true},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"New user username.","type":"string","required":true},"password":{"description":"New user password.","type":"string","required":true},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/customers"}]}},"\/wc\/v2\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"email":{"description":"The email address for the customer.","type":"string","format":"email","required":false},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"Customer login name.","type":"string","required":false},"password":{"description":"Customer password.","type":"string","required":false},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false},"reassign":{"default":0,"type":"integer","description":"ID to reassign posts to.","required":false}}}]},"\/wc\/v2\/customers\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"The email address for the customer.","type":"string","format":"email","required":false},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"Customer login name.","type":"string","required":false},"password":{"description":"Customer password.","type":"string","required":false},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/customers\/batch"}]}},"\/wc\/v2\/orders\/network":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limit result set to orders assigned a specific status.","type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/orders\/network"}]}},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Limit result to customers or internal notes.","type":"string","enum":["any","customer","internal"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"note":{"type":"string","description":"Order note content.","required":true},"customer_note":{"default":false,"description":"If true, the note will be shown to customers and they will be notified. If false, the note will be for admin reference only.","type":"boolean","required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"order_id":{"description":"The order ID.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"amount":{"description":"Refund amount.","type":"string","required":false},"reason":{"description":"Reason for refund.","type":"string","required":false},"refunded_by":{"description":"User ID of user who created the refund.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"When true, the payment gateway API is used to generate the refund.","type":"boolean","required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/orders":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limit result set to orders assigned a specific status.","type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"status":{"default":"pending","description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"GBP","description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/orders"}]}},"\/wc\/v2\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"status":{"description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v2\/orders\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"status":{"description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/orders\/batch"}]}},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc\/v2\/products\/attributes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Name for the resource.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"default":"select","description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/attributes"}]}},"\/wc\/v2\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/products\/attributes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/attributes\/batch"}]}},"\/wc\/v2\/products\/categories":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"default":"default","description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/categories"}]}},"\/wc\/v2\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/products\/categories\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/categories\/batch"}]}},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"review":{"type":"string","description":"Review content.","required":true},"date_created":{"description":"The date the review was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the review was created, as GMT.","type":["null","string"],"required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false},"name":{"type":"string","description":"Name of the reviewer.","required":true},"email":{"type":"string","description":"Email of the reviewer.","required":true}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"date_created":{"description":"The date the review was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the review was created, as GMT.","type":["null","string"],"required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false},"name":{"description":"Reviewer name.","type":"string","required":false},"email":{"description":"Reviewer email.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"date_created":{"description":"The date the review was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the review was created, as GMT.","type":["null","string"],"required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false},"name":{"description":"Reviewer name.","type":"string","required":false},"email":{"description":"Reviewer email.","type":"string","required":false}}}]},"\/wc\/v2\/products\/shipping_classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/shipping_classes"}]}},"\/wc\/v2\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/products\/shipping_classes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/shipping_classes\/batch"}]}},"\/wc\/v2\/products\/tags":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/tags"}]}},"\/wc\/v2\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Tag name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/products\/tags\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tag name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/tags\/batch"}]}},"\/wc\/v2\/products":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute. Use the taxonomy name\/attribute slug.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limit result set to products in stock or out of stock.","type":"boolean","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"type":{"default":"simple","description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, as GMT.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"default":true,"description":"Controls whether or not the product is listed as \"in stock\" or \"out of stock\" on the frontend.","type":"boolean","required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Allow reviews.","type":"boolean","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"List of grouped products ID.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, as GMT.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"description":"Controls whether or not the product is listed as \"in stock\" or \"out of stock\" on the frontend.","type":"boolean","required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"List of grouped products ID.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"description":"Whether to bypass bin and force deletion.","type":"boolean","required":false}}}]},"\/wc\/v2\/products\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, as GMT.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"description":"Controls whether or not the product is listed as \"in stock\" or \"out of stock\" on the frontend.","type":"boolean","required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"List of grouped products ID.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/products\/batch"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute. Use the taxonomy name\/attribute slug.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limit result set to products in stock or out of stock.","type":"boolean","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, as GMT.","type":["null","string"],"required":false},"visible":{"default":true,"description":"Define if the variation is visible on the product's page.","type":"boolean","required":false},"virtual":{"default":false,"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at variation level.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"default":true,"description":"Controls whether or not the variation is listed as \"in stock\" or \"out of stock\" on the front-end.","type":"boolean","required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, as GMT.","type":["null","string"],"required":false},"visible":{"description":"Define if the variation is visible on the product's page.","type":"boolean","required":false},"virtual":{"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at variation level.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"description":"Controls whether or not the variation is listed as \"in stock\" or \"out of stock\" on the front-end.","type":"boolean","required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Unique identifier.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, as GMT.","type":["null","string"],"required":false},"visible":{"description":"Define if the variation is visible on the product's page.","type":"boolean","required":false},"virtual":{"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at variation level.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"in_stock":{"description":"Controls whether or not the variation is listed as \"in stock\" or \"out of stock\" on the front-end.","type":"boolean","required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]},"position":{"description":"Image position. 0 means that the image is featured.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v2\/reports\/sales":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Report period.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Return sales for a specific start date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false},"date_max":{"description":"Return sales for a specific end date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/reports\/sales"}]}},"\/wc\/v2\/reports\/top_sellers":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Report period.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Return sales for a specific start date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false},"date_max":{"description":"Return sales for a specific end date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/reports\/top_sellers"}]}},"\/wc\/v2\/reports":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/reports"}]}},"\/wc\/v2\/settings":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/settings"}]}},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"value":{"description":"Setting value.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"id":{"description":"Unique identifier for the resource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"value":{"description":"Setting value.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v2\/shipping\/zones":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"name":{"type":"string","description":"Shipping zone name.","required":true},"order":{"description":"Shipping zone order.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/shipping\/zones"}]}},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"name":{"description":"Shipping zone name.","type":"string","required":false},"order":{"description":"Shipping zone order.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"code":{"description":"Shipping zone location code.","type":"string","required":false},"type":{"description":"Shipping zone location type.","type":"string","enum":["postcode","state","country","continent"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"order":{"description":"Shipping method sort order.","type":"integer","required":false},"enabled":{"description":"Shipping method enabled status.","type":"boolean","required":false},"settings":{"description":"Shipping method settings.","type":"object","properties":{"id":{"description":"A unique identifier for the setting.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"A human readable label for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"A human readable description for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type of setting.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Setting value.","type":"string","context":["view","edit"]},"default":{"description":"Default value for the setting.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Additional help text shown to the user about the setting.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Placeholder text to be displayed in text inputs.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"Shipping method ID.","required":true}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"instance_id":{"description":"Unique ID for the instance.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"instance_id":{"description":"Unique ID for the instance.","type":"integer","required":false},"order":{"description":"Shipping method sort order.","type":"integer","required":false},"enabled":{"description":"Shipping method enabled status.","type":"boolean","required":false},"settings":{"description":"Shipping method settings.","type":"object","properties":{"id":{"description":"A unique identifier for the setting.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"A human readable label for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"A human readable description for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type of setting.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Setting value.","type":"string","context":["view","edit"]},"default":{"description":"Default value for the setting.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Additional help text shown to the user about the setting.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Placeholder text to be displayed in text inputs.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"instance_id":{"description":"Unique ID for the instance.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v2\/taxes\/classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tax class name.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/taxes\/classes"}]}},"\/wc\/v2\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unique slug for the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Unique slug for the resource.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/taxes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Sort collection by object attribute.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Sort by tax class.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false}}},{"methods":["POST"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode \/ ZIP.","type":"string","required":false},"city":{"description":"City name.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"default":1,"description":"Tax priority.","type":"integer","required":false},"compound":{"default":false,"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"default":true,"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"default":"standard","description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/taxes"}]}},"\/wc\/v2\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode \/ ZIP.","type":"string","required":false},"city":{"description":"City name.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/taxes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode \/ ZIP.","type":"string","required":false},"city":{"description":"City name.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/taxes\/batch"}]}},"\/wc\/v2\/webhooks":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limit result set to webhooks assigned a specific status.","type":"string","enum":["all","active","paused","disabled"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"default":"active","description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Webhook topic.","required":true},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false},"delivery_url":{"type":"string","description":"Webhook delivery URL.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/webhooks"}]}},"\/wc\/v2\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Webhook topic.","type":"string","required":false},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v2\/webhooks\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Webhook topic.","type":"string","required":false},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/webhooks\/batch"}]}},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Unique identifier for the webhook.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Unique identifier for the webhook.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/wc\/v2\/system_status":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/system_status"}]}},"\/wc\/v2\/system_status\/tools":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/system_status\/tools"}]}},"\/wc\/v2\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"A unique identifier for the tool.","type":"string","required":false},"name":{"description":"Tool name.","type":"string","required":false},"action":{"description":"What running the tool will do.","type":"string","required":false},"description":{"description":"Tool description.","type":"string","required":false},"success":{"description":"Did the tool run successfully?","type":"boolean","required":false},"message":{"description":"Tool return message.","type":"string","required":false}}}]},"\/wc\/v2\/shipping_methods":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/shipping_methods"}]}},"\/wc\/v2\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v2\/payment_gateways":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v2\/payment_gateways"}]}},"\/wc\/v2\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"title":{"description":"Payment gateway title on checkout.","type":"string","required":false},"description":{"description":"Payment gateway description on checkout.","type":"string","required":false},"order":{"description":"Payment gateway sort order.","type":"integer","required":false},"enabled":{"description":"Payment gateway enabled status.","type":"boolean","required":false},"settings":{"description":"Payment gateway settings.","type":"object","properties":{"id":{"description":"A unique identifier for the setting.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"A human readable label for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"A human readable description for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type of setting.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Setting value.","type":"string","context":["view","edit"]},"default":{"description":"Default value for the setting.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Additional help text shown to the user about the setting.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Placeholder text to be displayed in text inputs.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}}]},"\/wc\/v3\/coupons":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limit result set to resources with a specific code.","type":"string","required":false}}},{"methods":["POST"],"args":{"code":{"description":"Coupon code.","type":"string","required":true},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"default":false,"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/coupons"}]}},"\/wc\/v3\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"code":{"description":"Coupon code.","type":"string","required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v3\/coupons\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Coupon code.","type":"string","required":false},"amount":{"description":"The amount of discount. Should always be numeric, even if setting a percentage.","type":["number","string"],"required":false},"status":{"description":"The status of the coupon. Should always be draft, published, or pending review","type":"string","required":false},"discount_type":{"description":"Determines the type of discount that will be applied.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Coupon description.","type":"string","required":false},"date_expires":{"description":"The date the coupon expires, in the site's timezone.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"The date the coupon expires, as GMT.","type":["null","string"],"required":false},"individual_use":{"description":"If true, the coupon can only be used individually. Other applied coupons will be removed from the basket.","type":"boolean","required":false},"product_ids":{"description":"List of product IDs the coupon can be used on.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"List of product IDs the coupon cannot be used on.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"How many times the coupon can be used in total.","type":"integer","required":false},"usage_limit_per_user":{"description":"How many times the coupon can be used per customer.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Max number of items in the basket the coupon can be applied to.","type":"integer","required":false},"free_shipping":{"description":"If true and if the free shipping method requires a coupon, this coupon will enable free shipping.","type":"boolean","required":false},"product_categories":{"description":"List of category IDs the coupon applies to.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"List of category IDs the coupon does not apply to.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"If true, this coupon will not be applied to items that have sale prices.","type":"boolean","required":false},"minimum_amount":{"description":"Minimum order amount that needs to be in the basket before coupon applies.","type":["number","string"],"required":false},"maximum_amount":{"description":"Maximum order amount allowed when using the coupon.","type":["number","string"],"required":false},"email_restrictions":{"description":"List of email addresses that can use this coupon.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/coupons\/batch"}]}},"\/wc\/v3\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v3\/customers":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by object attribute.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limit result set to resources with a specific email.","type":"string","format":"email","required":false},"role":{"description":"Limit result set to resources with a specific role.","type":"string","default":"customer","enum":["all","no_private_message","customer","bbp_spectator","bbp_participant","bbp_senior_moderator","bbp_moderator","SILVER Member","BRONZE Member","GOLD Member","FOUNDER Member","shop_manager","editor","administrator","bbp_keymaster","author","bbp_blocked"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"New user email address.","required":true},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"New user username.","type":"string","required":true},"password":{"description":"New user password.","type":"string","required":true},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/customers"}]}},"\/wc\/v3\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"email":{"description":"The email address for the customer.","type":"string","format":"email","required":false},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"Customer login name.","type":"string","required":false},"password":{"description":"Customer password.","type":"string","required":false},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false},"reassign":{"default":0,"type":"integer","description":"ID to reassign posts to.","required":false}}}]},"\/wc\/v3\/customers\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"The email address for the customer.","type":"string","format":"email","required":false},"first_name":{"description":"Customer first name.","type":"string","required":false},"last_name":{"description":"Customer last name.","type":"string","required":false},"username":{"description":"Customer login name.","type":"string","required":false},"password":{"description":"Customer password.","type":"string","required":false},"billing":{"description":"List of billing address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"List of shipping address data.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"ISO code of the country.","type":"string","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/customers\/batch"}]}},"\/wc\/v3\/layout-templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"area":{"description":"Area to get templates for.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/layout-templates"}]}},"\/wc\/v3\/layout-templates\/(?P<id>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false}}}]},"\/wc\/v3\/orders\/network":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limit result set to orders assigned a specific status.","type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/orders\/network"}]}},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Limit result to customers or internal notes.","type":"string","enum":["any","customer","internal"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"note":{"type":"string","description":"Order note content.","required":true},"customer_note":{"default":false,"description":"If true, the note will be shown to customers and they will be notified. If false, the note will be for admin reference only.","type":"boolean","required":false},"added_by_user":{"default":false,"description":"If true, this note will be attributed to the current user. If false, the note will be attributed to the system.","type":"boolean","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"order_id":{"description":"The order ID.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"amount":{"description":"Refund amount.","type":"string","required":false},"reason":{"description":"Reason for refund.","type":"string","required":false},"refunded_by":{"description":"User ID of user who created the refund.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"When true, the payment gateway API is used to generate the refund.","type":"boolean","required":false},"api_restock":{"default":true,"description":"When true, refunded items are restocked.","type":"boolean","required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"The order ID.","type":"integer","required":false},"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/orders":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limit result set to orders which have specific statuses.","type":"array","items":{"type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Limit result set to orders assigned a specific customer.","type":"integer","required":false},"product":{"description":"Limit result set to orders assigned a specific product.","type":"integer","required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limit result set to orders created via specific sources (e.g. checkout, admin).","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"created_via":{"description":"Shows where the order was created.","type":"string","required":false},"status":{"default":"pending","description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"GBP","description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"manual_update":{"default":false,"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/orders"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"created_via":{"description":"Shows where the order was created.","type":"string","required":false},"status":{"description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v3\/orders\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Parent order ID.","type":"integer","required":false},"created_via":{"description":"Shows where the order was created.","type":"string","required":false},"status":{"description":"Order status.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Currency the order was created with, in ISO format.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"User ID who owns the order. 0 for guests.","type":"integer","required":false},"customer_note":{"description":"Note left by customer during checkout.","type":"string","required":false},"billing":{"description":"Billing address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]},"email":{"description":"Email address.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Phone number.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Shipping address.","type":"object","properties":{"first_name":{"description":"First name.","type":"string","context":["view","edit"]},"last_name":{"description":"Last name.","type":"string","context":["view","edit"]},"company":{"description":"Company name.","type":"string","context":["view","edit"]},"address_1":{"description":"Address line 1","type":"string","context":["view","edit"]},"address_2":{"description":"Address line 2","type":"string","context":["view","edit"]},"city":{"description":"City name.","type":"string","context":["view","edit"]},"state":{"description":"ISO code or name of the county, state, province or district.","type":"string","context":["view","edit"]},"postcode":{"description":"Postal code.","type":"string","context":["view","edit"]},"country":{"description":"Country code in ISO 3166-1 alpha-2 format.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Payment method ID.","type":"string","required":false},"payment_method_title":{"description":"Payment method title.","type":"string","required":false},"transaction_id":{"description":"Unique transaction ID.","type":"string","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Line items data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Product name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Product ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Variation ID, if applicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Quantity ordered.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tax class of product.","type":"string","context":["view","edit"]},"subtotal":{"description":"Line subtotal (before discounts).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Line subtotal tax (before discounts).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"]},"total":{"description":"Tax total.","type":"string","context":["view","edit"]},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Product SKU.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Product price.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Shipping lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Shipping method name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Shipping method ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Shipping instance ID.","type":"string","context":["view","edit"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Fee lines data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Fee name.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Tax class of fee.","type":"string","context":["view","edit"]},"tax_status":{"description":"Tax status of fee.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Line total (after discounts).","type":"string","context":["view","edit"]},"total_tax":{"description":"Line total tax (after discounts).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Line taxes.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Tax rate ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Tax total.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Tax subtotal.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Coupons line data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Item ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Coupon code.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Discount total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Discount total tax.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Discount type.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta data.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Define if the order is paid. It will set the status to processing and reduce stock items.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/orders\/batch"}]}},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Unique identifier for the attribute of the terms.","type":"integer","required":false},"name":{"description":"Term name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"menu_order":{"description":"Menu order, used to custom sort the resource.","type":"integer","required":false}}}]},"\/wc\/v3\/products\/attributes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Name for the resource.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"default":"select","description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/attributes"}]}},"\/wc\/v3\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/products\/attributes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Attribute name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"type":{"description":"Type of attribute.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Default sort order.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Enable\/Disable attribute archives.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/attributes\/batch"}]}},"\/wc\/v3\/products\/categories":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"default":"default","description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/categories"}]}},"\/wc\/v3\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/products\/categories\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Category name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"parent":{"description":"The ID for the parent of the resource.","type":"integer","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false},"display":{"description":"Category archive display type.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/categories\/batch"}]}},"\/wc\/v3\/products\/custom-fields\/names":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"order":{"description":"Order sort items ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/custom-fields\/names"}]}},"\/wc\/v3\/products\/reviews":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to reviews published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Limit result set to reviews assigned to specific user IDs.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"Ensure result set excludes reviews assigned to specific user IDs.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Limit result set to that from a specific author email.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Limit result set to reviews assigned to specific product IDs.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Limit result set to reviews assigned a specific status.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the product.","type":"integer","required":true},"product_name":{"description":"Product name.","type":"string","required":false},"status":{"default":"approved","description":"Status of the review.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Name of the reviewer.","required":true},"reviewer_email":{"type":"string","description":"Email of the reviewer.","required":true},"review":{"type":"string","description":"Review content.","required":true},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/reviews"}]}},"\/wc\/v3\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"product_id":{"description":"Unique identifier for the product that the review belongs to.","type":"integer","required":false},"product_name":{"description":"Product name.","type":"string","required":false},"status":{"description":"Status of the review.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Reviewer name.","type":"string","required":false},"reviewer_email":{"description":"Reviewer email.","type":"string","format":"email","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v3\/products\/reviews\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the product that the review belongs to.","type":"integer","required":false},"product_name":{"description":"Product name.","type":"string","required":false},"status":{"description":"Status of the review.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Reviewer name.","type":"string","required":false},"reviewer_email":{"description":"Reviewer email.","type":"string","format":"email","required":false},"review":{"description":"The content of the review.","type":"string","required":false},"rating":{"description":"Review rating (0 to 5).","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/reviews\/batch"}]}},"\/wc\/v3\/products\/shipping_classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/shipping_classes"}]}},"\/wc\/v3\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/products\/shipping_classes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/shipping_classes\/batch"}]}},"\/wc\/v3\/products\/shipping_classes\/slug-suggestion":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Shipping class name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/shipping_classes\/slug-suggestion"}]}},"\/wc\/v3\/products\/tags":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by resource attribute.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide resources not assigned to any products.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Limit result set to resources assigned to a specific product.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to resources with a specific slug.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Name for the resource.","required":true},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/tags"}]}},"\/wc\/v3\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Tag name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/products\/tags\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tag name.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the resource unique to its type.","type":"string","required":false},"description":{"description":"HTML description of the resource.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/tags\/batch"}]}},"\/wc\/v3\/products":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute. Use the taxonomy name\/attribute slug.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limit results to those with a SKU that partial matches a string. This argument takes precedence over 'sku'.","type":"string","required":false},"search_name_or_sku":{"description":"Limit results to those with a name or SKU that partial matches a string. This argument takes precedence over 'search', 'sku' and 'search_sku'.","type":"string","required":false},"search_fields":{"description":"Limit search to specific fields when used with search parameter. Available fields: name, sku, global_unique_id, description, short_description. This argument takes precedence over all other search parameters.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limit result set to products with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude products with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limit result set to products with any of the types.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"exclude_types":{"description":"Exclude products with any of the types from result set.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"downloadable":{"description":"Limit result set to downloadable products.","type":"boolean","required":false},"virtual":{"description":"Limit result set to virtual products.","type":"boolean","required":false},"pos_products_only":{"description":"Limit result set to products visible in Point of Sale.","type":"boolean","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"description":"Whether to bypass bin and force deletion.","type":"boolean","required":false}}}]},"\/wc\/v3\/products\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/batch"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false}}}]},"\/wc\/v3\/products\/suggested-products":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limit result set to products assigned a specific type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"featured":{"description":"Limit result set to featured products.","type":"boolean","required":false},"category":{"description":"Limit result set to products assigned a specific category ID.","type":"string","required":false},"tag":{"description":"Limit result set to products assigned a specific tag ID.","type":"string","required":false},"shipping_class":{"description":"Limit result set to products assigned a specific shipping class ID.","type":"string","required":false},"attribute":{"description":"Limit result set to products with a specific attribute. Use the taxonomy name\/attribute slug.","type":"string","required":false},"attribute_term":{"description":"Limit result set to products with a specific attribute term ID (requires an assigned attribute).","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limit result set to products in stock or out of stock.","type":"boolean","required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"categories":{"description":"Limit result set to specific product categorie ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limit result set to specific product tag ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limit result set to specific amount of suggested products.","type":"integer","default":5,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/products\/suggested-products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"Product name.","type":"string","required":false},"slug":{"description":"Product slug.","type":"string","required":false},"date_created":{"description":"The date the product was created, in the site's timezone.","type":["null","string"],"required":false},"date_created_gmt":{"description":"The date the product was created, as GMT.","type":["null","string"],"required":false},"type":{"description":"Product type.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Product status (post status).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Featured product.","type":"boolean","required":false},"catalog_visibility":{"description":"Catalogue visibility.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Product description.","type":"string","required":false},"short_description":{"description":"Product short description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Product regular price.","type":"string","required":false},"sale_price":{"description":"Product sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"virtual":{"description":"If the product is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the product is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"external_url":{"description":"Product external URL. Only for external products.","type":"string","format":"uri","required":false},"button_text":{"description":"Product external button text. Only for external products.","type":"string","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at product level.","type":"boolean","required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Allow one item to be bought in a single order.","type":"boolean","required":false},"weight":{"description":"Product weight (kg).","type":"string","required":false},"dimensions":{"description":"Product dimensions.","type":"object","properties":{"length":{"description":"Product length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Product width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Product height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"reviews_allowed":{"description":"Allow reviews.","type":"boolean","required":false},"post_password":{"description":"Post password.","type":"string","required":false},"upsell_ids":{"description":"List of up-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"List of cross-sell products IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Product parent ID.","type":"integer","required":false},"purchase_note":{"description":"Optional note to send the customer after purchase.","type":"string","required":false},"categories":{"description":"List of categories.","type":"array","items":{"type":"object","properties":{"id":{"description":"Category ID.","type":"integer","context":["view","edit"]},"name":{"description":"Category name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Category slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"List of brands.","type":"array","items":{"type":"object","properties":{"id":{"description":"Brand ID.","type":"integer","context":["view","edit"]},"name":{"description":"Brand name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Brand slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"List of tags.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tag ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tag name.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tag slug.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"List of images.","type":"array","items":{"type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"position":{"description":"Attribute position.","type":"integer","context":["view","edit"]},"visible":{"description":"Define if the attribute is visible on the \"Additional information\" tab in the product's page.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Define if the attribute can be used as variation.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"List of available term names of the attribute.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Defaults variation attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Attribute slug."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"id":{"description":"Unique identifier for the variation.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Unique identifier for the variable product.","type":"integer","required":false},"delete":{"description":"Deletes unused variations.","type":"boolean","required":false},"default_values":{"description":"Default values for generated variations.","type":"object","properties":{"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation description.","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock Keeping Unit.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN or ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation regular price.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation sale price.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Start date of sale price, in the site's timezone.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Start date of sale price, as GMT.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"End date of sale price, in the site's timezone.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"End date of sale price, in the site's timezone.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation status.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"If the variation is virtual.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"If the variation is downloadable.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Number of times downloadable files can be downloaded after purchase.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Number of days until access to downloadable files expires.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tax status.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tax class.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock management at variation level.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock quantity.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Low Stock amount for the variation.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation weight (kg).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Shipping class slug.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Menu order, used to custom sort products.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}},"required":false},"description":{"description":"Variation description.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN or ISBN.","type":"string","required":false},"regular_price":{"description":"Variation regular price.","type":"string","required":false},"sale_price":{"description":"Variation sale price.","type":"string","required":false},"date_on_sale_from":{"description":"Start date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Start date of sale price, as GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"End date of sale price, in the site's timezone.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Variation status.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"If the variation is virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"If the variation is downloadable.","type":"boolean","required":false},"downloads":{"description":"List of downloadable files.","type":"array","items":{"type":"object","properties":{"id":{"description":"File ID.","type":"string","context":["view","edit"]},"name":{"description":"File name.","type":"string","context":["view","edit"]},"file":{"description":"File URL.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Number of times downloadable files can be downloaded after purchase.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Number of days until access to downloadable files expires.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Tax status.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Tax class.","type":"string","required":false},"manage_stock":{"default":false,"description":"Stock management at variation level.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Stock quantity.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controls the stock status of the product.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"If managing stock, this controls if back-orders are allowed.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Variation weight (kg).","type":"string","required":false},"dimensions":{"description":"Variation dimensions.","type":"object","properties":{"length":{"description":"Variation length (cm).","type":"string","context":["view","edit"]},"width":{"description":"Variation width (cm).","type":"string","context":["view","edit"]},"height":{"description":"Variation height (cm).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Shipping class slug.","type":"string","required":false},"image":{"description":"Variation image data.","type":"object","properties":{"id":{"description":"Image ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"The date the image was created, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"The date the image was created, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"The date the image was last modified, in the site's timezone.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"The date the image was last modified, as GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Image URL.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Image name.","type":"string","context":["view","edit"]},"alt":{"description":"Image alternative text.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"List of attributes.","type":"array","items":{"type":"object","properties":{"id":{"description":"Attribute ID.","type":"integer","context":["view","edit"]},"name":{"description":"Attribute name.","type":"string","context":["view","edit"]},"option":{"description":"Selected attribute term name.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Menu order, used to custom sort products.","type":"integer","required":false},"meta_data":{"description":"Meta data.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta key.","type":"string","context":["view","edit"]},"value":{"description":"Meta value.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false}}}]},"\/wc\/v3\/refunds":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Number of decimal points to use in each resource.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/refunds"}]}},"\/wc\/v3\/reports\/sales":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Report period.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Return sales for a specific start date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false},"date_max":{"description":"Return sales for a specific end date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/sales"}]}},"\/wc\/v3\/reports\/top_sellers":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Report period.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Return sales for a specific start date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false},"date_max":{"description":"Return sales for a specific end date; the date needs to be in the YYYY-MM-DD format.","type":"string","format":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/top_sellers"}]}},"\/wc\/v3\/reports\/orders\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/orders\/totals"}]}},"\/wc\/v3\/reports\/products\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/products\/totals"}]}},"\/wc\/v3\/reports\/customers\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/customers\/totals"}]}},"\/wc\/v3\/reports\/coupons\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/coupons\/totals"}]}},"\/wc\/v3\/reports\/reviews\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports\/reviews\/totals"}]}},"\/wc\/v3\/reports":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/reports"}]}},"\/wc\/v3\/settings":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/settings"}]}},"\/wc\/v3\/settings\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/settings\/batch"}]}},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"value":{"description":"Setting value.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"id":{"description":"Unique identifier for the resource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Settings group ID.","type":"string","required":false},"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"value":{"description":"Setting value.","type":["null","object","string","number","boolean","integer","array"],"required":false}}}]},"\/wc\/v3\/shipping\/zones":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"name":{"type":"string","description":"Shipping zone name.","required":true},"order":{"description":"Shipping zone order.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/shipping\/zones"}]}},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"name":{"description":"Shipping zone name.","type":"string","required":false},"order":{"description":"Shipping zone order.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique ID for the resource.","type":"integer","required":false},"code":{"description":"Shipping zone location code.","type":"string","required":false},"type":{"description":"Shipping zone location type.","type":"string","enum":["postcode","state","country","continent"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"order":{"description":"Shipping method sort order.","type":"integer","required":false},"enabled":{"description":"Shipping method enabled status.","type":"boolean","required":false},"settings":{"description":"Shipping method settings.","type":"object","properties":{"id":{"description":"A unique identifier for the setting.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"A human readable label for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"A human readable description for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type of setting.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Setting value.","type":"string","context":["view","edit"]},"default":{"description":"Default value for the setting.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Additional help text shown to the user about the setting.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Placeholder text to be displayed in text inputs.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"Shipping method ID.","required":true}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"instance_id":{"description":"Unique ID for the instance.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"instance_id":{"description":"Unique ID for the instance.","type":"integer","required":false},"order":{"description":"Shipping method sort order.","type":"integer","required":false},"enabled":{"description":"Shipping method enabled status.","type":"boolean","required":false},"settings":{"description":"Shipping method settings.","type":"object","properties":{"id":{"description":"A unique identifier for the setting.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"A human readable label for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"A human readable description for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type of setting.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Setting value.","type":"string","context":["view","edit"]},"default":{"description":"Default value for the setting.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Additional help text shown to the user about the setting.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Placeholder text to be displayed in text inputs.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"Unique ID for the zone.","type":"integer","required":false},"instance_id":{"description":"Unique ID for the instance.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Whether to bypass bin and force deletion.","required":false}}}]},"\/wc\/v3\/taxes\/classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tax class name.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/taxes\/classes"}]}},"\/wc\/v3\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unique slug for the resource.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Unique slug for the resource.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/taxes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Sort collection by object attribute.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Sort by tax class.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false}}},{"methods":["POST"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"default":1,"description":"Tax priority.","type":"integer","required":false},"compound":{"default":false,"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"default":true,"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"default":"standard","description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"List of postcodes \/ ZIPs. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"List of city names. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/taxes"}]}},"\/wc\/v3\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"List of postcodes \/ ZIPs. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"List of city names. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/taxes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"Country ISO 3166 code.","type":"string","required":false},"state":{"description":"State code.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Tax rate.","type":"string","required":false},"name":{"description":"Tax rate name.","type":"string","required":false},"priority":{"description":"Tax priority.","type":"integer","required":false},"compound":{"description":"Whether or not this is a compound rate.","type":"boolean","required":false},"shipping":{"description":"Whether or not this tax rate also gets applied to shipping.","type":"boolean","required":false},"order":{"description":"Indicates the order that will appear in queries.","type":"integer","required":false},"class":{"description":"Tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"List of postcodes \/ ZIPs. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"List of city names. Introduced in WooCommerce 5.3.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/taxes\/batch"}]}},"\/wc\/v3\/variations":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limit result set to those of particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limit result set to products with a specific slug.","type":"string","required":false},"status":{"default":"any","description":"Limit result set to products assigned a specific status.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limit result set to products with specific SKU(s). Use commas to separate.","type":"string","required":false},"tax_class":{"description":"Limit result set to products with a specific tax class.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limit result set to products on sale.","type":"boolean","required":false},"min_price":{"description":"Limit result set to products based on a minimum price.","type":"string","required":false},"max_price":{"description":"Limit result set to products based on a maximum price.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Limit result set to products with specified stock status.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Attribute slug."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/variations"}]}},"\/wc\/v3\/webhooks":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to resources published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to resources published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limit result set to webhooks assigned a specific status.","type":"string","enum":["all","active","paused","disabled"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"default":"active","description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Webhook topic.","required":true},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false},"delivery_url":{"type":"string","description":"Webhook delivery URL.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/webhooks"}]}},"\/wc\/v3\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Webhook topic.","type":"string","required":false},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the resource.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Required to be true, as resource does not support binning.","required":false}}}]},"\/wc\/v3\/webhooks\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"A friendly name for the webhook.","type":"string","required":false},"status":{"description":"Webhook status.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Webhook topic.","type":"string","required":false},"secret":{"description":"Secret key used to generate a hash of the delivered webhook and provided in the request headers. This will default to a MD5 hash from the current user's ID|username if not provided.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/webhooks\/batch"}]}},"\/wc\/v3\/system_status":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/system_status"}]}},"\/wc\/v3\/system_status\/tools":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/system_status\/tools"}]}},"\/wc\/v3\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"A unique identifier for the tool.","type":"string","required":false},"name":{"description":"Tool name.","type":"string","required":false},"action":{"description":"What running the tool will do.","type":"string","required":false},"description":{"description":"Tool description.","type":"string","required":false},"success":{"description":"Did the tool run successfully?","type":"boolean","required":false},"message":{"description":"Tool return message.","type":"string","required":false}}}]},"\/wc\/v3\/shipping_methods":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/shipping_methods"}]}},"\/wc\/v3\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false}}}]},"\/wc\/v3\/payment_gateways":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/payment_gateways"}]}},"\/wc\/v3\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the resource.","type":"string","required":false},"title":{"description":"Payment gateway title on checkout.","type":"string","required":false},"description":{"description":"Payment gateway description on checkout.","type":"string","required":false},"order":{"description":"Payment gateway sort order.","type":"integer","required":false},"enabled":{"description":"Payment gateway enabled status.","type":"boolean","required":false},"settings":{"description":"Payment gateway settings.","type":"object","properties":{"id":{"description":"A unique identifier for the setting.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"A human readable label for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"A human readable description for the setting used in interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Type of setting.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Setting value.","type":"string","context":["view","edit"]},"default":{"description":"Default value for the setting.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Additional help text shown to the user about the setting.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Placeholder text to be displayed in text inputs.","type":"string","context":["view","edit"],"readonly":true}},"required":false}}}]},"\/wc\/v3\/data":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/data"}]}},"\/wc\/v3\/data\/continents":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/data\/continents"}]}},"\/wc\/v3\/data\/continents\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"continent":{"description":"2 character continent code.","type":"string","required":false}}}]},"\/wc\/v3\/data\/countries":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/data\/countries"}]}},"\/wc\/v3\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"ISO3166 alpha-2 country code.","type":"string","required":false}}}]},"\/wc\/v3\/data\/currencies":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/data\/currencies"}]}},"\/wc\/v3\/data\/currencies\/current":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/data\/currencies\/current"}]}},"\/wc\/v3\/data\/currencies\/(?P<currency>[\\w-]{3})":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"ISO4217 currency code.","type":"string","required":false}}}]},"\/wc\/v3\/paypal-standard\/update-shipping":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/paypal-standard\/update-shipping"}]}},"\/wc\/v3\/paypal-webhooks":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/paypal-webhooks"}]}},"\/wc\/v3\/paypal-buttons\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/paypal-buttons\/create-order"}]}},"\/wc\/v3\/paypal-buttons\/cancel-payment":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/paypal-buttons\/cancel-payment"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/receipt":{"namespace":"wc\/v3","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier of the order.","type":"integer","required":false},"expiration_date":{"description":"Expiration date formatted as dd-mm-yyyy.","type":"string","default":null,"required":false},"expiration_days":{"description":"Number of days to be added to the current date to get the expiration date.","type":"integer","default":1,"required":false},"force_new":{"description":"True to force the creation of a new receipt even if one already exists and has not expired yet.","type":"boolean","default":false,"required":false}}},{"methods":["GET"],"args":{"id":{"description":"Unique identifier of the order.","type":"integer","required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/email_templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier of the order.","type":"integer","required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_email":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier of the order.","type":"integer","required":false},"email":{"description":"Email address to send the order details to.","type":"string","format":"email","required":false},"force_email_update":{"description":"Whether to update the billing email of the order, even if it already has one.","type":"boolean","required":false},"template_id":{"description":"The ID of the template to use for sending the email.","type":"string","enum":["new_order","cancelled_order","customer_cancelled_order","failed_order","customer_failed_order","customer_on_hold_order","customer_processing_order","customer_completed_order","customer_refunded_order","customer_invoice","customer_note","customer_reset_password","customer_new_account","customer_pos_completed_order","customer_pos_refunded_order","wpmem_wc_reminder","wpmem_wc_membership_info"],"required":true}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_order_details":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier of the order.","type":"integer","required":false},"email":{"description":"Email address to send the order details to.","type":"string","format":"email","required":false},"force_email_update":{"description":"Whether to update the billing email of the order, even if it already has one.","type":"boolean","required":false}}}]},"\/wc\/v3\/orders\/statuses":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc\/v3\/orders\/statuses"}]}},"\/wc-admin\/settings\/payments\/country":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"location":{"description":"The ISO3166 alpha-2 country code to save for the current user.","type":"string","pattern":"[a-zA-Z]{2}","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/country"}]}},"\/wc-admin\/settings\/payments\/providers":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to WooCommerce&#039;s base location country.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/providers"}]}},"\/wc-admin\/settings\/payments\/providers\/order":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"order_map":{"description":"A map of provider ID to integer values representing the sort order.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/providers\/order"}]}},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/attach":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<suggestion_id>[\\w\\d\\-]+)\/incentive\/(?P<incentive_id>[\\w\\d\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"The context ID for which to dismiss the incentive. If not provided, will dismiss the incentive for all contexts.","type":"string","required":false},"do_not_track":{"description":"If true, the incentive dismissal will be ignored by tracking.","type":"boolean","default":false,"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/start":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/save":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/check":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/clean":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Where from in the onboarding flow this request was triggered.","type":"string","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Where from in the onboarding flow this request was triggered.","type":"string","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Where from in the onboarding flow this request was triggered.","type":"string","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable"}]}},"\/wc-admin-email":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin-email","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin-email"}]}},"\/wc-admin-email\/settings\/email\/send-preview":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"The email type to preview.","type":"string","required":true},"email":{"description":"Email address to send the email preview to.","type":"string","format":"email","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin-email\/settings\/email\/send-preview"}]}},"\/wc-admin-email\/settings\/email\/preview-subject":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"The email type to get subject for.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin-email\/settings\/email\/preview-subject"}]}},"\/wc-admin-email\/settings\/email\/save-transient":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"type":"string","description":"The key for the transient. Must be one of the allowed options.","required":true},"value":{"type":"string","description":"The value to be saved for the transient.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin-email\/settings\/email\/save-transient"}]}},"\/wc-admin-email\/settings\/email\/listing\/recreate-email-post":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email_id":{"description":"The email ID to recreate the post for.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-admin-email\/settings\/email\/listing\/recreate-email-post"}]}},"\/wc-telemetry":{"namespace":"wc-telemetry","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-telemetry","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-telemetry"}]}},"\/wc-telemetry\/tracker":{"namespace":"wc-telemetry","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"platform":{"description":"Platform to track.","type":"string","required":true},"version":{"description":"Platform version to track.","type":"string","required":true},"installation_date":{"description":"Installation date of the WooCommerce mobile app.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wc-telemetry\/tracker"}]}},"\/wccom-site\/v3":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wccom-site\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3"}]}},"\/wccom-site\/v3\/installer\/(?P<product_id>\\d+)\/state":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"type":"integer","required":true}}}]},"\/wccom-site\/v3\/installer":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"run-until-step":{"type":"string","enum":["get_product_info","download_product","unpack_product","move_product","activate_product"],"required":true},"idempotency-key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3\/installer"}]}},"\/wccom-site\/v3\/installer\/reset":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"idempotency-key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3\/installer\/reset"}]}},"\/wccom-site\/v3\/ssr":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3\/ssr"}]}},"\/wccom-site\/v3\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3\/status"}]}},"\/wccom-site\/v3\/connection\/disconnect":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3\/connection\/disconnect"}]}},"\/wccom-site\/v3\/connection\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wccom-site\/v3\/connection\/status"}]}},"\/import-users-from-csv-with-meta\/v1":{"namespace":"import-users-from-csv-with-meta\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"import-users-from-csv-with-meta\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/import-users-from-csv-with-meta\/v1"}]}},"\/import-users-from-csv-with-meta\/v1\/execute-cron":{"namespace":"import-users-from-csv-with-meta\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/import-users-from-csv-with-meta\/v1\/execute-cron"}]}},"\/front-end-pm\/v1":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"front-end-pm\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/front-end-pm\/v1"}]}},"\/front-end-pm\/v1\/view-message\/(?P<fep_id>\\d+)":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"fep_id":{"type":"integer","required":false}}}]},"\/front-end-pm\/v1\/message-heads\/(?P<feppage>\\d+)\/(?P<fep_filter>[a-zA-Z0-9_-]+)":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"feppage":{"type":"integer","default":1,"required":false},"fep_filter":{"type":"string","default":"","required":false}}}]},"\/front-end-pm\/v1\/pagination\/(?P<fepaction>[a-zA-Z0-9_-]+)\/(?P<feppage>\\d+)\/(?P<fep_filter>[a-zA-Z0-9_-]+)":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"fepaction":{"type":"string","default":"messagebox","required":false},"feppage":{"type":"integer","default":1,"required":false},"fep_filter":{"type":"string","default":"","required":false}}}]},"\/front-end-pm\/v1\/users\/(?P<for>[a-zA-Z0-9_-]+)":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"for":{"type":"string","default":"","required":false},"q":{"type":"string","default":"","required":false},"x":{"type":"string","default":"","required":false}}}]},"\/front-end-pm\/v1\/notification":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/front-end-pm\/v1\/notification"}]}},"\/front-end-pm\/v1\/notification\/dismiss":{"namespace":"front-end-pm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/front-end-pm\/v1\/notification\/dismiss"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}},{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unique identifier for the ability category.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}},{"methods":["GET"],"args":{"slug":{"description":"Unique identifier for the ability category.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Input parameters for the ability execution.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}},{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Input parameters for the ability execution.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limit results to abilities in specific ability category.","type":"string","required":false}}},{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limit results to abilities in specific ability category.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}},{"methods":["GET"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/jetpack\/v4\/verify_registration":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/verify_registration"}]}},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"Set to false will trigger the site to disconnect.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Indicates where the registration action was triggered for tracking\/segmentation purposes","type":"string","required":false},"redirect_uri":{"description":"URI of the admin page where the user should be redirected after connection flow","type":"string","required":false},"plugin_slug":{"description":"Indicates from what plugin the request is coming from","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI of the admin page where the user should be redirected after connection flow","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"New user token","type":"string","required":true},"is_connection_owner":{"description":"Is connection owner","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"New owner","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limit result set to items with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the categories taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limit result set to items with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the tags taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"designer":{"description":"Limit result set to items with specific terms assigned in the designer taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"designer_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the designer taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"release_date":{"description":"Limit result set to items with specific terms assigned in the release_date taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"release_date_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the release_date taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"product_colour":{"description":"Limit result set to items with specific terms assigned in the product_colour taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_colour_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the product_colour taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"cartridge_type":{"description":"Limit result set to items with specific terms assigned in the cartridge_type taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"cartridge_type_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the cartridge_type taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"beolink":{"description":"Limit result set to items with specific terms assigned in the beolink taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"beolink_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the beolink taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limit result set to items that are sticky.","type":"boolean","required":false},"ignore_sticky":{"description":"Whether to ignore sticky posts or not.","type":"boolean","default":true,"required":false},"format":{"description":"Limit result set to items assigned one or more given formats.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Whether or not the post should be treated as sticky.","type":"boolean","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the object in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the object in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"designer":{"description":"The terms assigned to the object in the designer taxonomy.","type":"array","items":{"type":"integer"},"required":false},"release_date":{"description":"The terms assigned to the object in the release_date taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_colour":{"description":"The terms assigned to the object in the product_colour taxonomy.","type":"array","items":{"type":"integer"},"required":false},"cartridge_type":{"description":"The terms assigned to the object in the cartridge_type taxonomy.","type":"array","items":{"type":"integer"},"required":false},"beolink":{"description":"The terms assigned to the object in the beolink taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Whether or not the post should be treated as sticky.","type":"boolean","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the object in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the object in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"designer":{"description":"The terms assigned to the object in the designer taxonomy.","type":"array","items":{"type":"integer"},"required":false},"release_date":{"description":"The terms assigned to the object in the release_date taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_colour":{"description":"The terms assigned to the object in the product_colour taxonomy.","type":"array","items":{"type":"integer"},"required":false},"cartridge_type":{"description":"The terms assigned to the object in the cartridge_type taxonomy.","type":"array","items":{"type":"integer"},"required":false},"beolink":{"description":"The terms assigned to the object in the beolink taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Whether or not the post should be treated as sticky.","type":"boolean","required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"categories":{"description":"The terms assigned to the object in the category taxonomy.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"The terms assigned to the object in the post_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false},"designer":{"description":"The terms assigned to the object in the designer taxonomy.","type":"array","items":{"type":"integer"},"required":false},"release_date":{"description":"The terms assigned to the object in the release_date taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_colour":{"description":"The terms assigned to the object in the product_colour taxonomy.","type":"array","items":{"type":"integer"},"required":false},"cartridge_type":{"description":"The terms assigned to the object in the cartridge_type taxonomy.","type":"array","items":{"type":"integer"},"required":false},"beolink":{"description":"The terms assigned to the object in the beolink taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limit result set to items with particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"parent":{"description":"The ID for the parent of the object.","type":"integer","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"parent":{"description":"The ID for the parent of the object.","type":"integer","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the object.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limit result set to items with particular parent IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limit result set to all items except those of a particular parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limit result set to attachments of a particular media type or media types.","type":"array","items":{"type":"string","enum":["image","video","audio","application"]},"required":false},"mime_type":{"default":null,"description":"Limit result set to attachments of a particular MIME type or MIME types.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"alt_text":{"description":"Alternative text to display when attachment is not displayed.","type":"string","required":false},"caption":{"description":"The attachment caption.","type":"object","properties":{"raw":{"description":"Caption for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML caption for the attachment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"The attachment description.","type":"object","properties":{"raw":{"description":"Description for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML description for the attachment, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"The ID for the associated post of the attachment.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"alt_text":{"description":"Alternative text to display when attachment is not displayed.","type":"string","required":false},"caption":{"description":"The attachment caption.","type":"object","properties":{"raw":{"description":"Caption for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML caption for the attachment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"The attachment description.","type":"object","properties":{"raw":{"description":"Description for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML description for the attachment, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"The ID for the associated post of the attachment.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the attachment.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL to the edited image file.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array of image edits.","type":"array","minItems":1,"items":{"description":"Image edit.","type":"object","required":["type","args"],"oneOf":[{"title":"Flip","properties":{"type":{"description":"Flip type.","type":"string","enum":["flip"]},"args":{"description":"Flip arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Flip direction.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Whether to flip in the horizontal direction.","type":"boolean"},"vertical":{"description":"Whether to flip in the vertical direction.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotation type.","type":"string","enum":["rotate"]},"args":{"description":"Rotation arguments.","type":"object","required":["angle"],"properties":{"angle":{"description":"Angle to rotate clockwise in degrees.","type":"number"}}}}},{"title":"Crop","properties":{"type":{"description":"Crop type.","type":"string","enum":["crop"]},"args":{"description":"Crop arguments.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontal position from the left to begin the crop as a percentage of the image width.","type":"number"},"top":{"description":"Vertical position from the top to begin the crop as a percentage of the image height.","type":"number"},"width":{"description":"Width of the crop as a percentage of the image width.","type":"number"},"height":{"description":"Height of the crop as a percentage of the image height.","type":"number"}}}}}]},"required":false},"rotation":{"description":"The amount to rotate the image clockwise in degrees. DEPRECATED: use `modifiers` instead.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"As a percentage of the image, the x position from which to start the crop. DEPRECATED: use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"As a percentage of the image, the y position from which to start the crop. DEPRECATED: use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"As a percentage of the image, the width to which to crop the image. DEPRECATED: use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"As a percentage of the image, the height to which to crop the image. DEPRECATED: use `modifiers` instead.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"The attachment caption.","type":"object","properties":{"raw":{"description":"Caption for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML caption for the attachment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"The attachment description.","type":"object","properties":{"raw":{"description":"Description for the attachment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML description for the attachment, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"The ID for the associated post of the attachment.","type":"integer","required":false},"alt_text":{"description":"Alternative text to display when attachment is not displayed.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limit result set to items with specific terms assigned in the menus taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the menus taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"The title for the object.","type":["string","object"],"properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"The family of objects originally represented, such as \"post_type\" or \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"parent":{"default":0,"description":"The ID for the parent of the object.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text for the title attribute of the link element for this menu item.","type":"string","required":false},"classes":{"description":"Class names for the link element of this menu item.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"The description of this menu item.","type":"string","required":false},"menu_order":{"default":1,"description":"The DB ID of the nav_menu_item that is this item's menu parent, if any, otherwise 0.","type":"integer","minimum":1,"required":false},"object":{"description":"The type of object originally represented, such as \"category\", \"post\", or \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"The database ID of the original object this menu item represents, for example the ID for posts or the term_id for categories.","type":"integer","minimum":0,"required":false},"target":{"description":"The target attribute of the link element for this menu item.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"The URL to which this menu item points.","type":"string","format":"uri","required":false},"xfn":{"description":"The XFN relationship expressed in the link of this menu item.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"The terms assigned to the object in the nav_menu taxonomy.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"title":{"description":"The title for the object.","type":["string","object"],"properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"The family of objects originally represented, such as \"post_type\" or \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"parent":{"description":"The ID for the parent of the object.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text for the title attribute of the link element for this menu item.","type":"string","required":false},"classes":{"description":"Class names for the link element of this menu item.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"The description of this menu item.","type":"string","required":false},"menu_order":{"description":"The DB ID of the nav_menu_item that is this item's menu parent, if any, otherwise 0.","type":"integer","minimum":1,"required":false},"object":{"description":"The type of object originally represented, such as \"category\", \"post\", or \"attachment\".","type":"string","required":false},"object_id":{"description":"The database ID of the original object this menu item represents, for example the ID for posts or the term_id for categories.","type":"integer","minimum":0,"required":false},"target":{"description":"The target attribute of the link element for this menu item.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"The URL to which this menu item points.","type":"string","format":"uri","required":false},"xfn":{"description":"The XFN relationship expressed in the link of this menu item.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"The terms assigned to the object in the nav_menu taxonomy.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the object.","type":"integer","minimum":0,"required":false},"title":{"description":"The title for the object.","type":["string","object"],"properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"The family of objects originally represented, such as \"post_type\" or \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"attr_title":{"description":"Text for the title attribute of the link element for this menu item.","type":"string","required":false},"classes":{"description":"Class names for the link element of this menu item.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"The description of this menu item.","type":"string","required":false},"menu_order":{"description":"The DB ID of the nav_menu_item that is this item's menu parent, if any, otherwise 0.","type":"integer","minimum":1,"required":false},"object":{"description":"The type of object originally represented, such as \"category\", \"post\", or \"attachment\".","type":"string","required":false},"object_id":{"description":"The database ID of the original object this menu item represents, for example the ID for posts or the term_id for categories.","type":"integer","minimum":0,"required":false},"target":{"description":"The target attribute of the link element for this menu item.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"The URL to which this menu item points.","type":"string","format":"uri","required":false},"xfn":{"description":"The XFN relationship expressed in the link of this menu item.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"The terms assigned to the object in the nav_menu taxonomy.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limit result set to items with specific terms assigned in the wp_pattern_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the wp_pattern_category taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"wp_pattern_category":{"description":"The terms assigned to the object in the wp_pattern_category taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"wp_pattern_category":{"description":"The terms assigned to the object in the wp_pattern_category taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"wp_pattern_category":{"description":"The terms assigned to the object in the wp_pattern_category taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limit to the specified post ID.","type":"integer","required":false},"area":{"description":"Limit to the specified template part area.","type":"string","required":false},"post_type":{"description":"Post type for which to get the templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"default":"","description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description of template.","type":"string","required":false},"status":{"default":"publish","description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"The slug of the template to get the fallback for","type":"string","required":true},"is_custom":{"description":"Indicates if a template is custom or part of the template hierarchy","type":"boolean","required":false},"template_prefix":{"description":"The template prefix for the created template. This is used to extract the main template type, e.g. in `taxonomy-books` extracts the `taxonomy`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false},"area":{"description":"Where the template part is intended for use (header, footer, etc)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID of a template","type":"string","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limit to the specified post ID.","type":"integer","required":false},"area":{"description":"Limit to the specified template part area.","type":"string","required":false},"post_type":{"description":"Post type for which to get the templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"default":"","description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description of template.","type":"string","required":false},"status":{"default":"publish","description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false},"area":{"description":"Where the template part is intended for use (header, footer, etc)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"The slug of the template to get the fallback for","type":"string","required":true},"is_custom":{"description":"Indicates if a template is custom or part of the template hierarchy","type":"boolean","required":false},"template_prefix":{"description":"The template prefix for the created template. This is used to extract the main template type, e.g. in `taxonomy-books` extracts the `taxonomy`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"slug":{"description":"Unique slug identifying the template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme identifier for the template.","type":"string","required":false},"type":{"description":"Type of template.","type":"string","required":false},"content":{"description":"Content of template.","type":["object","string"],"properties":{"raw":{"description":"Content for the template, as it exists in the database.","type":"string","context":["view","edit"]},"block_version":{"description":"Version of the content block format used by the template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Title of template.","type":["object","string"],"properties":{"raw":{"description":"Title for the template, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the template, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description of template.","type":"string","required":false},"status":{"description":"Status of template.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"The ID for the author of the template.","type":"integer","required":false},"area":{"description":"Where the template part is intended for use (header, footer, etc)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"The ID of a template","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the global styles revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the global styles revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"The theme identifier","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"The theme identifier","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID of global styles config.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Global styles.","type":["object"],"required":false},"settings":{"description":"Global settings.","type":["object"],"required":false},"title":{"description":"Title of the global styles variation.","type":["object","string"],"properties":{"raw":{"description":"Title for the global styles variation, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Version of the theme.json schema used for the typography settings.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family declaration in theme.json format, encoded as a string.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"theme_json_version":{"description":"Version of the theme.json schema used for the typography settings.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family declaration in theme.json format, encoded as a string.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"theme_json_version":{"description":"Version of the theme.json schema used for the typography settings.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"font-face declaration in theme.json format, encoded as a string.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"id":{"description":"Unique identifier for the font face.","type":"integer","required":true},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"The ID for the parent font family of the font face.","type":"integer","required":true},"id":{"description":"Unique identifier for the font face.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/e-floating-buttons":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limit result set to posts with a specific menu_order value.","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"format":{"description":"Limit result set to items assigned one or more given formats.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/e-floating-buttons"}]}},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"The order of the post in relation to other posts.","type":"integer","required":false},"format":{"description":"The format for the post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","product-post","product","product-archive","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"The ID for the parent of the revision.","type":"integer","required":false},"id":{"description":"Unique identifier for the revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support binning.","required":false}}}]},"\/wp\/v2\/elementor_snippet":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Ensure result set excludes posts assigned to specific authors.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_location":{"type":"string","title":"","description":"","default":"elementor_head","enum":["elementor_head","elementor_body_start","elementor_body_end"]},"_elementor_priority":{"type":"integer","title":"","description":"","default":1},"_elementor_code":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/elementor_snippet"}]}},"\/wp\/v2\/elementor_snippet\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"The ID for the author of the post.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_elementor_location":{"type":"string","title":"","description":"","default":"elementor_head","enum":["elementor_head","elementor_body_start","elementor_body_end"]},"_elementor_priority":{"type":"integer","title":"","description":"","default":1},"_elementor_code":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to posts published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to posts modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to posts published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to posts modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating"],"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limit result set to posts assigned one or more statuses.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit result set based on relationship between multiple taxonomies.","type":"string","enum":["AND","OR"],"required":false},"product_brand":{"description":"Limit result set to items with specific terms assigned in the product_brand taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_brand_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the product_brand taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_cat":{"description":"Limit result set to items with specific terms assigned in the product_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_cat_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the product_cat taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Whether to include child terms in the terms limiting the result set.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_tag":{"description":"Limit result set to items with specific terms assigned in the product_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Whether items must be assigned all or any of the specified terms.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_tag_exclude":{"description":"Limit result set to items, except those with specific terms assigned in the product_tag taxonomy.","type":["object","array"],"oneOf":[{"title":"Term ID List","description":"Match terms with the listed IDs.","type":"array","items":{"type":"integer"}},{"title":"Term ID Taxonomy Query","description":"Perform an advanced term query.","type":"object","properties":{"terms":{"description":"Term IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"product_brand":{"description":"The terms assigned to the object in the product_brand taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"The terms assigned to the object in the product_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"The terms assigned to the object in the product_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/product"}]}},"\/wp\/v2\/product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Override the default excerpt length.","type":"integer","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"product_brand":{"description":"The terms assigned to the object in the product_brand taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"The terms assigned to the object in the product_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"The terms assigned to the object in the product_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false}}}]},"\/wp\/v2\/product\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"date":{"description":"The date the post was published, in the site's time zone.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"The date the post was published, as GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"An alphanumeric identifier for the post unique to its type.","type":"string","required":false},"status":{"description":"A named status for the object.","type":"string","enum":["publish","future","draft","pending","private","closed","spam","orphan","hidden","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"A password to protect access to the content and excerpt.","type":"string","required":false},"title":{"description":"The title for the post.","type":"object","properties":{"raw":{"description":"Title for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML title for the object, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"The content for the post.","type":"object","properties":{"raw":{"description":"Content for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the post, transformed for display.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version of the content block format used by the post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Whether the content is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"The excerpt for the post.","type":"object","properties":{"raw":{"description":"Excerpt for the post, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML excerpt for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Whether the excerpt is protected with a password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"The ID of the featured media for the post.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the post.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the post can be pinged.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_total_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_voice_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_anonymous_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_topic_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count_hidden":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_forum_subforum_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0}},"required":false},"template":{"description":"The theme file to use to display the post.","type":"string","required":false},"product_brand":{"description":"The terms assigned to the object in the product_brand taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"The terms assigned to the object in the product_cat taxonomy.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"The terms assigned to the object in the product_tag taxonomy.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/product\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"The ID for the parent of the autosave.","type":"integer","required":false},"id":{"description":"The ID for the autosave.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"An alphanumeric identifier for the post type.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"An alphanumeric identifier for the status.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limit results to taxonomies associated with a specific post type.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"An alphanumeric identifier for the taxonomy.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false},"locations":{"description":"The locations assigned to the menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Whether to automatically add top-level pages to this menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false},"locations":{"description":"The locations assigned to the menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Whether to automatically add top-level pages to this menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/product_brand":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/product_brand"}]}},"\/wp\/v2\/product_brand\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/product_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to terms assigned to a specific parent.","type":"integer","required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/product_cat"}]}},"\/wp\/v2\/product_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"parent":{"description":"The parent term ID.","type":"integer","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/product_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/product_tag"}]}},"\/wp\/v2\/product_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/designer":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/designer"}]}},"\/wp\/v2\/designer\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/release_date":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/release_date"}]}},"\/wp\/v2\/release_date\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/product_colour":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/product_colour"}]}},"\/wp\/v2\/product_colour\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/cartridge_type":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/cartridge_type"}]}},"\/wp\/v2\/cartridge_type\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/beolink":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by term attribute.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Whether to hide terms not assigned to any posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limit result set to terms assigned to a specific post.","type":"integer","default":null,"required":false},"slug":{"description":"Limit result set to terms with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":true},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/beolink"}]}},"\/wp\/v2\/beolink\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"description":{"description":"HTML description of the term.","type":"string","required":false},"name":{"description":"HTML title for the term.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the term unique to its type.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as terms do not support binning.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"default":"asc","description":"Order sort attribute ascending or descending.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sort collection by user attribute.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limit result set to users with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limit result set to users matching at least one specific role provided. Accepts csv list or single role.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limit result set to users matching at least one specific capability provided. Accepts csv list or single capability.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limit result set to users who are considered authors.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limit result set to users who have published posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","e-floating-buttons":"e-floating-buttons","elementor_library":"elementor_library","elementor_snippet":"elementor_snippet","product":"product"}},"required":false},"search_columns":{"default":[],"description":"Array of column names to be searched.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Login name for the user.","type":"string","required":true},"name":{"description":"Display name for the user.","type":"string","required":false},"first_name":{"description":"First name for the user.","type":"string","required":false},"last_name":{"description":"Last name for the user.","type":"string","required":false},"email":{"description":"The email address for the user.","type":"string","format":"email","required":true},"url":{"description":"URL of the user.","type":"string","format":"uri","required":false},"description":{"description":"Description of the user.","type":"string","required":false},"locale":{"description":"Locale for the user.","type":"string","enum":["","en_US","en_GB","it_IT"],"required":false},"nickname":{"description":"The nickname for the user.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the user.","type":"string","required":false},"roles":{"description":"Roles assigned to the user.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password for the user (never included).","type":"string","required":true},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_last_posted":{"type":"integer","title":"","description":"bbPress User Activity","default":0},"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"The date and time the preferences were updated.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the user.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the user.","type":"integer","required":false},"username":{"description":"Login name for the user.","type":"string","required":false},"name":{"description":"Display name for the user.","type":"string","required":false},"first_name":{"description":"First name for the user.","type":"string","required":false},"last_name":{"description":"Last name for the user.","type":"string","required":false},"email":{"description":"The email address for the user.","type":"string","format":"email","required":false},"url":{"description":"URL of the user.","type":"string","format":"uri","required":false},"description":{"description":"Description of the user.","type":"string","required":false},"locale":{"description":"Locale for the user.","type":"string","enum":["","en_US","en_GB","it_IT"],"required":false},"nickname":{"description":"The nickname for the user.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the user.","type":"string","required":false},"roles":{"description":"Roles assigned to the user.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password for the user (never included).","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_last_posted":{"type":"integer","title":"","description":"bbPress User Activity","default":0},"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"The date and time the preferences were updated.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the user.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as users do not support binning.","required":false},"reassign":{"type":"integer","description":"Reassign the deleted user's posts and links to this user ID.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Login name for the user.","type":"string","required":false},"name":{"description":"Display name for the user.","type":"string","required":false},"first_name":{"description":"First name for the user.","type":"string","required":false},"last_name":{"description":"Last name for the user.","type":"string","required":false},"email":{"description":"The email address for the user.","type":"string","format":"email","required":false},"url":{"description":"URL of the user.","type":"string","format":"uri","required":false},"description":{"description":"Description of the user.","type":"string","required":false},"locale":{"description":"Locale for the user.","type":"string","enum":["","en_US","en_GB","it_IT"],"required":false},"nickname":{"description":"The nickname for the user.","type":"string","required":false},"slug":{"description":"An alphanumeric identifier for the user.","type":"string","required":false},"roles":{"description":"Roles assigned to the user.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password for the user (never included).","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_bbp_topic_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_reply_count":{"type":"integer","title":"","description":"bbPress Item Count","default":0},"_bbp_last_posted":{"type":"integer","title":"","description":"bbPress User Activity","default":0},"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"The date and time the preferences were updated.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Required to be true, as users do not support binning.","required":false},"reassign":{"type":"integer","description":"Reassign the deleted user's posts and links to this user ID.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"A UUID provided by the application to uniquely identify it. It is recommended to use an UUID v5 with the URL or DNS namespace.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"The name of the application password.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"A UUID provided by the application to uniquely identify it. It is recommended to use an UUID v5 with the URL or DNS namespace.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"The name of the application password.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"after":{"description":"Limit response to comments published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"author":{"description":"Limit result set to comments assigned to specific user IDs. Requires authorisation.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Ensure result set excludes comments assigned to specific user IDs. Requires authorisation.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limit result set to that from a specific author email. Requires authorisation.","format":"email","type":"string","required":false},"before":{"description":"Limit response to comments published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by comment attribute.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limit result set to comments of specific parent IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Ensure result set excludes specific parent IDs.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limit result set to comments assigned to specific post IDs.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limit result set to comments assigned a specific status. Requires authorisation.","type":"string","required":false},"type":{"default":"comment","description":"Limit result set to comments assigned a specific type. Requires authorisation.","type":"string","required":false},"password":{"description":"The password for the post if it is password protected.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"The ID of the user object, if author was a user.","type":"integer","required":false},"author_email":{"description":"Email address for the comment author.","type":"string","format":"email","required":false},"author_ip":{"description":"IP address for the comment author.","type":"string","format":"ip","required":false},"author_name":{"description":"Display name for the comment author.","type":"string","required":false},"author_url":{"description":"URL for the comment author.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent for the comment author.","type":"string","required":false},"content":{"description":"The content for the comment.","type":"object","properties":{"raw":{"description":"Content for the comment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the comment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"The date the comment was published, in the site's time zone.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"The date the comment was published, as GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"The ID for the parent of the comment.","type":"integer","required":false},"post":{"default":0,"description":"The ID of the associated post object.","type":"integer","required":false},"status":{"description":"State of the comment.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the comment.","type":"integer","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"The password for the parent post of the comment (if the post is password protected).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the comment.","type":"integer","required":false},"author":{"description":"The ID of the user object, if author was a user.","type":"integer","required":false},"author_email":{"description":"Email address for the comment author.","type":"string","format":"email","required":false},"author_ip":{"description":"IP address for the comment author.","type":"string","format":"ip","required":false},"author_name":{"description":"Display name for the comment author.","type":"string","required":false},"author_url":{"description":"URL for the comment author.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent for the comment author.","type":"string","required":false},"content":{"description":"The content for the comment.","type":"object","properties":{"raw":{"description":"Content for the comment, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the comment, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"The date the comment was published, in the site's time zone.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"The date the comment was published, as GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"The ID for the parent of the comment.","type":"integer","required":false},"post":{"description":"The ID of the associated post object.","type":"integer","required":false},"status":{"description":"State of the comment.","type":"string","required":false},"meta":{"description":"Meta fields.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the comment.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Whether to bypass Bin and force deletion.","required":false},"password":{"description":"The password for the parent post of the comment (if the post is password protected).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"type":{"default":"post","description":"Limit results to items of an object type.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limit results to items of one or more object subtypes.","type":"array","items":{"enum":["post","page","e-floating-buttons","elementor_library","product","category","post_tag","product_brand","product_cat","product_tag","designer","release_date","product_colour","cartridge_type","beolink","any"],"type":"string"},"required":false},"exclude":{"description":"Ensure result set excludes specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limit result set to specific IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Unique registered name for the block.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attributes for the block.","type":"object","default":[],"required":false},"post_id":{"description":"ID of the post context.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block namespace.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block namespace.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Block name.","type":"string","required":false},"namespace":{"description":"Block namespace.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Title","description":"Site title.","type":"string","required":false},"description":{"title":"Tagline","description":"Site tagline.","type":"string","required":false},"timezone":{"title":"","description":"A city in the same timezone as you.","type":"string","required":false},"date_format":{"title":"","description":"A date format for all date strings.","type":"string","required":false},"time_format":{"title":"","description":"A time format for all time strings.","type":"string","required":false},"start_of_week":{"title":"","description":"A day number of the week that the week should start on.","type":"integer","required":false},"language":{"title":"","description":"WordPress locale code.","type":"string","required":false},"use_smilies":{"title":"","description":"Convert emoticons like :-) and :-P to graphics on display.","type":"boolean","required":false},"default_category":{"title":"","description":"Default post category.","type":"integer","required":false},"default_post_format":{"title":"","description":"Default post format.","type":"string","required":false},"posts_per_page":{"title":"Maximum posts per page","description":"Blog pages show at most.","type":"integer","required":false},"show_on_front":{"title":"Show on front","description":"What to show on the front page","type":"string","required":false},"page_on_front":{"title":"Page on front","description":"The ID of the page that should be displayed on the front page","type":"integer","required":false},"page_for_posts":{"title":"","description":"The ID of the page that should display the latest posts","type":"integer","required":false},"default_ping_status":{"title":"","description":"Allow link notifications from other blogs (pingbacks and trackbacks) on new articles.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Allow comments on new posts","description":"Allow people to submit comments on new posts.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Site logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Site icon.","type":"integer","required":false},"elementor_one_welcome_screen_completed":{"title":"","description":"Elementor One Welcome Screen Completed","type":"boolean","required":false},"elementor_one_dismiss_connect_alert":{"title":"","description":"Elementor One Dismiss Connect Alert","type":"boolean","required":false},"elementor_one_editor_update_notification_dismissed":{"title":"","description":"Elementor One Dismiss Editor Update Notification","type":"boolean","required":false},"pickup_location_settings":{"title":"","description":"WooCommerce Local Pickup Method Settings","type":"object","properties":{"enabled":{"description":"If enabled, this method will appear on the block based checkout.","type":"string","enum":["yes","no"]},"title":{"description":"This controls the title which the user sees during checkout.","type":"string"},"tax_status":{"description":"If a cost is defined, this controls if taxes are applied to that cost.","type":"string","enum":["taxable","none"]},"cost":{"description":"Optional cost to charge for local pickup.","type":"string"}},"additionalProperties":false,"required":false},"pickup_locations":{"title":"","description":"WooCommerce Local Pickup Locations","type":"array","items":{"type":"object","properties":{"name":{"type":"string"},"address":{"type":"object","properties":{"address_1":{"type":"string"},"city":{"type":"string"},"state":{"type":"string"},"postcode":{"type":"string"},"country":{"type":"string"}},"additionalProperties":false},"details":{"type":"string"},"enabled":{"type":"boolean"}},"additionalProperties":false},"required":false},"solid_mail_settings":{"title":"","description":"Solid Mail Settings","type":"object","properties":{"disable_logs":{"type":"string","description":"Enable or disable logging of sent emails."},"use_unmatched_connections":{"type":"string","description":"If the default connection fails then an alternative connection will be used as a fallback. Connections with the same &quot;from&quot; address are prioritized."}},"additionalProperties":false,"required":false},"woocommerce_default_catalog_orderby":{"title":"Default product sorting","description":"How should products be sorted in the catalogue by default?","type":"string","enum":["menu_order","popularity","rating","date","price","price-desc"],"required":false},"woocommerce_checkout_phone_field":{"title":"Phone number","description":"Controls the display of the phone field in checkout.","type":"string","enum":["optional","required","hidden"],"required":false},"woocommerce_checkout_company_field":{"title":"Company","description":"Controls the display of the company field in checkout.","type":"string","enum":["optional","required","hidden"],"required":false},"woocommerce_checkout_address_2_field":{"title":"Address Line 2","description":"Controls the display of the apartment (address_2) field in checkout.","type":"string","enum":["optional","required","hidden"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limit result set to themes assigned one or more statuses.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"The theme's style sheet. This uniquely identifies the theme.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"status":{"description":"Limits results to plugins with the given status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The ID of a registered sidebar","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Nested widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The widget type ID.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"The widget type ID.","type":"string","required":true},"instance":{"description":"Current instance settings of the widget.","type":"object","required":false},"form_data":{"description":"Serialised widget form data to encode into instance settings.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"The widget type ID.","type":"string","required":true},"instance":{"description":"Current instance settings of the widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"The sidebar for which to return widgets.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the widget.","type":"string","required":false},"id_base":{"description":"The type of the widget. Corresponds to ID in widget-types endpoint.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"The sidebar to which the widget belongs.","type":"string","required":true},"instance":{"description":"Instance settings of the widget, if supported.","type":"object","properties":{"encoded":{"description":"Base64 encoded representation of the instance settings.","type":"string","context":["edit"]},"hash":{"description":"Cryptographic hash of the instance settings.","type":"string","context":["edit"]},"raw":{"description":"Unencoded instance settings, if supported.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-encoded form data from the widget admin form. Used to update a widget that does not support instance. Write only.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unique identifier for the widget.","type":"string","required":false},"id_base":{"description":"The type of the widget. Corresponds to ID in widget-types endpoint.","type":"string","required":false},"sidebar":{"description":"The sidebar to which the widget belongs.","type":"string","required":false},"instance":{"description":"Instance settings of the widget, if supported.","type":"object","properties":{"encoded":{"description":"Base64 encoded representation of the instance settings.","type":"string","context":["edit"]},"hash":{"description":"Cryptographic hash of the instance settings.","type":"string","context":["edit"]},"raw":{"description":"Unencoded instance settings, if supported.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-encoded form data from the widget admin form. Used to update a widget that does not support instance. Write only.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Whether to force removal of the widget, or move it to the inactive sidebar.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limit result set to blocks matching the search term.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","minLength":1,"required":false},"category":{"description":"Limit results to those matching a category ID.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limit results to those matching a keyword ID.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limit results to those matching a pattern (slug).","type":"array","required":false},"offset":{"description":"Offset the result set by a specific number of items.","type":"integer","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"The URL to process.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"An alphanumeric identifier for the menu location.","type":"string","required":false},"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made; determines fields present in response.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":57749,"site_icon":57747,"site_icon_url":"https:\/\/forum.beoworld.org\/wp-content\/uploads\/sites\/3\/2024\/07\/cropped-BeoWorld-Icon-512x512-1.webp","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/media\/57749"},{"embeddable":true,"type":"site_icon","href":"https:\/\/forum.beoworld.org\/wp-json\/wp\/v2\/media\/57747"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
