Beoplay A1 inside
Beoplay A1 inside
posted by sunseeker1975
Mon, Jul 11 2016
File size: 2.2MB
Filed under:
I dared to open it and as this forum helped me a lot in making decision for the A1, I would like to contribute whith the first (?) picture showing what hides inside the case of Beoplay A1 Bluetooth speaker.
Comments
MattSPL wrote re: Beoplay A1 inside
on Mon, Oct 17 2016 9:33 PM
Great picture, thanks for sharing.
I wonder has anybody tried higher capacity 18650's?
Scotsound wrote re: Beoplay A1 inside
on Tue, Feb 21 2017 4:38 PM
Dear Sunseeker,
Unfortunately I dropped my wife's Beoplay A1 and now the USB slot is misaligned. How did you open the case so that I can try to fix it? My attempts to get B&O repair it are in vain.
Thank you.
Regards
