Home Forums Recreated Classics BeoGram 4000c The New BG4000C
Viewing 17 posts - 21 through 37 (of 37 total)
  • #33553
    steve1977
      Probably to protect the asset value of those 50 people who paid £10k for the first/only batch of BC4000C’s
      I think the 95 original buyers are well “protected”. The kit is nowhere as “good” as the original 10k offer. The original offer had a different color / polish and also carries the 4000C name/logo on it.
      The 95 people basically received a “new” product, while the kit “only” provide a more professional refurbishment.
      #33554
      matador
        One can wonder if this is not only a way of speaking.
        With the lack of details on what is done to the Beograms I wouldn’t consider this expensive refurbishment as “more professional” as the work of some fellow Beoworlders that go very deep into the guts of the deck (bearings, full recap, light replacement with less, …)
        For exemple, appart the one on the marketing photos I’ve not seen a BG4000c with the plates and the platter perfectly aligned and adjusted (you can skip perfectly if you want).
        #33555
        matador
          With the lack of details on what is done to the Beograms…
          I was wrong! But still…
          IMG-3689 - copie
          #33556
          Dillen
          GOLD Member
            They also restore the electronics, including introduction of a minor modification to the servo motor control circuit.
            And they fit a new platter belt. – A quality one.
            #33557
            NQVHNWI
            FOUNDER Member
              I don’t think it matters what was done, mule deck (of any kind) or original. Some people paid £10k for a product called the BC4000c.
              Someone offering up a poor quality eBay BC4000 for refurb, spending £5k to have B&O sort it won’t ever happen. B&O will lose credibility.
              However, it may be they can accept someone sending a wreaked eBay BC4002 for refurb and it leaving the factory as a well sorted, modernised BC4002.
              that was my original point and it has little to do with deck variations and original design quality. It’s all about releasing a limited run product with a name (bc4000c)
              #33558
              steve1977
                Does anyone have a photo of a 4000x after the “kit”? It also gets “painted” if I read above correctly. Any idea what this “painting” looks like?
                #33559
                matador
                  #33560
                  Dillen
                  GOLD Member
                    Maybe there?
                    – Which actually mentions Beogram 4000 as well.
                    #33561
                    matador
                      Yes, I’m with you on this but i think we’ll never have another answer that the one Steve gave us earlier in this thread.
                      #59152
                      Peter
                      FOUNDER Member
                        The Beogram 4000 is very different to the Beogram 4002, 4004 and 6000. It uses an expensive Swiss AC motor, a completely different control system, has a much more substantial sub chassis and sub platter with a strobe speed display and the arm control was simplified for the 4002. There is a good description of the two at Beocentral. However, as Tim points out, the performance of the 4002 was much the same as the 4000 and was a lot cheaper to produce. As the electronics and structure of the 4000 is very different to the 4002, I can fully understand why B&O have limited the offer to the later simpler models.
                        B&O do have a history of the engineers making products that are technologically fantastic but in real life could be troublesome or very expensive to produce  – the Beocord 5000 type 4705 comes to mind – three heads, dual capstan and all electronic control. As anyone who has owned one of these will testify, these are heavy and staggeringly well made and also temperamental and liable to destroy tapes. I remember these were the only devices that my old service departments refused to touch as they said simply taking them apart and putting them back together cost more in time than the machine was worth. The Beomaster 6000 quad, which it matched, was similar though I did get them to service this – I was a good customer!!
                        I suspect the parts needed to fully restore a BG4000 would be very expensive now and would probably need remanufacturing which would clearly be uneconomic for a very small number of decks. Luckily mine still seems to be working fine!
                        #59207
                        hcraig244
                          All of the above are the reasons I hold the vintage equipment in high regard, the BM6000 quad is a master class in over engineering, the lengths the B&O engineers went to just to make the indicator ribbons move up and down is staggering…and the logic gated control panel of the BG4000, given it’s primary role in life is to drop a stylus onto a rotating disc is also the work of someone with far too much time on his hands……
                          craig
                          #59211
                          Peter
                          FOUNDER Member
                            Agree – I love the massively over engineered 4000 – I have three of the 400x decks – the 4000, 4004 (bought this new when a medical student!) and my 6000 (now rebadged as the 4001! The 4000 exudes quality , the control panel simpler and I think better looking and has the strobe, and the lid is not so heavily smoked with a light brown smoked finish as opposed to the grey of the 4004. And considerably heavier!
                            #61902
                            paul.70
                              Couple of things here…..firstly does anyone have any pictures of whats inside the new turntable? Secondly I read somewhere that B&O where offering to upgrade existing 4000x turntables to the new spec…..what are they changing out and more importantly what are they going to do with the component/equipment they remove during this excercise….
                              There’s no question that it looks very attractive, and that its modelled on a 4002 unit. In my view it lacks the over engineered and massively complicated charm of a 4000 deck, the boolean logic controlling the 4000 is a work of art in itself…and the delicate reed relay stop start circuit is just so baffling that i suspect it must have been reverse engineered from an alien spacecraft dug up from the gobi dessert ;¬) And does anyone know what the device is that Eric is injecting the circuit board with is, soldering flux perhaps. Looks like he is upgrading an existing deck from the oxidation on the internals, an old Elco Capacitor and the tone arm solenoid coil looks like it has warmed up the insulation over time…is image 2 the finished article Steve?
                              Hi Steve.
                              Just got mine back (4002) from Multicare. It sounds amazing connected to my Shape. I made the cabinet myself complete with integrated Halo remote charger and music sync LED’s.
                              #61907
                              paul.70
                                Hi Steve.
                                #62019
                                steve1977
                                  Thanks @paul.70 for sharing. Multicare is the offical B&O kit or a 3rd party provider? The color seems unchanged?
                                  How does it connect with the Shape and is there a delay?
                                  • This reply was modified 2 days, 17 hours ago by steve1977.
                                  #62021
                                  paul.70
                                    Thanks @paul.70 for sharing. Multicare is the offical B&O kit or a 3rd party provider? The color seems unchanged? How does it connect with the Shape and is there a delay?
                                    Hi @steve1977 the kit comes directly from B&O, when they return your freshly painted chassis from the beogram you supply. Then Multicare of Leeds do the rest. The colour as I understand was only changed for the limited run that B&O upgraded and sold directly by them. I have wire connected mine to the Beosound Core inside my shape via the line-in connector. There is a small delay between the Beogram and the shape but it sounds great and I was shocked at how little needle noise there is.
                                    Any further questions please feel free to ask.
                                    #62049
                                    Multicare
                                    GOLD Member
                                      • Favourite Product: BeoGram 400x
                                      That is correct, we are the UK’s official Bang & Olufsen classic service center, we repair the whole product range.
                                      Covering both warranty and chargeable repairs.
                                      Thanks for sharing the pics Paul, it looks amazing. I hope you managed to use it over christmas 😊👍
                                      Multicare Electronics - Bang & Olufsen classic service centre.
                                      Repairs and refurbishment to both old and new.
