- This topic has 171 replies, 46 voices, and was last updated 5 days, 18 hours ago by
YannChris.
March 29, 2022 at 5:34 pm #3631
I like the idea of using the date, but as I need to keep it as short as possible to fit in the menu, then something like:-
Archive 2017 to 2012
Archive 2012 to 2022
perhaps or similar..
March 29, 2022 at 6:23 pm #3634Archive 07 to 12 (07-12) Archive 12 to 22 (12-22)
March 30, 2022 at 5:56 am #3642hiii
March 31, 2022 at 8:06 am #3681I can’t find the ‘report spam’ topic, but there have been a few posts from new user ‘optech’ that need removing: https://forum.beoworld.org/forums/users/optech/
March 31, 2022 at 11:27 am #3689Well, it’s the Prize Draw tonight – and I’d like to report the problem that I don’t understand how we still manage to give away such lovely prizes 🙂
March 31, 2022 at 11:38 am #3694Excited!
March 31, 2022 at 4:15 pm #3708Hooked and looking forward to the prize draw …
This reply was modified 4 months, 1 week ago by
iPoditiv.
March 31, 2022 at 7:44 pm #3720Just changed the time by one hour..
March 31, 2022 at 8:37 pm #3747Hi Keith,
I noticed that the subscription status appears for some members.
In the old forum, my status was displayed with the F of founders.
In the new one, no status is shown near my avatar.
What to do?
Kind regards,
Yann.
March 31, 2022 at 8:43 pm #3752See my note in response to your paging post
I have changed your role to gold
Keith
April 1, 2022 at 8:14 am #3762Same here (gold&founder)
Is this not automatic yet?
hemenex.
April 1, 2022 at 8:36 am #3767The Bronze, silver and gold under your avatar are currently just tests.
Under the old system you logged into your account and when you came to the forum you would automatically be logged in and your status would be put on the forum.
During the first phases of the upgrade this no longer happens, hence why you must currently login at the web site and/or the new forum.
In phase 5 of the upgrade the web site will be updated and then we will be back to one login.
We are currently on phase 2 of the upgrade, but I am making sure I can get the roles of each member to be displayed on the forum.
Keith..
April 1, 2022 at 10:20 am #3775EDIT: Thank you, Keith!
I can’t see your reply on my phone’s browser. On the PC Browser I can see it.
TWG.
April 1, 2022 at 10:31 am #3776Did you not read my message right below your posts?
April 2, 2022 at 2:46 am #3807[posted here because no spam thread?] Looks like someone actually registered just to post a link, then edit it later? Anyway, spammy given that the current link is to the McDonalds…
[Eidt also odd that the “#post-3641” doesn’t show up in the display of the thread info above, after the forum software digests it?]
April 2, 2022 at 11:39 pm #3858Hi Keith…….I’ve managed to load an avatar now but can’t seem to get it the right way round….tried to amend it but failed. Also I know it’s work in progress but I seem to have been demoted to a bronze member as well!! Thanks Mike
April 3, 2022 at 8:49 am #3860Firstly, you have not been demoted. Look at my reply post further down this thread.
With regards to your avatar image being the wrong way round is nothing to do with the forum and I am guessing you saved it on a iPhone?
Apple and a few other company’s in their wisdom put a code embedded in the image itself that defines the rotation and other elements of the image. So, you either go on the web and get an app that adjusts the image or resave it on your iPhone based on the rotation of your phone.
Keith..
April 5, 2022 at 11:02 am #3927I find it a bit puzzling that you can not reply directly to a specific post in a thread – the post appears at a different place, not directly after the posting you try to reply to.
Also it is not possible to quote a posting (at least I don’t know how to) in order to make it clear what you are referring to.
Millemissen.
April 5, 2022 at 12:17 pm #3933April 5, 2022 at 12:30 pm #3937I find it a bit puzzling that you can not reply directly to a specific post in a thread – the post appears at a different place, not directly after the posting you try to reply to. Also it is not possible to quote a posting (at least I don’t know how to) in order to make it clear what you are referring to. ? MM
I think this is what you mean..
Keith..-
Keith Saunders.
