Home › Forums › Product Discussion & Questions › BeoVision › Beovision Avant 55 Picture Spot Issue
- This topic has 1 reply, 2 voices, and was last updated 1 year ago by
multicare.
6 May 2025 at 20:13 #65467
Ryan Mitchell
BRONZE MemberHi all,
Just got a Beovision Avant 55, and the picture is not uniform across the panel. It has a large, slightly dim “spot” over the middle 2/3rds of the display, and the left and right sides of the screen are brighter from (I’m assuming) the backlight LED strips there. I don’t notice the issue when showing black content, but it’s pretty apparent when looking at a solid grey screen that the left/right edges are brighter and the middle tends to skew dimmer/browner.
Does this fall under the DVE issue everyone talks about? Or could it be something else, with the backlight or panel or otherwise? If it’s something that there’s still parts/can still be fixed, I’ll likely get a dealer/tech out as the gearbox that drives the speaker extension is also broken, but otherwise it might not be worth fixing just that. Thanks!
16 May 2025 at 15:50 #65658 multicare
GOLD MemberThis does not sound too good 😢
I think you have a bad panel, ti wouldn’t generally be an issue with the video engineMy B&O Icons:
