- This topic has 10 replies, 2 voices, and was last updated 1 month, 3 weeks ago by
Beogogo.
April 28, 2022 at 5:45 pm #4544
Where are the fuse(s) located on a Beosound 4000? I see reference to them behind the back panel, and see them in the schematic in the service manual, but I cannot find any reference on how/where to find them. Thanks!
April 28, 2022 at 6:03 pm #4545If you look at the second photo on this eBay listing you will see F1 to F4 marked on the PCB attached to the transformer. The fuses will be on the other side – probably the small back circular type.
https://www.ebay.co.uk/itm/255201530108
(EDIT: There’s an F5 as well closer to the edge of the PCB)
(EDIT2: There’s a better photo here in a Beoparts listing: https://beoparts.com/category/beosound/beosound-ouverture/#jp-carousel-8289)
April 28, 2022 at 10:01 pm #4554Ah, not as obvious as I thought. Thank you very much, I truly appreciate it!
April 30, 2022 at 10:08 pm #4609The fuses are all good. Any idea why the doors open and close, lights come on, CD load works, but nether the tape, radio or CD will play. The display has both a green and red light displaying. Thanks!
May 1, 2022 at 7:27 am #4611The red light is just the standby light, and should go out when the system is switched on (playing radio, CD or tape). The green light means that the timer is set, and you should be able to cancel this from the front panel using the SETUP then TIMER setting.
Are you only trying to operate the unit from the front panel, or also from a remote? I ask this because the front panels have been know to fail on these systems – the symptom is that just some of the buttons stop working.
May 3, 2022 at 4:31 pm #4672Both green and red lights flash when I select a source from the keypad or the remote, but nothing happens. The doors will close when a button is touched, but nothing else happens. That’s why I originally thought it was maybe a fuse. The unit sat in my office at work for two years without being used during COVID.
May 3, 2022 at 5:52 pm #4677Sorry but I don’t have any further suggestions. Perhaps when it was sat unused there was a mains voltage surge that upset the processor?
Do you have the service manual? There is a ‘TEST mode’ that you can use to check various functions, but without the full instructions you could muck it up further! The Service Manual is available on the Main Beoworld Site to Silver/Gold members.
May 4, 2022 at 1:54 pm #4730Yes, it is very possible a surge damaged it. It was on a protector, but it seems to me we lost some equipment at one point. I do have the service manual and I’ll give it a look at some point. Thanks for the suggestions!
May 7, 2022 at 2:49 pm #4850The lithium battery is dead. It looks like it’s soldered or glued in place?
May 7, 2022 at 5:31 pm #4854The lithium battery is dead. It looks like it’s soldered or glued in place?
Soldered probably. I’ve replaced one in a BC9500 but not a BS4000. You need to be a little careful soldering lithium batteries – not too much heat! Alternatively some people have replaced the battery with a small lithium battery holder to make it easier to replace, but if there is limited space you may need to relocate this within the Beosound.
Not sure if this is the right one for a BS4000 (check the manual) but this is the one I got for my BC9500: https://uk.farnell.com/renata/cr2450-nfh-lf/cell-lithium-button-2pin-3v/dp/1319731?CMP=i-ddd7-00001003
This reply was modified 1 month, 4 weeks ago by
Guy.
May 9, 2022 at 3:59 pm #4893Thanks again. I like the idea of a separate holder.
