Home › Forums › Product Discussion & Questions › BeoLab › Beolab 28 set up
- This topic has 4 replies, 4 voices, and was last updated 3 years, 7 months ago by
checkler.
19 August 2022 at 02:29 #37073
vivekmohan83
BRONZE MemberHi, I am trying to set up a home theater/ surround system set up for my living room (25*20 ft).. I have a 83 inch LG C2 TV
my consultant is recommending
1. Beolab 282. B&O Almando multiplayer switch (to connect to the LG TV)
3. B&O Lab 19 sub woofer
4. B&O Beoamp 2 (for connecting surround speakers)
5. B&O BOC82 in ceiling speakers
Does this seem like an overkill? Given the Beolab 28 is an active speaker with built in woofers so I really need a sub woofer and ceiling speakers.
Also is Almando the best route to connect Beolab 28 to the LG TV?
20 August 2022 at 06:23 #37074vivekmohan83
BRONZE MemberBumping this up. Need to finalise this weekend. Please help
20 August 2022 at 07:06 #37075NQVHNWI
BRONZE MemberHi,
I think you are in a territory not many Beoworlder have wide experience of. i.e the combination non-B&O TV with current SOTA actives loudspeakers, and passives with separate amplification.
Some of my points…
1. Subwoofer. Can add this later. If you are pre-wiring in a build, wire in for a sub.
2. We suspect that B&O will release a new sound bar in September. It is suspected that it may be a Beovision Eclipse sound bar of sorts with pluggable external loudspeakers and 5.1 processing. If true, this would simplify your whole home theatre approach…..
20 August 2022 at 09:28 #37076Sandyb
BRONZE MemberYes, as below.
I’d definitely wait as the Beosound Theatre is very close to release – a centre speaker / sound bar with all the surround AV processing built in. It will integrate with your LG and allow you to use the B&O remote.
Also, the BL28’s have such absurdly strong bass that a BL19 sub is completely unnecessary – many 28’s users have had to dial down its bass in the out of the box settings!.
As for your surrounds, etc – that’s all fine and do whatever you need, governed by room configuration / budget etc etc.
You can see a picture (which was leaked by B&O) of the upcoming Theatre on the B&O (not official) Discord server, under the BeoSound subject / thread.
20 August 2022 at 16:11 #37077checkler
BRONZE MemberDefinitely with you on overkill with the BL19. The 28’s deliver amazing bass. AND I would definitley wait until the release of the new B&O sound bar
