Beogram 8000 Aluminum Deck And Door Panel Reattachment
Not Answered This post has 0 verified answers | 11 Replies | 0 Followers
John Francis
USA
Silver Member
John Francis posted on Fri, Apr 27 2012 4:56 PM
Hello,
I am sure ths is not a new question as to what to use to replace the adhesive tape for the aluminum deck and panel that covers the tone arm on the BG 8000 when it comes loose. I did a search on the old forum but maybe did not use the correct key words and came up with nothing. I seem t recall a mention of 3M doubled sided foam tape. Any thoughts would be appreciated.
John
Peter
Earsdon
Peter replied on Fri, Apr 27 2012 5:36 PM
I have done 4 of these and use epoxy glue. I know some have used carpet tape, but I found glue to be stronger and it gave a very satisfactory finish.
Peter
DMacri
United States
DMacri replied on Sat, Apr 28 2012 12:04 AM
I don't know if it's the same, but I found carpet tape to be a near exact match for the pieces on a TX.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
Dillen
Copenhagen / Denmark
Dillen replied on Sat, Apr 28 2012 6:58 AM
2-comp epoxy for the right side lid, liberal amounts of contact glue for the platter surround.
I glue in a handful of metal washers under the right side lid in suitable thickness to compensate for
the loss of the foam tape height and shim the panel to sit flush with the dustcover.
Make sure you have the Beogram on a plain and smooth surface and all its rubber feet are present and good
while you glue or the lid will not sit nice and/or conflict with the dustcover.
root
root replied on Sat, Apr 28 2012 8:47 AM
They used double sided foam taple so why not keep it original and do the same? There are various suppliers, can recommend the one that is sold for attaching number plates to cars, like that one: http://www.maplin.co.uk/double-sided-foam-tape-33766
Leslie
the Netherlands City
Silver Member
Leslie replied on Sat, Apr 28 2012 8:53 AM
John, I can supply you some 3M DS (not foam) tape for free if you need any for your BG8000Smile
Brengen & Ophalen
Dillen
Dillen replied on Sat, Apr 28 2012 9:07 AM
root:
Because you would end up with the same messy problem again in 6 years.
Leslie
Silver Member
Leslie replied on Sat, Apr 28 2012 6:58 PM
Double sided tape has been improved since 1955 MartinBig Smile
Brengen & Ophalen
Dillen
Dillen replied on Sat, Apr 28 2012 8:58 PM
Leslie:
Also since 1985 ?
Surely, the butyl foam used hasn't improved a bit and that seems to be the problem.
The sticky tape seems to hold on nicely (actually too good if you are to remove the old stuff).
(This is my second try at posting this. First time I got the server unavailable message screen - again !)
John Francis
USA
Silver Member
Thanks everyone, This is why this site is so great, ask a question about something rather trivial and you get such great responses. I especially thank you Leslie for your kind offer to send the tape, but I live in Boise, Idaho which would cost you a fortune to ship it to me here in the states. Actually I should be able to get the 3M tape here. I think I am leaning towards the epoxy and glue solutions however. Thanks all, John
Leslie
Silver Member
Leslie replied on Sun, Apr 29 2012 6:53 AM
You're welcome! Btw, it doesn't cost a fortune, 3E by regular postSmile If you gonna decide for 3M sticky tape make sure you get the right one, but be carefull though, once the panel has placed it stays, no adjustments afterSuper Angry
Brengen & Ophalen
Steffen
Denmark
Steffen replied on Mon, Apr 30 2012 11:29 PM
Dillen:
I have used 2-comp epoxy for both...And also for the glass-panels on my BeoSystem 4500 and BeoCenter 9500. They will never come loose again Big Smile
Page 1 of 1 (12 items) | RSS
