Masterlink Gateway
Not Answered This post has 0 verified answers | 36 Replies | 7 Followers
frog
Camberley UK
frog posted on Sun, Feb 16 2014 12:49 PM
I'm keen to start controlling my B&O system through a MLG using Domoticz running on a raspberry Pi. While the MLG is not currently supported natively by the Domoticz software (and I suspect never will due to its rarity), I'd like to control it via the ethernet interface. Is there anywhere I can find documentation as to how to go about this?
Regards to all
frog
Camberley UK
frog replied on Tue, Oct 9 2018 5:30 PM
Ah, now I understand - sorry. I can GENERATE key presses by the scripts which connect over port 9000 using sockets. The limitation in receiving keystrokes is - as you have said, limited to LIGHT commands (as far as I remember).
The way I handle what you want to do is via the receipt of the IR signal in a raspberry using LIRC. That can receive the IR and send out a http post.
See here for the IR receiving hardware (or use an IR Puck - which I did eventually)
frog
Camberley UK
https://forum.beoworld.org/forums/t/22757.aspx
ebnrob
South East England
Ah that's a shame!! I do have a spare IR puck and a pi so might try it out, only snag is I'd need one in each room!
Thanks for all your help.
cge01
Paris
cge01 replied on Sun, Feb 9 2020 2:29 PM
Hello,
I am trying to link my MLGW to my domoticz system (raspberry pi + rfxcom) in order to control my window blinds using my TV remote.
At the moment, the MLGW is working fine and interconnects a Lutron Grafik Eye unit to a BV7.
I guess I will have to use the MLGW custom strings to send commands to domoticz. Have any of you succeeded? If so, would you have any tips to help me? I have tried the links provided here but they no longer work.
Thanks in advance.
Regards,
Christian
Living room Avant 55 MK1 - BL5 x2 - BL6000 x2 - BS3200 - Core - NL/ML Converter - Thorens turntable
Bedroom BV7-40 MK6 - BL4 x2 - BL8000 x2 - BL11 - MLGW - Lutron GFX - RaspberryPi Domoticz
Bathroom BL2000 on BLC1611 with Chromecast audio
Kitchen Core - BL3 x2
Garden Core - Beolink Passive on 2x Bose Freespace 51
L Spad
Brighton
Hi Frog, would you be willing to re-share the script - the link above is no longer working.
Thanks!
Luke
frog
Camberley UK
frog replied on Tue, Feb 11 2020 10:23 AM
here’s an updated link
https://rapidgator.net/file/f97262f9dfabca44aae57c59c829ca1d/mlgw_client.py.html
L Spad
Brighton
Many thanks for sharing!
Page 3 of 3 (37 items) < Previous 1 2 3 | RSS
