Advice on how to connect a t-box which only has s-video or HDMI to an AVANT
Answered (Not Verified) This post has 0 verified answers | 4 Replies | 1 Follower
Dave
Dave posted on Sun, Feb 2 2014 12:12 AM
G'day all!
I had a search for this but i couldn't find the info i need... is it possible (or even feasable) to convert HDMI to RGB SCART? I need to connect a T-Box (digital HD set top box in australia) I want the clear picture i'm used to from using a regular set top box with scart.
any pointers? or anyone done the same? I still have a good quality converter which converts component to RGB scart, but my AVANT is still in storage - it's a long story.
Cheers for any help! :)
Jonathan
Melbourne, Australia
Hi Dave,
Which version of the T-Box is it?
x:________________________
Dave
Dave replied on Sun, Feb 2 2014 2:05 AM
The latest > with the mini din connector on the back - which solves my problem with the cable to component! oops :)
Stoobietoo
Exeter, Devon, UK
Suggested by Stoobietoo
I know you have solved your particular issue, but in case others are looking at the HDMI to Scart (Composite) issue I can say I bought one of these to connect my ATV-1 (HDMI) to my Beovison 5 (Scart) and it was simply "plug and play". It does not even require power and works out of the box. I did see cheaper, but this one seemed to have good customer reviews :o)
Stoobie
PS - I did use the fix that forces composite out of the component connections on the ATV but got fed up with having to keep doing it every time there was an issue with the ATV and I had to unplug it.
Dave
Dave replied on Mon, Feb 3 2014 10:11 PM
G'day thanks for the info, however the aim here (for me anyway) is to avoid that awful picture quality that is from Composite, otherwise there's no point in keeping such a big heavy old TV... it's all about the PQ! :)
Page 1 of 1 (5 items) | RSS
