Where to get a door drive belt for a Beocenter 2300?
Not Answered This post has 0 verified answers | 18 Replies | 1 Follower
AndrewEcosse
AndrewEcosse posted on Thu, Jan 30 2014 8:07 PM
Hi all,
Would anybody know where to get a drive belt for the door mechanism on an early beocenter 2300? B&O are telling me the part is no longer available?
Thanks, Andrew.
joeyboygolf
Ely, Cambridgeshire, UK
Contact member Dillen on this forum. He will sell you one
Regards Graham
Dillen
Copenhagen / Denmark
Dillen replied on Thu, Jan 30 2014 9:24 PM
Thanks Graham but I don't have that belt.
I believe it's still available from B&O.
joeyboygolf
Correct, it will most likely be the same as Beosound 3000/3200 which must still be within the service period.
Edit
Just checked the service manuals and it is indeed the same belt as 3000/3200
The part number is 2732076 and it must still be available from B&O
Regards Graham
Dillen
Dillen replied on Thu, Jan 30 2014 10:18 PM
Sorry Graham, I just checked and you were right.
I have it.  Laughing
joeyboygolf
Hang on a minute...........having reread the OP I have given you the wrong Pt No. I thought he wanted the clamper drive belt.
I think he wants the belt that drives the glass doors which is 2732076. It should still be available from B&O as it is common to the 3000/3200
Regards Graham
AndrewEcosse
Thank's folks. I think B&O are not all that keen on bothering with the older unit. After seeing the internals of the unit, It surprised me that the part was unavailable, being as it's just a rubber belt.
Are there any reputable parts suppliers other than B&O?
Thanks, Andrew.
joeyboygolf
Dillen may have 2732092
There are no other suppliers that I know of.
Regards Graham
joeyboygolf
I just checked with my dealer and both if these belts are still available from B&O
Regards Graham
AndrewEcosse
I'm waiting on AVA to call back, but this is the response B&O gave me... “The belts and all parts for this are obsolete. I have tried off the shelf belt kits and they don't fit. They cause speed variation issues. Unfortunately they are not repairable and this is why you can pick these units up for very little. Investing in a convertor would be unwise as no firmware updates to smooth out known snags with communication. This unit is at least  20 years old”
And when giving them the part number, they still assure me it will cause problems with speed. Personally I cannot see how.
joeyboygolf
All I can do is repeat my point.........what would they tell their last Beosound 3200 customers if they needed a warranty repair.
The 3200 uses the same belts!!!!
The converter worked fine when I used one to interface a 2300 with a Beolab 3500  speaker via masterlink with no apparent communication issues.
Sounds like your dealer is using the bull sh1t approach.
Regards Graham
AndrewEcosse
Yup I agree... this is the reply to that very question....
"I asked Jim about your query and he assures me the belt is not the same.  He has tried in the past to mix parts from different models only to have issues."
joeyboygolf
So it's a different belt with the identical part number.
It must be a misprint in the service manual!! I don't think so.
Regards Graham
AndrewEcosse
Well... I'll contact a different dealer and see where I get. Anybody recommend one who is receptive to such questions??
AndrewEcosse
Ava have a belt on its way to me. And i've forwarded his details to B&O.!
Page 1 of 2 (19 items) 1 2 Next > | RSS
