AirPlay and BeoSound 5 / BeoMaster 5 or BeoMedia
This post has 17 Replies | 4 Followers
BeoMotion
Posts 371
BeoMotion Posted: Wed, Dec 4 2013 10:49 PM
Hi to all,
I am quite new to this forum but I own some B&O stuff for several years. :-)
With this thread I want to share a nice thing that I found out with my BeoSound 5.
I always wanted to have a direct AirPlay feature in this great pice of technic but it seams that B&O ist not able to include this. Maybe a restriction from Apple? I don't know...
The only solution they gave to customer like us is an USB Aux adapter where you can plug in an AirPort Express. Since the sound quality of those two extra devices isn't really not the best one I did some search in the WWW and found following.
There is an open source "AirPlay receiver software" which can be installed on any windows based PC. So I gave it a try and installed it on the BeoMaster 5. (which is actually a windows based machine and all system sounds will be forwarded to PL/ML connection.)
This solution works very good. Very stable with no drop outs and a better sound quality then the B&O solution. :-)
If you want to try it on your own, google for "shairport4w.exe" and download it to a USB stick.
On BeoSound 5 open Servicemenu (Windows Desktop), plug in the stick and install the program.
Now navigate to the firewall settings and add an exception for this program since it needs to communicate with airplay transmitters within your LAN.
Now, open shairport, type in a name that will be visible in your AirPlay list. Don't forget to activate the autostart function.
Close the servicemenu, activate A.Aux and start to send AirPlay from your iDevice to BeoMaster.
I think this solution will also work for BeoMedia 1 since it similar to BM5.
Please keep in mind that you do everything ON YOUR OWN RISK. I will NOT be responsible for any bricked B&O devices or destroyed music collections   :-)
Best greetings.
- BeoMotion
olvisab
Posts 1,358
Silver Member
olvisab replied on Wed, Dec 4 2013 10:58 PM
Hi beomotion
Thanks for this info. This is a project hosted by sourceforge.net.
beolab 5, beolab 9, beolab 3, beolab 10, beolab 5000, beolab 8000, beolab 3500, IWS 2000, beovision 7 55 mk2,  beotime, beogram 7000 white mmc2, beosound ouverture, beosound essence, beomaster 900 RG de luxe and the collection continues...
BeoMotion
Posts 371
BeoMotion replied on Wed, Dec 4 2013 11:11 PM
Hi olvisab,
Yes, you are right. I forgot to mention that.
MartinW
Posts 389
MartinW replied on Wed, Dec 4 2013 11:47 PM
I like the sound of that!!!!
BeoMegaMan
Posts 572
@BeoMotion if what you say is true, you may have just become a BeoSound 5 hero on the forum. Can't wait to try it in the AM.
Ah, you know... A little B&O here, a little there
beolion
Posts 354
Silver Member
beolion replied on Thu, Dec 5 2013 8:38 AM
Thanks a lot for that info, I really missed that feature. Will try when I get home.
BeoMotion
Posts 371
Thanks for the praise...
I am using it for several weeks without any problems so far.
There is no really installation progress. Just copy paste it to your BeoMaster's Desktop and start it. Let me know if you have trouble with installing it.
The part with the firewall setting is a bit tricky but really necessary. Otherwise the program will not be visible within your LAN / AirPlay list.
Remember to stop AirPlay stream from your iDevice if you change from A.Aux to a different audio source of BM5. Otherwise it will play in background together with the other source.
- BeoMotion
gysse2004
Hellerup
Posts 164
gysse2004 replied on Thu, Dec 5 2013 11:07 AM
This is good news - been waiting for somthinge like this. All we need now is Spotify Connect...
Will try tonight
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
BeoMotion
Posts 371
BeoMotion replied on Thu, Dec 5 2013 11:22 AM
@Peter
Unfortunately Spotify did not release any API for the "Connect" function, yet.
Hopefully there will be something coming in future.
stefan
200 miles from Struer
Posts 2,741
stefan replied on Thu, Dec 5 2013 2:59 PM
Thanks for the BM5-airplay info!
For Spotify there is a norwegian app called "Remoteless". It`s for remote control Spotify on your computer via ipad.
You have to install a "Helper" on your computer. Maybe this will work on a BM5 too...??
Stefan
BeoMotion
Posts 371
@stefan
yes, there are several "remote" apps for spotify available.
Some time ago I used the "Spotimote" App from Android store. You have to install the complete Spotify Desktop program and a special server software.
Works with BeoMaster 5 but in my opinion the original App from Spotify in combination with AirPlay is much cooler.
Hopefully they will release a special API for the "connect" function or add it at least to libspotify.
- BeoMotion
stefan
Posts 2,741
stefan replied on Thu, Dec 5 2013 9:12 PM
BeoMotion:
- BeoMotion
Yes, I hope so too. Thanks again for sharing your experience.
Stefan
Beobuddy
Utrecht, The Netherlands
Posts 3,520
BeoMotion:
Some options are only possible with a complete BM5 BS5 setup.
A.Aux will only be available with the BS5. Same for the Spotify feature.
The Beo-navigatorsoftware divers from the Beomedia1. So the above will only work when Beosound.exe is working after detecting the BS5
BeoMotion
Posts 371
Hi Beobuddy,
Yes, you are right but of course there are some unmentioned tricks I found out. :-)
If you own BeoMedia 1 or BeoMaster-5-only, you can use shairport, too. Just install it the way mentioned above.
Now, if you want to listen to AirPlay, simply use the N.Music function and press STOP. Now only the AirPlay source will be playing.
You could also delete all stored music. Then simply press N.Music and start AirPlay.
Maybe after 30 Minutes system will shut down because no "BeoSource" is playing. If someone is experiencing this problem you could take a closer look at the registry. Maybe there is a value for setting another timer?
I never had this problem...
If you are an Android and Spotify user you can think about of installing the Spotify desktop application. Then search the App Store for "spotify remote" or "spotimote" and follow their instroductions. In most cases you have to install a special server software for the spotify application.
I can recommend "Spotimote". It is running on the embedded xp systems.
Feels a bit similar to Spotify Connect but you have to use a third party Spotify App on your smartphone.
- BeoMotion
Beobuddy
Posts 3,520
Thanks for the information about the Airplay. As you've mentioned, it eliminates same components and its "distortion".
I've tried already some tweaking on my BM5 in the past. Changed some registersettings to get the Beo6 working.
That worked for some time, but the system became instable.
BeoMotion
Posts 371
BeoMotion replied on Sun, Dec 8 2013 10:53 AM
Unfortunately the stability in communication between BM5 / Beo6 is even in original state not the best one.
Aleksei
Russia
Posts 71
Aleksei replied on Fri, Oct 27 2017 8:46 AM
To make the picture complete, you do not necessarily need the usb-flash. You can also put the setup file to any the BM-SHARE folder via BeoConnect and then browse it from Service Menu. Also, in the recent release the firewall rule may be set during the setup.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+BeoMaster900
frog
Camberley UK
Posts 502
frog replied on Sun, Feb 24 2019 8:18 PM
I've had trouble getting Shairport4w running on me Beomaster 5 - downloading from 32-bit version from Sourceforge gives me an error that the executable is not a 32-bit application. Not sure anyone else had the problem. The developer's repository is: https://github.com/Frank-Friemel/Shairport4w/releases
I've found a version that works well though at: https://www.chip.de/downloads/Shairport4w_49182437.html
Page 1 of 1 (18 items) | RSS
