Beovision 7-32 DVI
Answered (Verified) This post has 1 verified answer | 19 Replies | 1 Follower
robathome
robathome posted on Sun, Nov 3 2013 9:17 AM
Does anyone know of a smart BlueRay player that supports composite out or HDMI out with separate analogue out sound. The DVI socket does not support audio and I don't think there is a cable that will support hdmi out to DVI in with separate audio.
Any Ideas, not WII, PlayStation or XBOX etc
Regards
Robert Cooper
Mark
London
Answered (Verified) Mark replied on Wed, Nov 6 2013 7:37 PM
Verified by robathome
http://www.amazon.co.uk/SCART-Converter-Adapter-quality-converter/dp/B007WRPJX2
If in doubt Google it out
Millemissen
Flensborg, Denmark
Hi robathome and welcome to BeoWorld,
on recent BRP's you will have to use an adapter - HDMI to DVI  for the picture and a small DAC - digital out to rca - for the sound.
Older BRP's had analog-out (video and audio) connections - it might still be possible to get one/ebay?
robathome
Thanks, I have ordered cables and rca on Ebay, I'll let you know if it all works!
Rob
robathome
The TV does not show a coherent picture, just lots of lines like it can't support the res of the Blue Ray Player :(
The player outputs to a PC monitor via DVI and the TV display a PC screen through the DVI socket
I have set the Player to display it's lowest res 576 HDMI but the display is not viewable.
Any ideas?
Rob
robathome
Any ideas?
Rob
Millemissen
Flensborg, Denmark
If it will work depends on the 7-32 version and/or if it has been 'HD-Ready' upgraded.
With older BRP's and 'analog outputs' I meant the 'ypbpr' like this:
http://0.tqn.com/d/hometheater/1/0/7/9/component10242.JPG
Worst case: you will have to use a 'HDMI to Scart converter'.
robathome
The TV is no HD ready, the retailers I have been to say there is no such device as HDMI to Composite :(
Where can I get a HDMI to SCART or Composite cable?
Millemissen
Flensborg, Denmark
Depends on where you are located.
No cable, but a converter-box.
Like this:
or this:
http://www.amazon.co.uk/KanaaN-HDMI-Composite-S-Video-Converter/dp/B005ZCUA26/ref=sr_1_2?s=electronics&ie=UTF8&qid=1383692454&sr=1-2&keywords=Hdmi+to+composite
or that:
http://www.amazon.co.uk/eSynic®-Component-Stereo-Converter-Adapter/dp/B00AQ1LE3U/ref=sr_1_3?s=electronics&ie=UTF8&qid=1383692527&sr=1-3&keywords=hdmi+to+component
or even this one:
http://www.hdfury.com/products/hdfuryiii-getting-started/
With lots of background information to this theme (HDCP).
Mark
London
robathome
I have ordered one, but one of the reviews says it does work with "an old B&O TV"
We will see.
Millemissen
Flensborg, Denmark
If you mean the HDMI to Scart converter, I can assure you that it works.
I have one to connect an ATV to my Avant - which csertainly is "an old B&O tv".
kallasr
Germany
Question is:
Is the YPbPr socket an Option? Converters from HDMI to YPbPr are available.
Or what about using a HDMI HDCP remover to feed the DVI-I socket?
I have the same issue with Beovision 7 40 MKI (not hd ready), trying to connect a HDMI source...
Ralf
Millemissen
Flensborg, Denmark
@kallasr - didn't you notice my links above?
kallasr
Germany
Millemissen:
Sure did, very good background information.
So, it does work, using a YPbPr converter?
See also this thread I started.
I want to connect a HDMI source to a Beovision 7 40 MKI non hd-ready AND getting a HD Picture to the TV (no downscaling via scart, composite etc.).
Thanks!
Ralf
Millemissen
Flensborg, Denmark
I did not try the '...to component' converter.
Haven't got the opportunity to/the gear for this experiment.
But - as atated - I have the '...to scart' converter.
I am quite sure it will work.
How good it works, will depend on the quality of the converter - don't expect too much of a cheap conveter-thing.
On the other hand don't expect too much from a non HD-Ready tv!!!
If I had a 7-32 (non HD-Ready) I would go for the HDFury-solution - even if I had to use 'PC' from 'List' to activate it (just put it to the first place in the 'List').
Note: using a converter always means 'downscaling' - that is exactly what is needed to get things to work.
Page 1 of 2 (20 items) 1 2 Next > | RSS
