BM 2400 Remote
Answered (Verified) This post has 2 verified answers | 4 Replies | 2 Followers
Søren Mexico
Mexico City
Søren Mexico posted on Tue, Feb 7 2012 3:32 PM
Got my Remote for the BM 2400, Funny failure, all the left side buttons works, I can change to channel 1,3 and select Phono and lover volume, but non of the right side controls work, I took it apart and cleaned it, but no difference. I will change the caps and see what happens, but the question is, is the failure in the remote or in the BM.
Evan
USA
Answered (Verified) Evan replied on Tue, Feb 7 2012 3:42 PM
Verified by Søren Mexico
Well, on the topic of diagnosing whether it is the remote or the BM, put your ear to the remote and check to see if it makes any noise when the buttons are pressed.
If the remote makes noise on all buttons, there is a problem in the BM.
Beo4 'til I die!
Dillen
Copenhagen / Denmark
ONLINE
Most likely in the Beomaster.
The received signals are grouped according to frequency in there and that corresponds to the left
and right buttons respectively.
Evan
USA
Beo4 'til I die!
Dillen
ONLINE
Søren Mexico
Mexico City
Dillen:
As I'm still running my BM 2400 for testing, its still open, will try to figure this out with help of the schematics.
Beobuddy
Utrecht, The Netherlands
ONLINE
And?
Already any progress?
My BM 2400 remote makes noises when you press on the aluminium buttons.
Page 1 of 1 (5 items) | RSS
