Screensaver at Beovision 11
Answered (Verified) This post has 1 verified answer | 5 Replies | 2 Followers
Hermann_
Hermann_ posted on Sun, May 26 2013 10:29 AM
Is there a way to have a Screensaver at BV11 while I listen music or radio from BV11?
DGRouge
Verified by Hermann_
One option is to add the p.mute function on the beo4. Just add it the function using the list key.
Michael
Sweden
Hermann_5F00_:
If you use an Apple TV (that you can mount inside the BV11 cable space) just select a screensaver and how long it will have to play before activating itself.
DGRouge
Hermann_
@Michael: But then i can't listen music from home media.
Hermann_
@DGRouge: With your tip I found also p.media. This is the solution, thanks a lot.
Michael
Sweden
Michael replied on Wed, May 29 2013 10:31 PM
Hermann_:
I also use P. MUTE but that is not a screen saver, but of course it does probably save the screen :)
Page 1 of 1 (6 items) | RSS
